Page 2 of 3 1 2 3
Re: Exactly WHY is my car hard to start when warm? [Re: BossRide] #328180
05/26/09 09:10 AM
05/26/09 09:10 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I had this problem and was also baffled until I spoke with Doug Dutra, the famous slant six guru. He explained what was happening:
When you shut off a warm engine, the heat from your engine's intake manifold is boiling the fuel in your float bowl and causing it to drip into the intake etc causing an excessively rich condition. This happens because the fuel percolation drops the float and allows more fuel from the still presurized fuel line, between the fuel pump and the needle and seat to flow more fuel into the carb to bring the float level back to normal. This continues until the pressure in the fuel line between the fuel pump and the needle and seat goes to zero. In the mean while, a significant amount of fuel has now percolated out of the carb AND the pressurized fuel line between the fuel pump and the carb (until the presure is released by the process). Quite a bit of gas ends up in the intake every time you shut off a hot motor.
This is how you fix it:
#1 Use two gaskets and a sheet of aluminum to isolate the carb from the intake manifold. This will likely require longer carb studs. Be sure to check for hood clearance. (this helped a lot, but did not eliminate the problem completely)
#2 Install a fuel return line from a 3-nipple fuel filter, which is available from any autoparts store between the fuel pump and the carb, and the fuel tank. The third nipple on the 3-nipple fuel filters has a metered orifice to limit the amount of fuel it flows. I had to install a return line and a 2 fitting fuel sending unit on my 68 slant six car to complete this installation. The car had an original 5/16 fuel line, so I added a 3/8ths line as the main fuel line and used the 5/16ths line as the return. I bought a dual fitting fuel sending unit for less than $50 off ebay, ran the lines, installed the 3-nipple filter. I never had a hot start problem again.
Re: Exactly WHY is my car hard to start when warm? [Re: jbc426] #328181
05/26/09 09:23 AM
05/26/09 09:23 AM
that's good stuff, #1 for the heat & #2 to release the psi
Re: Exactly WHY is my car hard to start when warm? [Re: RapidRobert] #328182
05/26/09 09:41 AM
05/26/09 09:41 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yah, that Dutra is something else! If you don't want to spend the money on a new dual nipple fuel sending unit, you can drill and add a fitting to your existing sending unit by using those brass hardware store parts, some cheap aluminum return line and the fuel filter. The total cost is around $40 or less.
Re: Exactly WHY is my car hard to start when warm? [Re: RapidRobert] #328183
05/26/09 09:41 AM
05/26/09 09:41 AM
North Carolina
jt1 Offline
jt1  Offline
North Carolina
I understand the fuel boiling and evaporating out the vent tubes, but how does any fuel get into the engine to cause a rich condition? It seems something would have to force the fuel thru the jets and out the boosters.
John
Re: Exactly WHY is my car hard to start when warm? [Re: 1_WILD_RT] #328184
05/26/09 10:09 AM
05/26/09 10:09 AM
S.E.Ohio
Magnumguy Online content
Magnumguy  Online Content
S.E.Ohio
Seriously try a heat shield, it deflects most of the engine heat around the carb...In order to clear the linkage I had to trim one corner a little but it works great... Not a pretty as some other spacers but more effective & I care more about function as I like to drive my car... And if your gonna drive it it's gotta start..
Where'd you get the spacer (shield) on the right?
I wonder if you don't have your floats too high. Every Magnum I've owned (and it's been alot) would start pretty much the same hot or cold, except one of my current driver one. It will smoke black some when it starts hot, rolls over OK, but takes 2-3 seconds, but almost instant cold.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Exactly WHY is my car hard to start when warm? [Re: BossRide] #328185
05/26/09 10:20 AM
05/26/09 10:20 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Prob not heat as much as your timing is off
Re: Exactly WHY is my car hard to start when warm? [Re: RATTRAP] #328186
05/26/09 10:28 AM
05/26/09 10:28 AM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
That has crossed my mind... maybe I'll double check it... with the Holley and intake, mild cam and headers, should I set it different that the stock specs?
It was set when the engine was installed and I forget exactly what we set it at, it's been almost two years.
Funny thing, the old tired 2bbl 318 did the same thing... start great, spin over and over when hot. It acts like the gas has left the carb, and it will catch slowly, but not be skippy or stumble, just light off slowly.
The Blue Goose
My instagram: Bossride
Re: Exactly WHY is my car hard to start when warm? [Re: jt1] #328187
05/26/09 10:44 AM
05/26/09 10:44 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
John
Slant sixes are the worst. Fuel line is routed like crap! Even before they started adding alcohol to our fuel my 72 had to be held to the floor to start hot. This was on 50* days too!
Rerouting the fuel line worked excellent! No return line needed. My 74 slant Dart has the same problem.
Fuel injection hose with the fuel injection clamps routed over the valve cover with enough slack to pull the cover to set your valves works. It is in a sticky on www.slantsix.org in the engine section.
I have watched hot steamy gasoline boil and dribble into my hot intake many times.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Exactly WHY is my car hard to start when warm? [Re: rss] #328188
05/26/09 11:07 AM
05/26/09 11:07 AM
cataclysm80 Offline
cataclysm80  Offline
This might make you feel better.
Mine has gotten to the point that it won't even start when warm. Nearly had it towed last week when I shut it down to fill up with gas. By the time the tow truck arrived it started and I was able to drive home. Fires up great cold, runs great, but if I turn it off and try to restart hot I can just crank away till the battery is nearly dead.
My original 1938 ford flathead does that same thing. I've been told it's caused by a bad coil that fails when it gets hot.
Check your spark next time it happens.
Tav
Re: Exactly WHY is my car hard to start when warm? [Re: Rug_Trucker] #328189
05/26/09 11:25 AM
05/26/09 11:25 AM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
With all the talk about percolation and fuel boiling, makes you wonder why more fires aren't getting started! If that's even possible?
Here's one though, for those with more than one carb. Right now, I'm using a Holley 750DP, but I also have a nice TQ. What few times that I've used the TQ, it didn't seem to hot start any. Would this be because of the phenolic design? In other words, would an extra 20 degrees cooler, which the TQ's are said to run on average, make the necessary difference to keep the fuel boiling at bay?
Re: Exactly WHY is my car hard to start when warm? [Re: 68Bullit] #328190
05/26/09 11:32 AM
05/26/09 11:32 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
What does the engine have for cylinder pressure? As bad as the gas is, I have yet to have an issue like this on any of mine or customers'. We have the 10% ethanol fuel, have for 4 years now at least. My truck has run at 220° before when working, and 45 minutes after parking, it turns over 2-3 times and it's fine. I find most of the issues with starting are a result of tuning or lack of cylinder pressure due to wear, or camshaft choice, or camshaft timing. Much more so than percolation issues. JMO.
Re: Exactly WHY is my car hard to start when warm? [Re: Magnumguy] #328191
05/26/09 11:51 AM
05/26/09 11:51 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
http://store.summitracing.com/egnsearch....p;x=39&y=10
Re: Exactly WHY is my car hard to start when warm? [Re: 1_WILD_RT] #328192
05/26/09 01:20 PM
05/26/09 01:20 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
How thick is that shield? (How much vertical space will it take up, gaskets included) for those with hood clearance concerns?
Re: Exactly WHY is my car hard to start when warm? [Re: 68Bullit] #328193
05/26/09 01:44 PM
05/26/09 01:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Less than 1/4"... Most of the heat rises around the plate rather than through the carb body...
Re: Exactly WHY is my car hard to start when warm? [Re: Rug_Trucker] #328194
05/26/09 02:08 PM
05/26/09 02:08 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
John
Rerouting the fuel line was my first attempt at getting rid of this problem. Then I did the heat shield, which I cut out from 18 gauge sheet aluminum from Orchard Supply Hardware, and that worked for all but the hottest days. Finally, I ran the return line.
In addition to eliminating the hot starting issues, the cooler carb and fuel gave me a noticable performance improvement.
Re: Exactly WHY is my car hard to start when warm? [Re: jbc426] #328195
05/26/09 02:56 PM
05/26/09 02:56 PM
IL
71383beep Offline
71383beep  Offline
IL
I too experience this problem. We also have the mandatory 10% ethanol blends and have come to the conclusion that a a vapor separator is probably needed.
It sucks though. Go for a cruise. Car starts and runs just fine. park for a half hour and she won't start. Pedal to floor crank and eventually she'll fire. Very frustrating.
I got a separator from the last swap/show. Now I just need to cut my nice new steel braided carb supply line... and install a return line.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Exactly WHY is my car hard to start when warm? [Re: moper] #328196
05/26/09 07:10 PM
05/26/09 07:10 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
If you are correct, then why would the car fire up instantly when cold but not start hot? Do poorly tuned cars run well cold???
Re: Exactly WHY is my car hard to start when warm? [Re: Rug_Trucker] #328197
05/26/09 07:32 PM
05/26/09 07:32 PM
MNobody Offline
MNobody  Offline
"I have watched hot steamy gasoline boil and dribble into my hot intake many times."
I had the same problem with my 750 Holley on my 318, the bowl's were getting so hot you couldn't touch them up by the carb base. The whole problem was solved with a 1/2" plywood spacer under the carb, the bowl's are almost cool to the touch now and it doesn't sound like coffee brewing in the carb anymore, i do still get a little smoke out of the primaries but no fuel dripping above the throttle plates.
Re: Exactly WHY is my car hard to start when warm? [Re: 71383beep] #328198
05/28/09 07:46 PM
05/28/09 07:46 PM
Southaven, MS
BossRide Offline OP
BossRide  Offline OP
Southaven, MS
I
Is this separator to vent gas or fumes back to the tank?
My car had the charcoal canister and some vent tubes that run into a box-thing at the top of the tank. Can I run a separator to that?
How does that work?
The Blue Goose
Re: Exactly WHY is my car hard to start when warm? [Re: BossRide] #328199
08/30/09 12:46 PM
08/30/09 12:46 PM
Bump...
My '74 Fury 400 was a hot start and flooding nightmare when I went to a Thermoquad and Edelbrock intake. I swapped out the steel line for an insulated stainless mesh covered fuel line from the mechanical pump to the carb. Of course the composite body on the Thermoquad was designed to eliminate heat soak transfer to the fuel bowls but even with that, the big block generated so much heat that the only cure was to keep the fuel line cool. You not only cook the fuel in the bowls but the fuel gets cooked in the line from the pump to the carb. My only problem now is COLD starting! Always has been a bear... crank for 20 -30 seconds and then runs like cr*p for 4 minutes... IF it even starts.
Page 2 of 3 1 2 3
