Re: 727 Shift Lever seal [Re: autoxcuda] #3283795
01/20/25 04:26 PM
01/20/25 04:26 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I polished both the selector and kickdown shafts.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: 727 Shift Lever seal [Re: autoxcuda] #3283797
01/20/25 04:33 PM
01/20/25 04:33 PM
So Cal
So Cal
make sure to take pictures of everything assembled before you take it apart.
Especially the selector comb and note what position it's in so you put it back in the same gear.
I put a little grease on the OD of the shaft so it didn't tear or mess up the seal. The seal had some grease in it already.
Re: 727 Shift Lever seal [Re: autoxcuda] #3283799
01/20/25 04:49 PM
01/20/25 04:49 PM
Star Idaho
67vertman Offline OP
Star Idaho
Thanks for the great pictures and tips. I am looking forward to starting it, but it needs to warm up first. snowblow
My Monster are real!
Living within your means makes life pretty easy.
Re: 727 Shift Lever seal [Re: 67vertman] #3283826
01/20/25 06:43 PM
01/20/25 06:43 PM
So Cal
So Cal
I used this durring wheel to polish the surface.
Love these. I leave this on my bench grinder and a brillo flapper wheel.
I use it for trim prep for polishing. Speeds up taking out deeper scratches.
https://www.mscdirect.com/product/details/84524925
This is like my flapper wheel. I think there's less expensive versions out there
https://www.mscdirect.com/product/details/62000823
Re: 727 Shift Lever seal [Re: autoxcuda] #3283853
01/20/25 08:53 PM
01/20/25 08:53 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up This is where many fail and wonder why it still leaks whistling beer
Re: 727 Shift Lever seal [Re: autoxcuda] #3283856
01/20/25 09:02 PM
01/20/25 09:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have exactly the same setup but use a lathe with strips of various grit sandpaper. One would need to be careful not to create flat spots with the wheels or have the wheel grab it and sling it beer
Re: 727 Shift Lever seal [Re: 67vertman] #3283872
01/20/25 10:43 PM
01/20/25 10:43 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
You should have a mile of room to change it without removing the pan. I did one in my 70 Challenger by picking it out with a small straight screwdriver, then after polishing the shaft with a scotchbrite pad, I used a C clamp and a deep socket same size as the seal and pushed back in. It worked great!
