2021 6.4 hemi swap accessory question #3290636
02/20/25 12:54 PM
02/20/25 12:54 PM
Andrewh Offline OP
Andrewh  Offline OP
I have a classic air setup in the car already.
can I just use the compressor on the motor?
I am using the mopar crate ecu to control it.
I have seen answers both ways, but they were not specific on the year of the engine.
I know they make a kit for the crate motors and that it is basically a 2014 jeep compressor. but if I can get away without doing it, I would rather.
same with power steering. I believe it is a 2014 ps pump. does it still need the lower pressure spring put in or is that good enough not to blow out seals in a 80 ps box?
Re: 2021 6.4 hemi swap accessory question [Re: Andrewh] #3290727
02/21/25 08:19 AM
02/21/25 08:19 AM
K
Kiddart Offline
Kiddart  Offline
K
call classic air on the compressor
also go over to For a bodies only to their swap forum. the power steering topic has been discussed a bunch. a lot to know about the power steering with hemi gen 3's
Thank you
Kiddart
Re: 2021 6.4 hemi swap accessory question [Re: Kiddart] #3290775
02/21/25 01:19 PM
02/21/25 01:19 PM
Andrewh Offline OP
Andrewh  Offline OP
Thanks, not a lot of info on the factory piece, but the relief valve is only 30 bucks so might go that route.
good idea, not sure why I didn't think to call them.
they said that it isn't compatible with their expansion valve.
might replace their valve with a factory valve instead of the compressor, but have to do some more research on that.
