Well that sucks! Valve seat failure.
#3286816
02/03/25 10:04 AM
02/03/25 10:04 AM
Posts: 4,918 Wichita
GY3
Wichita
I had driven the 330 to get gas the last time it was out. Parked it for a few weeks, went to restart and heard some not so good noises!
Apparently the valve seats fell out because the keepers, stems and locks were still in place and looked fine.
I can't be too disappointed because it's been together for for 10 years, 10,000 miles, hundreds of passes, ran 9's and was stone reliable as a driver up to this point.
Pretty sure the bottom end and block is fine but I'm going to put pistons, rings and bearings in while it's apart.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Well that sucks! Valve seat failure.
[Re: GY3]
#3286822
02/03/25 10:28 AM
02/03/25 10:28 AM
Posts: 75,420 A gulag near you.
JohnRR
A gulag near you.
one seat or both seats in the same chamber ? What head?
Mainstream Media is the new Pravda
[Re: JohnRR]
#3286830
02/03/25 10:50 AM
02/03/25 10:50 AM
GY3
Wichita
one seat or both seats in the same chamber ? What head? Both seats. 440 Source Stealth.
'63 Dodge 330
[Re: GY3]
#3286832
02/03/25 10:54 AM
02/03/25 10:54 AM
Posts: 14,591 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If the heads get torn down and inspected, I’d be interested in a report on the valve guide wear situation………since you have 10,000 miles of HR use/wear and tear. It would make for good reference data.
[Re: fast68plymouth]
#3286850
02/03/25 12:01 PM
02/03/25 12:01 PM
Posts: 2,942 Pattison Texas
CSK
Pattison Texas
If the heads get torn down and inspected, I’d be interested in a report on the valve guide wear situation………since you have 10,000 miles of HR use/wear and tear. It would make for good reference data. Back in 2017 I did a engine freshen up cause of a cam going flat, had about 5k miles on it, took the heads apart to do some better port work than I had done before, ALL the guides were toast, the 440 source valves that I had have machining lines like a record down the stems, NOT a smooth polished finish, not sure if that caused the wear or not, I replaced the guides & valves with ones for edelbrock heads in my Stealth heads.
[Re: CSK]
#3286917
02/03/25 03:15 PM
02/03/25 03:15 PM
Posts: 9,129 Rogue River, OR
Jeremiah
Rogue River, OR
Good and fortunate catch. My 511 had an intake start to come out on the 7th dyno pull.
The next time it comes apart I'll swap in a set of -1's or tf270's.
Are your Stealths out of the box as far as guides/seats? I had to have the guides and seats replaced. Less than 600lb open spring psi so nothung radical there.
Do you know your spring psi values? I'd be interested to know.
[Re: GY3]
#3286965
02/03/25 07:03 PM
02/03/25 07:03 PM
Posts: 231 Kansas
Thelma133
Kansas
Do you think nitrous played a role in the damage? O’Neill porting can fix that head for you. They are the one I told you about in another post. They do a lot of head repair, mostly race stuff. Guys name is Karl. They are in Benton, just short drive from you.
Notchback guy
[Re: Thelma133]
#3286984
02/03/25 07:57 PM
02/03/25 07:57 PM
Posts: 22,195 A collage of whims
topside
A collage of whims
Hmmm...aluminum expands at a higher rate than steel/iron, so I'm wondering if the seat fit was tight enough, or if there's too much heat in the chamber at times. That would seem to rule out a seat dropping during a cold start, as aluminum also contracts more than steel/iron, but I could be wrong, unless fatigue is playing a role ? Never had that happen on Stealths or Eddys or Indys on the street/strip cars, or on the Battens on the racecar, which once or twice I'd had some detonation, which I caught & addressed. Those heads had a couple hundred passes without issues, and are still working great on the car, which is probably 350-400 passes after last year.
[Re: CSK]
#3287027
02/03/25 10:44 PM
02/03/25 10:44 PM
Posts: 5,201 CT
GTX MATT
CT
If the heads get torn down and inspected, I’d be interested in a report on the valve guide wear situation………since you have 10,000 miles of HR use/wear and tear. It would make for good reference data. Back in 2017 I did a engine freshen up cause of a cam going flat, had about 5k miles on it, took the heads apart to do some better port work than I had done before, ALL the guides were toast, the 440 source valves that I had have machining lines like a record down the stems, NOT a smooth polished finish, not sure if that caused the wear or not, I replaced the guides & valves with ones for edelbrock heads in my Stealth heads. I also have a set with about 4000 miles on them, been running them for 10 years now. Guides in mine are also shot, I don’t have oil consumption or smoking issues but I get about a tablespoon of oil puddled on the back of each valve sitting overnight.
[Re: Thelma133]
#3287061
02/04/25 08:45 AM
02/04/25 08:45 AM
GY3
Wichita
Notchback guy Probably! 😆 I called him yesterday but found a deal last night…
'63 Dodge 330
[Re: Jeremiah]
#3287063
02/04/25 08:47 AM
02/04/25 08:47 AM
GY3
Wichita
Do you know your spring psi values? I'd be interested to know. Mine had new locks, springs and retainers before I got them. It’s been 10 years so don’t know the spring details.
'63 Dodge 330
#3287069
02/04/25 09:09 AM
02/04/25 09:09 AM
Posts: 3,559 Syracuse,NY
CompWedgeEngines
Syracuse,NY
If the heads get torn down and inspected, I’d be interested in a report on the valve guide wear situation………since you have 10,000 miles of HR use/wear and tear. It would make for good reference data. I bet we could almost guess what he'll find....I mean never say never,buuuuuuut........
RIP Monte Smith
[Re: CompWedgeEngines]
#3287140
02/04/25 01:35 PM
02/04/25 01:35 PM
CSK
Pattison Texas
If the heads get torn down and inspected, I’d be interested in a report on the valve guide wear situation………since you have 10,000 miles of HR use/wear and tear. It would make for good reference data. I bet we could almost guess what he'll find....I mean never say never,buuuuuuut........ So, what are you saying ??
[Re: Thelma133]
#3287230
02/04/25 08:13 PM
02/04/25 08:13 PM
Posts: 1,486 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I'm pretty sure Todd is saying that he'd expect the guides to be totally worn out at that point
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3287372
02/05/25 11:00 AM
02/05/25 11:00 AM
fast68plymouth
So. Burlington, Vt.
If someone has the heads bolted on and in service, they don’t really “know” how the guides are holding up(and neither does anyone else). So I look at heads that have been run, and off the engine…….as an opportunity to look them over and gauge how various aspects of the heads in question are holding up.
#3287376
02/05/25 11:20 AM
02/05/25 11:20 AM
CSK
Pattison Texas
I get that, I do the same, seeing BOTH intake & exhaust seats fall out leaves me scratching my head ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: CSK]
#3287377
02/05/25 11:28 AM
02/05/25 11:28 AM
fast68plymouth
So. Burlington, Vt.
I’ve got a two pair of marine heads here from the same boat. They’re mercruiser/Edelbrock heads. Out of 32 guides……31 are totally wasted. 1 is fine. I’ve done several sets of these thru the years, the guides are usually fine. As it turns out, it appears the guides in these 4 heads had been replaced before, with guides that are made from a different material than the originals.
So, the originals got bad enough to where they were replaced, and now the replacements are shot too.
The odd thing to me is the one guide that’s still fine, while all the others are all really bad.
As for the OP’s head with both seats falling out…….. My best guess is…….one fell out, then the trauma to the head from stuff bouncing around coaxed the other seat to come out.
Then again, looks like both valves broke off. Who’s to say one of those breaking off didn’t happen first?
#3287379
02/05/25 11:43 AM
02/05/25 11:43 AM
CSK
Pattison Texas
The odd thing to me is the one guide that’s still fine, while all the others are all really bad. That is weird one good out of 16, when I was building sprint car & oval track engines I was having hell with guides wearing out very fast & would lose some power off the corner, SBC stuff, I started leaving the valve stem seals off the exh 1st to experiment & they never wore out, intakes still went away fast, so I left the intakes off as well, problem solved, puff a little smoke sometimes but who cares, ran great, BUT this is race car stuff not for street cars, BBM heads would have a bad oiling problem if done this way, SBC it works ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) , maybe could use a small umbrella type seal so they get a little oil ?
