That's because water needs 80 calories per gram to melt (or freeze), not that measly one calorie per cc needed per degree of temperature change. Thank you Mr Karst, Thank you Mister Witham. Thank you Mr Broman. Chemistry, physics, and math. What I learned back in the dark ages still holds true today. 👍
