New SCAT Forged 360 & 5.9 Magnum Stroker Rotating Assembly
[Re: Rocket]
#3280662
01/05/25 12:31 PM
01/05/25 12:31 PM
Posts: 963 CT
Rocket
CT
I have a new SCAT forged rotating assembly for 360 & 5.9 Magnum Mopar engines. All parts are new high-quality parts. Final cubic inches will be 408”. The assembly includes the following parts.
• SCAT forged 4.000” crankshaft part # 4-360-4000-6123 • SCAT forged H-beam connecting rods with APR 2000 bolts part # 2-360-6123-2124A • Diamond Forged flattop 4.030” bore pistons (0.030” oversize) part # 51026 • Trend wrist pins - 0.984” part # TPD-G9842750155 • Diamond wrist pin locks • Mahle file fit ring set with Moly ductile iron top rings part # MAH4035MS • Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH • Clevite P-Series full groove main bearings part # MS-1266P
If you are looking for a 360 stroker with lower compression, I can substitute the pistons and connecting rods for new SRP 4.030” dished pistons part # 220156 (16.9 cc piston head volume) and new Eagle H-beam rods part # CRS6123C3D (360 stroker assembly only).
These rotating assemblies will need balancing.
The price for this complete kit with the Diamond flat top pistons and SCAT rods is $2,750 plus shipping cost.
The price for this complete kit with the SRP dished pistons and the Eagle H-beam rods is $2,600 plus shipping cost.
I can also meet in CT.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Lunati Big Block Solid Roller Cam & Lifters - New
[Re: Rocket]
#3280672
01/05/25 12:45 PM
01/05/25 12:45 PM
Posts: 963 CT
Rocket
CT
I have a new Big Block Lunati solid roller cam part # 40230912 & solid roller lifters part # 72451-16. The specs of the cam are as follows: Part # 40230912 Basic Operating RPM Range: 4,500-7,500 Duration at 050 inch Lift: 276 int./284 exh. Advertised Duration: 312 int./320 exh. Valve Lift with Factory Rocker Ratio: 0.690 int./0.690 exh. Lobe Separation Angle 106 Camshaft Gear Attachment: 3-bolt Valve Lash: 0.026 in. Intake 0.028 in. Exhaust
Lifter Specs and Description are as follows: Part # 72451-16 Fits Engines 361-440 Lifter Diameter 0.903" Weight – Lifter Pair 256 grams Seat Height 1.98" Pressurized Oiling to Roller Bearings - Yes Pushrod oiling - Yes Lifter Wheel Diameter 0.81”
Developed for serious racing applications, the pressurized oiling system of these lifters provides constant lubrication through the axle and to the needles. This reduces wear in the axle and increases the durability of the lifter. Also, for increased durability, all surfaces are hardened and polished, which makes the body stronger and smoother while reducing friction. The solid vertical bar roller lifters with pressurized oiling are held to higher standards than the competition for the ultimate in race lifters
Was planning to build a big block bracket engine but plans have changed so these are no longer needed. I have not opened the lifter package as it is one of those plastic packages is like Howards lifters and usually breaks and never stays shut on its own afterwards. Picture of lifter pair is what was on a retailers website.
Price for the cam and lifters is $1,250 plus $35 shipping in the lower 48 states.
Email me at procketrichard@hotmail.com for more pictures or any questions.
Milodon Small Block Gear Drive - Used
[Re: Rocket]
#3280677
01/05/25 12:50 PM
01/05/25 12:50 PM
Posts: 963 CT
Rocket
CT
I have a nice used Milodon gear drive part # 13600 for small bock engines. This was used on my W2 headed 360 bracket motor. It provided rock solid ignition and cam timing. I was saving this for a future rebuild however I sold the car so this is no longer needed. All the gears and bearings are in great shape. Pictures do not show the mounting bolts but they will be included.
Description from Summit Racing is as follows:
“Milodon timing-gear drive assemblies are designed for all-out competition, but work equally well in any application. Their proven fixed idler gear system is capable of maintaining consistent cam timing without siphoning off power the way 4-gear types can. Timing changes are easy via Milodon's adjustable bolt pattern cam gears and hub assemblies. Made for strength and durability, these gear drives will last indefinitely. They are available in a flat-cover style, which uses a stock-type water pump, or an injected/blown style, which doesn't use a stock-type pump.”
Price is $325 shipped in the lower 48 states. I will ship internationally for the added cost if any.
Re: For Sale - Race Parts - 1st Quarter
[Re: Dragula]
#3281098
01/07/25 09:29 AM
01/07/25 09:29 AM
Posts: 972 Odessa, Fl
blowndart
Odessa, Fl
FAST XFI 2.0 ECU, Part # 301000 for sale. Used FAST XFI 2.0 self-tuning EFI system with harness in great condition. All electrical harnesses are included to get your engine running. Also includes a new power adder harness, which is used for Nitrous control or Boost control and an adapter cable for the distributor to allow you to connect to a Holly/MSD dual sync distributor if you’re not using a FAST dual sync distributor. Includes the FAST/ NTK wide band O2 sensor, 1 BAR MAP or 2 BAR MAP sensor and C-Com laptop cable. The only sensors that you should need to get your engine running are the air and water temp sensors, which are inexpensive GM sensors, and the TPS and IAC, on your throttle body. NO throttle body is included. The only reason I’m selling this is because I needed to switch to a Holley Dominator ECU because I needed more inputs and outputs and drive-by-wire throttle control. Below is more info on the ECU. FAST XFI 2.0 Engine Control Units FAST XFI 2.0 engine control units deliver--fast! Utilizing the latest technology, FAST XFI 2.0 units can process, analyze, and adjust four times quicker than previous EFI systems. The C-Com XFI Windows-based software is easy to navigate and features field-flashable capabilities, so you can download the latest software updates via email or directly from FAST. These XFI control units also feature Qwik Tune for programming without a laptop. Pre-program up to four different EFI maps--optimize a setting for your daily driving, one for racing conditions, and still another for fuel economy. You'll enjoy on-board diagnostics, EZ Test indicator lights, 5-bar MAP sensing and controls, plus enhanced data-logging capabilities and memory.
Some of the FAST XFI 2.0 engine control units' standard features include:
* Built-in wideband O2 * Fully sequential and/or bank-to-bank capability * Individual cylinder correction * Fan and fuel pump control * Dynamic scaling of vectors in 2D and 3D tables * Torque converter lockup control * Air conditioning wide-open throttle cutout * Boost control * Fuel and oil pressure logging * Adjustable injector timing * Multiple ignition strategies Asking $500 + Shipping. PM me here for more info.
Inconel Rear Axle Tie Down Brackets
[Re: moparts]
#3282319
01/12/25 08:36 PM
01/12/25 08:36 PM
Posts: 24,328 Capital of Narcissism
jcc
No soup for you!!!
No soup for you!!!
These are IMO an upgrade/redesign of the long offered well accepted STD Mopar rear axle steel tie downs. Over a year ago I offered the vendor to pay any reasonable costs he incurred to build me a few sets of alternate material, like SS or Ti. He declined. I suggested just build a few sets and see if there is a market for it. No deal. There is IMO nothing wrong with the steel tie down currently offered.
So, after a year of planting the seed, I just decided to just do it myself. I was fortunate enough to acquire some suitable super alloy at a decent cost for the project, Inconel 718 or AMS 5596. This gave me some additional leeway in the design. I have had many unique items copied in my niche business over many decades, it is a little annoying and few if any of the copies were better. What I have here I believe is better, but I am not in business to produce them, I have limited amount of material able to be dedicated first to my cars When the extra sets are gone, I'm likely done with the project.
Inconel's most widely known attribute is its strength in high temps, like turbo exhaust valves, which obviously does not apply here. Its raw very high strength, high fatigue life and corrosion resistance are very useful qualities however in this application. The steel version pictured is .250" thick and weighs 29oz, and steel is usually in the 60Ksi Tensile and 35Ksi yield range. The break for bending, steel being a softer material, leaves a noticeable mark. The Inconel here is .159" thick with an optimized design and weighs 13oz, I calculate it's about min 2x the strength of the steel offering. Any additional drilling if needed is likely a rather tough task. Nickel Alloy 718 / Inconel 718 (UNS N07718)- Aircraft Materials There are many sources online for your own verification ++++++++++++++++++++++++++++++++tensile ksi___ yield ksi __ elongation __ Hardness Alloy 718 Sheet AMS 5596 Aged < 0.1874" thick____ 180 ______ 150 _______12_______ ≥36 HRC
Pair shipped USPS lower 48 $150, does not include nuts. First PAID, First served, these are not for everybody, but it might be hard to find a better solution. PM
They also may polish up real well, but I don't know as I haven't tried
Re: (NEW) LSM SC-100 Valve Spring Compressor/LSM SH-60 Speed Hdl
[Re: EvilB1Dart]
#3283244
01/17/25 02:19 PM
01/17/25 02:19 PM
Posts: 5,091 new jersey usa
11secdart
new jersey usa
For Sale Sanders Wheels 15 x 12 6 inch backspacing. 5 x 4.5 bolt pattern $700 in Stroudsburg Pa, selling for a friend Scott 1-570 -460-6090 or pm me or lbvracing@aol.com
*sold ****
[Re: 11secdart]
#3283280
01/17/25 06:13 PM
01/17/25 06:13 PM
Posts: 3,444 Pa
Hot 340
Pa
******no longer available ******
Old but NEW unused stock hydraulic lifters for small block. Part #HT2011. All have a very consistent crown of .003 checked in my tool fixture.
[Re: moparts]
#3283444
01/18/25 01:10 PM
01/18/25 01:10 PM
Posts: 16,243 oak park, il.
dsd70bee
oak park, il.
14 vintage Keystone Klassic wheels, some are 14 inch, some are 15 inch, most are 4 1/2 inch bolt circle, a couple are 4 3/4 inch bolt circle, there are no unilug, selling as is, selling as cores to restore, what you see is what you get $2000.00 for everything (708) 288-2879
