Just a reminder Camber is a real thing #3290344
02/18/25 07:58 PM
02/18/25 07:58 PM
Capital of Narcissism
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
grin
Re: Just a reminder Camber is a real thing [Re: jcc] #3290752
02/21/25 11:02 AM
02/21/25 11:02 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
He has them angled the wrong way.
Mo' Farts
Moderated by "tbagger".
Re: Just a reminder Camber is a real thing [Re: Grizzly] #3290806
02/21/25 04:25 PM
02/21/25 04:25 PM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
Understand, with his blade angled to the drivers right, the dirt being pushed to the right is pushing the front wheels to the left, and to resist that left sideways force on the front tires, great traction is gained by leaning the front tires to the drivers right.
I like the mental example of pushing a pencil eraser on a flat surface.
Lean it into the direction of being pushed, it slides along.
Lean it away from (negative camber) the direction it is being pushed, and it "digs in", a good thing.
Re: Just a reminder Camber is a real thing [Re: jcc] #3290850
02/21/25 08:11 PM
02/21/25 08:11 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Sorry, but, no it doesn't.
The load on the right hand side tries to pivot the Grader clock-wise (when in the seat) and rotate the front to the right (into the ditch on a Road job). You have to tilt the wheels to the left to anchor the front if it needs it. I ran a 160m, 140m, and 14G long enough to know.
It's an Amateur running it: he doesn't need any camber at all for a Windrow a foot high, he's ruining the front tires for nothing. Camber adjust is more for doing slopes or if you are trying to dry out heavy wet clay in Road building.
They are a wonderful Machine to run with the hand controls, but I don't miss running one 7 days a week.
Still, nice to see one on here: there's a first for everything. Thanks for posting it up
Mo' Farts
Re: Just a reminder Camber is a real thing [Re: Grizzly] #3290863
02/21/25 09:39 PM
02/21/25 09:39 PM
jcc Offline OP
No soup for you!!!
jcc  Offline OP
No soup for you!!!
The grader is pushing dirt to the right,
That pushing is pushing the front wheels to the left.
The pictured camber resists that pushing best.
The amount of dirt being moved is immaterial here, in this context.
I haven't a clue why this point is being debated.
