Re: 4000hp 71 Hemicuda drag and drive car
[Re: B1MAXX]
#3285809
01/29/25 12:50 PM
01/29/25 12:50 PM
Posts: 10,160 MN
JERICOGTX
MN
maybe kicked a rod and threw the belts.... You can see the belt hit the ground early in the run.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3285813
01/29/25 01:02 PM
01/29/25 01:02 PM
Posts: 4,918 Wichita
GY3
Wichita
maybe kicked a rod and threw the belts.... You can see the belt hit the ground early in the run. We saw that on the video and wondered what it was.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: Dart 500]
#3285935
01/30/25 12:11 PM
01/30/25 12:11 PM
Posts: 8,136 Tulsa OK
Bad340fish
Tulsa OK
Sucks to see. So now day 1 he's out, Bailey is out, Lutz is out and I think Morris is struggling with the wagon as well.
They said Bailey may be joining the $7500 drag car challenge for the week, but he has to find a car (look up cleetus mcfarland channel, if anything its been very funny, they are on episode 2) That really sucks about Matt's car. I am sure he has the data showing the voltage dropping then the oil pressure dropping. I think tire shake might have caused it all? The big block big tire guys are sure in a tough spot with a 302 cubic inch mustang with a factory block and head casting in #1 overall.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3285959
01/30/25 01:31 PM
01/30/25 01:31 PM
Posts: 12,574 Taxes & Virus's R-US, NY
Dragula
They said Bailey may be joining the $7500 drag car challenge for the week, but he has to find a car (look up cleetus mcfarland channel, if anything its been very funny, they are on episode 2) That really sucks about Matt's car. I am sure he has the data showing the voltage dropping then the oil pressure dropping. I think tire shake might have caused it all? The big block big tire guys are sure in a tough spot with a 302 cubic inch mustang with a factory block and head casting in #1 overall. The Snot Rocket is flying....no doubt. You would think with all the factory parts in his build, he would be the one having the breakage issues...
[Re: 605ply]
#3286537
02/01/25 10:14 PM
02/01/25 10:14 PM
Posts: 7,657 Minnesota
Hemi_Joel
Minnesota
In the video they say that the motor didn't fail because of the belt. It threw the belt because of the engine failure. I was thinking "Matt, Rich, did you see the video? We can see the belt hit the track one second before the crash!" So I watched the video again at 12:23 in slow motion. Now, I don't think that is the belt we see hitting the track, it is something else. It looks too solid to be a belt. https://www.youtube.com/watch?v=WjLtcJiqZuc
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
