Repop steering wheels? #3279874
01/02/25 06:13 AM
01/02/25 06:13 AM
tboomer Offline OP
tboomer  Offline OP
I am thinking about changing out the cracked steering wheel in my 69 GTS. I have looked at Classic Industries,Year One and Mike Ross at B/E/and A...Prices fluctuate quite a bit! They all carry the blue 67-69 steering wheel for my car. How many manufacturers are making these wheels? Thanks! Ted wave
Re: Repop steering wheels? [Re: tboomer] #3279882
01/02/25 08:17 AM
01/02/25 08:17 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Most likely one. And mine cracked after 6 years.
1969 Hemi Roadrunner 2nd owner
Re: Repop steering wheels? [Re: 69hemibeep] #3279949
01/02/25 12:15 PM
01/02/25 12:15 PM
tboomer Offline OP
tboomer  Offline OP
For what you pay for one they shouldn't crack! I wonder if they fade like the originals... shruggy
Re: Repop steering wheels? [Re: tboomer] #3279962
01/02/25 12:49 PM
01/02/25 12:49 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
There should be a really nice original one out there, at the repro price point, or less.
Re: Repop steering wheels? [Re: topside] #3279986
01/02/25 01:57 PM
01/02/25 01:57 PM
tboomer Offline OP
tboomer  Offline OP
Thanks! I will keep that in mind! wave
Re: Repop steering wheels? [Re: tboomer] #3279988
01/02/25 02:06 PM
01/02/25 02:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Hard plastic steering wheels with cracks can be glued and repainted, and should hold up for awhile if done correctly. If you own a car that nobody is ever likely to reproduce a steering wheel for it's an option to consider. Biggest expense is the primer and paint + paying someone to spray it if you can't.
https://youtu.be/4hchiLpoXWE?si=8AduaLQQdiDL_JSn
Re: Repop steering wheels? [Re: Neil] #3280019
01/02/25 04:16 PM
01/02/25 04:16 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I have done several steering wheel repair and repaint. It is a pretty simple straight forward process just a little time consuming. They have held up well.
If you cannot do it yourself there are companies out the that do it.
https://www.steeringwheelbob.com/
https://www.polyvance.com/Steering-...dRPAdJ1zQKLfdwg64LDsv80-PfN9PDjuiiTVeDan
http://www.garyssteeringwheel.com/
My Monster are real!
Living within your means makes life pretty easy.
Re: Repop steering wheels? [Re: 67vertman] #3280031
01/02/25 05:28 PM
01/02/25 05:28 PM
tboomer Offline OP
tboomer  Offline OP
Thanks for the links! Steering wheel Bob is pretty expensive!! wave
Re: Repop steering wheels? [Re: tboomer] #3280054
01/02/25 07:18 PM
01/02/25 07:18 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Yeah, that is why I did mine myself.
Remember those guys do SHOW quality restorations, I am a driver type of restoration guy. grin
Re: Repop steering wheels? [Re: tboomer] #3280156
01/03/25 09:37 AM
01/03/25 09:37 AM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
I have a repop black steering wheel for 8 years now. My 69 RR sits in a cold wood garage in the winter. I just take steering wheel off and bring into my house for the cold winter. I also have a wood steering wheel. it is stored in my home also.
Re: Repop steering wheels? [Re: TOMRR] #3280314
01/03/25 08:15 PM
01/03/25 08:15 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
Mine was NOS 20 plus years ago.
Still looks like new
Enjoy life today, It has an expiration date
Re: Repop steering wheels? [Re: tboomer] #3281118
01/07/25 10:54 AM
01/07/25 10:54 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
My Road Runner has a repo steering wheel in it. It hardly ever sees daylight, or high temps, and already has a hairline crack in it. It's not real noticeable, but it's there. If I were you, I would upgrade to a repo woodgrain wheel.
69 GTX 68 Road Runner
Re: Repop steering wheels? [Re: JERICOGTX] #3281156
01/07/25 12:59 PM
01/07/25 12:59 PM
tboomer Offline OP
tboomer  Offline OP
Thanks Jeff! You also keep your car in a heated garage don't you? I like the idea of a wood wheel and that may be worth looking into! Stay warm up there!! wave
Re: Repop steering wheels? [Re: tboomer] #3281177
01/07/25 02:12 PM
01/07/25 02:12 PM
AndyF Offline
AndyF  Offline
If you buy a repop steering wheel make sure that it comes with an ironclad return policy. The last repop I bought was splined wrong and the vendor wouldn't take it off. The wheel looked nice, but the spline was not cut correctly and I could not use it. So be careful. These wheels are all made in China and the Chinese make a lot of [censored] parts.
Re: Repop steering wheels? [Re: AndyF] #3281181
01/07/25 02:18 PM
01/07/25 02:18 PM
tboomer Offline OP
tboomer  Offline OP
Thanks Andy! That is good to know! I had a chance to buy an NOS one but it was black.. runaway
Re: Repop steering wheels? [Re: tboomer] #3281188
01/07/25 03:01 PM
01/07/25 03:01 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I bought a new repo plastic wheel for a Mustang years ago and it was a tad loose on the splines and eventually would work the nut loose. I think it did it because it was a manual steering car that required more effort to turn it. If it was power steering it might not have done that, or at least not as fast. I only had it for a week or so until I realized there was no fixing the issue. I returned it and used the money to buy an aftermarket Grant wood one that looked nice, but I could never get the horn button to work right.
I agree that if you buy a different wheel get it on the car and verify it's good before the return policy expires.
Re: Repop steering wheels? [Re: Neil] #3281204
01/07/25 03:49 PM
01/07/25 03:49 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
The wood grain wheels center ring aren't right as far as aligning the ring to the wheel. I had to drill and tap the holes to get the mounting ring to line up with the wheel. It was never going to be exact, and my OCD bothers me, but it will have to do. You would think that Quality Control would have caught it. But as far as I'm concerned there's none of that anymore, unfortunately.
Re: Repop steering wheels? [Re: gtx6970] #3281649
01/09/25 02:10 PM
01/09/25 02:10 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Ooooh love it, I need one like it only black. The guy I bought my 66 from (dead now) had got a blue one at sometime (looks nos) I have it on the 65 for now since that interior is blue. The black original one has a crack in the center and a little out of shape, I’ll try to fix it first myself, heat it up and it can be bent-formed easily back into shape. If it doesn’t fix I’ll pant the blue one.
Re: Repop steering wheels? [Re: cudaman1969] #3281842
01/10/25 11:29 AM
01/10/25 11:29 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I refinished mine.
It was cracked badly and missing a few chunks. I used the PC7 epoxy that Eastwood uses in their repair kits but I bought it at the hardware store.
The best advice I can give is bolt it to an engine stand so you can rotate it easily while painting.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Repop steering wheels? [Re: GY3] #3281862
01/10/25 12:36 PM
01/10/25 12:36 PM
tboomer Offline OP
tboomer  Offline OP
You did a nice job on that one! It looks great! up
