AMX Update #3283987
01/21/25 01:37 PM
01/21/25 01:37 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Talked with several members asking about the AMX I bought rom Tom (AMXAutoX) last April so I thought I’d post an update.
After some serious medical issues about the time I bought the car from Tom I was finally able to get up to Washington in early August. A buddy from Yakima picked up the car along with some of the parts and another buddy from the Olympia area picked up the remainder of the parts. As part of the deal I purchased the open trailer Tom had for transporting the car to and from Autox events.
Got the car home where I immediately put on a good coat of wax and some tire dressing to protect the tires. I then covered the car up unit the temps were more reasonable. This past summer we has over 100 days straight of 110 temps.
Once the temp subsided I did an initial assessment of the car. It had been stored most of the time since around 1999 so I treated it as a new build. I did a breakin of the engine and changed all the fluids
Other things I’ve done to date
Had the bucket seats recovered. They are Corvette C3 seats. The jury is still out on keeping these seats.
Pretty much leave the drive train alone. The motor was freshen up around 1999 so no reason to mess with it. It has a scatter shield along with the stock T-10. I’m considering putting the stock bell housing back on. I also purchased a rebuilt Hurst tower in that I’m having issues downshifting to second gear.
As far as suspension the car is pretty solid however it looks like the rubber bushings are showing some age so I may freshen those up. I’ll probably stick with rubber vs polygraphite.
The rear is the stock AMC20 with the two piece rear axles, the twin grip with 3.54s. I bought a set of 3.31s along with the axle conversion for the AMC20. Given I drivea lot on the freeways the higher gears will help. I do plan on a TKX 5 speed conversion down the road.
I bought some new tires putting them on the 15x7 and 15x8 Magnums Tom gave me. When I picked the car up it had 14x7 Magnums with tires that were over 20 years old. They were actually in really good shape however with the temps here in Phoenix I decided to change over for safety’s sake. I freshen up the front brakes with new rotors and pad that Tom gave me. A brake upgrade in the near future is being considered.
I’m planning on taking the car to Springfling with a detour over to Willow Springs for the open track day. I’d like to run it around the track to see how it handles. With all the mods on the car, Tom correct me if I’m wrong but it looks like he was leaning toward making more of a track car. Not knowing what went into the motor as far as mods such as bearing clearances, oiling mods etc. I’ll take it easy. As far as external oil mods it has a remote filter, oil cooler and oil returnlines to keep the sump full of oil.
As far as running some of the local tracks I did join SCCA which allows me to running two open tracks on our area.
C5F27E62-79D3-4AF4-87EB-68964BB61C9D.jpegBF8085D4-D00C-48C2-B904-25FB3D2C7272.jpegAC749F2D-9307-4152-8CAD-F84DC0BEF3D5.jpegEE132AAA-571D-439B-BDE7-C64AF1BF4D17.jpeg
Abe Lincoln
Re: AMX Update [Re: dart4forte] #3283992
01/21/25 01:53 PM
01/21/25 01:53 PM
NJ
rdrnr6970 Offline
Your #1 source for current events
rdrnr6970  Offline
NJ
Nice AMX!Glad to hear you're doing better! boogie drive
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: AMX Update [Re: rdrnr6970] #3284145
01/21/25 11:00 PM
01/21/25 11:00 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: AMX Update [Re: BloFish] #3284158
01/22/25 05:44 AM
01/22/25 05:44 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Iirc there's overdrive gears for the T10. And, I'd think about lower gears in the rear if adding OD.
I like the AMC paint jobs of that era but the tail stripe just seems weird.
Angry white pureblood male
Re: AMX Update [Re: ruderunner] #3284164
01/22/25 07:08 AM
01/22/25 07:08 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
I'm pretty sure the tail stripe you're seeing is a shadow.
Re: AMX Update [Re: moparmike1] #3284192
01/22/25 10:03 AM
01/22/25 10:03 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, that's a shadow - see OP's photos at the start of the thread.
Nice to see Tom's car being cared for, attaboy on that.
3.54 to 3.31 will be barely noticeable, but the axle mod sounds like a good idea.
AMC motors had oil circulation issues in competition, but are OK on the street.
I recall articles on the fix for that - Traco on the Penske TA cars, and an engine build in Hot Rod.
Re: AMX Update [Re: topside] #3284205
01/22/25 10:23 AM
01/22/25 10:23 AM
here.
Remy-Z Offline
Remy-Z  Offline
here.
Glad to see the AMX has a great home! up
Re: AMX Update [Re: moparmike1] #3284241
01/22/25 11:30 AM
01/22/25 11:30 AM
Mesa, Arizona
Mesa, Arizona
LOL, that was the shadow of a light pole
Abe Lincoln
Re: AMX Update [Re: topside] #3284245
01/22/25 11:42 AM
01/22/25 11:42 AM
Mesa, Arizona
Mesa, Arizona
Yeah, when I delved into the motor or I noticed a lot of oil lines. Lines from the oil pump adapter to the remote, lines to the oil cooler and back, two oil lines from the each valve cover draining accumulated oil at the top of the head to the oil pan. My only concern with driving on the street is the low oil pan and those oil line connections to the pan. So far no issues with speed bumps.
Tom gave me a slew of documents to include a lot of tech info. I’m seeing where he incorporated a lot of those oiling mods above and beyond hat of an autocross car. More of a slant toward road racing.
Abe Lincoln
Re: AMX Update [Re: dart4forte] #3284248
01/22/25 11:47 AM
01/22/25 11:47 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Those are such fun cars.
A good friends Dad had one that I used to wrench on.
The little 390 was plenty stout!
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: AMX Update [Re: dart4forte] #3284326
01/22/25 05:53 PM
01/22/25 05:53 PM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
I went to a few events that Tom attended. It's great to see the car out again. up
Re: AMX Update [Re: Hemi_Jack] #3284354
01/22/25 07:52 PM
01/22/25 07:52 PM
Mesa, Arizona
Mesa, Arizona
I remember attending several auto crosses over at Boeing in in Kent, WA. In fact I belive he and I competed in the same class, E/SP.
Abe Lincoln
Re: AMX Update [Re: dart4forte] #3284591
01/23/25 09:08 PM
01/23/25 09:08 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Heya buddy -- long time, I know. Do you know Rick Guisto? He has two AMXs in Chandler and autocrosses his '71 Challenger. If you don't know him, I can introduce y'all.
-- Mike
Re: AMX Update [Re: Hotwheelsjr] #3284606
01/23/25 10:37 PM
01/23/25 10:37 PM
Mesa, Arizona
Mesa, Arizona
-- Mike
Oh yeah, I know Rick. He came by the house last month to pickup some AMC parts I gave him. We talked quite a bit about his AMX. Good guy.
Abe Lincoln
Re: AMX Update [Re: dart4forte] #3285892
01/29/25 10:32 PM
01/29/25 10:32 PM
Hotwheelsjr Offline
Hotwheelsjr  Offline
-- Mike
Yup, shore is. I was just talking to him a couple of days ago and I asked if he knew you....shore enuff, yup!
Re: AMX Update [Re: Hotwheelsjr] #3285893
01/29/25 10:34 PM
01/29/25 10:34 PM
Hotwheelsjr Offline
Hotwheelsjr  Offline
-- Mike
Many moons ago, you were moving here or visiting from the northwest or something. I came and picked you up in my demon. I think we went to breakfast or something. I'm getting old and senile now. realcrazy
Re: AMX Update [Re: Hotwheelsjr] #3285908
01/30/25 07:06 AM
01/30/25 07:06 AM
Mesa, Arizona
Mesa, Arizona
-- Mike
Yeah, I remember that. I think it was just after we moved here.
Abe Lincoln
