Re: 5.7 hemi swaps air cleaner choices?
[Re: Dabee]
#3281820
01/10/25 09:41 AM
01/10/25 09:41 AM
Posts: 4,114 Horsham, Pa.
Finoke
Horsham, Pa.
On the 64 Dart I’m currently building I moved the battery to the trunk. Built a filter / air box where the battery was with holes in the to allow fresh cool air in from the grill area. Nice!
[Re: topside]
#3281877
01/10/25 01:59 PM
01/10/25 01:59 PM
Posts: 3,612 Dandridge TN
Dabee
Dandridge TN
If that's the OP's intake style, a smaller battery - maybe moved down to top of the frame rail - might work. A buddy has a Braille battery in his Dart, and it's quite compact. No room down there. AC compressor is really close to the frame. I’m doing an early A body. Later As may have room. Here are a few photos of how tight the fit is.
[Re: Andrewh]
#3281929
01/10/25 04:44 PM
01/10/25 04:44 PM
Dabee
Dandridge TN
Not a crate motor. It’s out of a 2018 Charger cop car that was totaled. Engine has 38,000 miles on it. Only used the PS pump. Everything else is stock MOPAR.
[Re: Andrewh]
#3282008
01/11/25 12:32 AM
01/11/25 12:32 AM
Dabee
Dandridge TN
thanks, was just curious. They seem to make a ps pump that bolts in place for older car ps systems, but is marketed towards the crate motors. diy hemi also offers the ps pressure reducer for older cars. Yes I’ve seen the pressure reducers. Would have used one but there is no room for the electric PS pump.
[Re: Dabee]
#3282102
01/11/25 04:07 PM
01/11/25 04:07 PM
Posts: 1,252 rust belt
Moparite
rust belt
You can fabricate something from universal kit parts like this one.
[Re: Andrewh]
#3282204
01/12/25 10:52 AM
01/12/25 10:52 AM
Posts: 6,100 Salem
Grizzly
Moparts Proctologist
Salem
This setup doesn't take up battery space. Those side intakes look out of place on a Classic Car.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#3282209
01/12/25 11:28 AM
01/12/25 11:28 AM
Moparite
rust belt
I think you forgot the link to the kit. No, Link is the "this".
[Re: Moparite]
#3282213
01/12/25 11:41 AM
01/12/25 11:41 AM
Andrewh
I think you forgot the link to the kit. No, Link is the "this". ah thanks. as for the ram air cleaner, that would be nice, but the mopar crate ecu doesn't work with the truck engines for some reason. diy hemi shows some but only up to like 2015 I think. not sure why. I think I could figure out how to adapt the truck one to a regular air cleaner since it points straight up.
