A Body Tubular Upper Control Arms
[Re: moparts]
#3283566
01/19/25 09:30 AM
01/19/25 09:30 AM
Posts: 311 Long Island, NY
ValiantRich
Long Island, NY
Pair of A Body Tubular Upper Control Arms. Heim Joints and Ball Joints are perfect and ready to install. I had brackets welded on to attach travel limiters. These arms were in my car for a very brief period of time due to a change in plans. $350. rich1981@optonline.net SOLD
Re: For Sale - Magna Flow Quick Star 300
[Re: moparts]
#3284308
01/22/25 03:52 PM
01/22/25 03:52 PM
Posts: 2,144 New Lenox IL
cudadon
New Lenox IL
Quick Star 300 pump with built in filter. $325
Magna Flow regulator $50
Postal money order or Paypal friends& family
Buyer pays shipping Thanks Moparts
Re: For Sale P4876548 water pump
[Re: OUTLAWSSAA]
#3284937
01/25/25 05:20 PM
01/25/25 05:20 PM
Posts: 2,099 oberlin, Ohio
Rapid340
oberlin, Ohio
Mopar performance P4876548 high performance SB water pump.
Radiator connection tig welded to clear large fuel pump
$385 obo
thanks
rapid340@yahoo.com
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: For Sale Holley double pumper 4 bbl 4776
[Re: Rapid340]
#3284938
01/25/25 05:42 PM
01/25/25 05:42 PM
Rapid340
oberlin, Ohio
Super nice Holley double pumper 4 bbl 4776 classic
These are around $750 (plus tax) new
$385
thanks
[Re: Rapid340]
#3284940
01/25/25 06:12 PM
01/25/25 06:12 PM
Rapid340
oberlin, Ohio
NOS Mopar Performance intake manifold
large port intake for use with W5 or similar heads.
$485
thanks
rapid340@yahoo.com
3' Hooker Aero Chamber Mufflers 21505HKR
[Re: moparts]
#3285448
01/27/25 09:43 PM
01/27/25 09:43 PM
Posts: 145 Central Pa.
Cloned_Cuda
Central Pa.
The mufflers are brand new and were out the boxes for fitting only.
$160 for the pair plus shipping or pick up.
AED 785 Vacuum Secondary Carbs
[Re: Cloned_Cuda]
#3285451
01/27/25 10:03 PM
01/27/25 10:03 PM
Cloned_Cuda
Central Pa.
These Carbs came with the engine I had built, and they are basically brand new. They come with Carb Kits from AED and Quick Fuel Adjustable Secondaries.
$1500 for the pair plus shipping.
US Car Tool Driveshaft Loop
[Re: Cloned_Cuda]
#3285454
01/27/25 10:22 PM
01/27/25 10:22 PM
Cloned_Cuda
Central Pa.
Driveshaft Loop was new, bolted it up on car, decided to do something different.
$70 plus shipping. **PENDING**
Re: For Sale - Race Parts - 1st Quarter
[Re: moparts]
#3285457
01/27/25 10:31 PM
01/27/25 10:31 PM
Posts: 3,559 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Wilwood Brake Proportioning Valve===as you see it , just the valve.
$25 plus USPS shipping from Syracuse NY
Pay Pal only. Shipping will be USPS Flat Rate or being a smaller item maybe just first class.
RIP Monte Smith
Larry Morgan 500 cubic inch race motor parts
[Re: moparts]
#3286660
02/02/25 02:30 PM
02/02/25 02:30 PM
Posts: 3,366 St.Louis,Mo.
70RR383
St.Louis,Mo.
2 Book Racing Carbs,1250-1500 CFM .,,,,,,,2500 OBO,,,,,,,,,,,,,,,,,,C&R racing radiator 22X13 with extras,,,,,750.00,,,,,,,,,,,,,,Complete dry sump oil system,1250.00,,,,,,Coan racing trans,,turbo 400,..4500 stall,,,,make offer,,,,all parts have about 2 hrs run time on them,,,,,COMPLETE motor setup,disassembled is available,,heads have damage,,block,pistons,ect good shape....St Louis area.....,,message me for pictures
Indy 572-13 Top-end plus RB
[Re: 70RR383]
#3287150
02/04/25 02:09 PM
02/04/25 02:09 PM
Posts: 4,317 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I have a good pair of 572-13 heads, Jesel rockers kit and matching CFE 2x4150 sheet intake WITH linkage. Ti 2.3 coated intakes and Ti 1.88 exhaust. Set up made over 900HP on a 452 RB about 20 years ago. Need an exhaust valve job and springs. I can finish them to your liking for extra money. I was going to use these to make 1050HP with some tune-ups and bigger cam but have Predator heads now. These will push a 3200# car solid into the 8's as-is at a nice low rpm. (bracket) Chambers are about 66cc now and can be milled further. $3800. I have two fresh and matched '950' HP carbs, tuned well on my last motor $1400 with package. 55mm 4/7 swap cam about .790' NET lift with heads $425 with package. New 572-13 CP 4.507" 1.2 C/H pistons with rings/ latest tricks $1800 with package. Good stuff! Heads were painted and I'll detail/clean them when purchased. Decks are good currently. Contact thru Moparts Thanks!
