Page 1 of 3 1 2 3
trick flow head exhaust valve leak #3280177
01/03/25 11:23 AM
01/03/25 11:23 AM
pa
gregcharger72 Offline OP
pa
I did a leak down test on my engine because the car slowed up a bit with out explanation, about a tenth. No mis-fires or any thing obvious just slower . It is a 440 topped with trick flow 270 heads. What I found was cylinder #1 and #8 have 30-35% leak down #4 has 15%. The rest of them are less than 5%. The air is escaping passed the exhaust valve. Tried tapping the valve with mallet and and adding a shot of oil with no change. I'm surprised with this as the engine only has 45 runs on it. Has anyone seen an issue like this with the trick flow heads? I don't have the heads off the engine yet, that is going to be my project this weekend so I can get a close up inspection of what is actually going on with the valves.
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3280202
01/03/25 12:31 PM
01/03/25 12:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Did you back off the rockers on those cylinders for the test ?
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3280215
01/03/25 01:08 PM
01/03/25 01:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You said the car slowed down, so I suspect the leakage wasn’t present initially.
Until the heads are removed and inspected it’s all speculation, but my guess is the valves got tagged and are now tweaked.
Re: trick flow head exhaust valve leak [Re: CSK] #3280216
01/03/25 01:09 PM
01/03/25 01:09 PM
pa
pa
Yes, I removed the rocker assemblies altogether.
Re: trick flow head exhaust valve leak [Re: fast68plymouth] #3280221
01/03/25 01:26 PM
01/03/25 01:26 PM
pa
pa
Yes , you are correct there was no leakage when the engine was assembled
That is what I am suspecting too. But why only the three valves? If I remember There was .090" piston to valve clearance. I used the clay method of checking clearance.
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3280223
01/03/25 01:42 PM
01/03/25 01:42 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Those valves might have gotten a little hang time and made light contact.
When my timing set came apart all the valves held water but when I pulled them 12 were bent. 4 survived. All the pistons had tiny eyebrows.
The tiny tolerances stacking up can make all the difference.
- Stu Harmon
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3280224
01/03/25 01:44 PM
01/03/25 01:44 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’ve inspected a few TF heads that had pretty minimal guide clearance.
If yours are like that, it might have pinched the valve a bit and allowed contact.
At high rpm, it doesn’t take much contact at all to tweak a hot exhaust valve.
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3280226
01/03/25 01:46 PM
01/03/25 01:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What rpm, and what valve spring?
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3280229
01/03/25 01:54 PM
01/03/25 01:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
You wouldn’t be the first person to get fooled by that.
Re: trick flow head exhaust valve leak [Re: fast68plymouth] #3280234
01/03/25 02:15 PM
01/03/25 02:15 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Quote
Please expound on the issue - Thx work
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: trick flow head exhaust valve leak [Re: Brad_Haak] #3280248
01/03/25 03:01 PM
01/03/25 03:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
Engine assembler used clay, came up with .060” intake clearance.
Breaks new Ferrea 6000 intake valve in burnout box of first pass.
Post blow up inspection reveals all intake valves making hard contact with pistons
I mock everything back up and manually measure with checking springs, with lash set.
I get “zero” clearance.
He kept good notes during assembly. The notes showed .060 , checked with clay.
I only use clay to check for radial clearance in the pocket.
Re: trick flow head exhaust valve leak [Re: fast68plymouth] #3280250
01/03/25 03:04 PM
01/03/25 03:04 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I watched this one a few weeks ago, and he goes over how the valve is not always where people think it is relative to the piston when it's near the top of the cylinder.
https://youtu.be/o_Oln_ik0vw?si=H-vxgkMQwL59kqsb
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3280288
01/03/25 06:23 PM
01/03/25 06:23 PM
Cab_Burge Online work
Cab_Burge  Online Work
Did you check all 16 valves for piston to valve clearances and valve to block clearances with checking springs? I do scope wrench up
Re: trick flow head exhaust valve leak [Re: fast68plymouth] #3280376
01/04/25 08:40 AM
01/04/25 08:40 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Then that guy was an idiot, he probably did it with a hydraulic lifter or something stupid like that.
I use both methods for different reasons and have run engines twice in the .050's(using checking springs) and we never hurt a thing. That being said I am not suggesting everyone go out and do it for the reasons above.
If the heads are off you should already know why and what happened. There should be contact marks and bent valves, next would be look at top of valves for x pattern wear for valve float, then stem clearance.
Re: trick flow head exhaust valve leak [Re: B1MAXX] #3280381
01/04/25 09:02 AM
01/04/25 09:02 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
My point being .090 with clay would be fine(clay always shows more) ., but now that I read the post he says I think it was .090
And yes after typing this I can see where .060 with clay could be trouble. Takes me a second. Clay usually adds about .030 or more. (deflection in valvetrain).
Re: trick flow head exhaust valve leak [Re: B1MAXX] #3280462
01/04/25 04:25 PM
01/04/25 04:25 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If the rocker shafts are off put a straightedge across the valve stems to see if they are all the same height?
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3280593
01/05/25 01:18 AM
01/05/25 01:18 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Greg how much did you pick up changing from the 240s to the 270s?
Re: trick flow head exhaust valve leak [Re: GTX MATT] #3280790
01/05/25 08:33 PM
01/05/25 08:33 PM
pa
pa
The car went from 10.7s to 10.4s and 124mph to 128mph with just the cylinder head change. I am quite happy with the results.
I got the heads off the engine and checked the valves and to my surprise the valves are not bent but the seats are deformed on the high leakage cylinders #1, 8, and 4. I can see light behind the valve. When checked with bluing dye there is a gap on the seat. I have no idea what could have caused this , I'm going to call trick flow tomorrow and see what they have to say.
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3280884
01/06/25 10:20 AM
01/06/25 10:20 AM
So. Burlington, Vt.
So. Burlington, Vt.
Time to put that warranty to the test.
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3281420
01/08/25 01:16 PM
01/08/25 01:16 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Thats great, it sounds like you hit your goal then. Did you keep the same carb and intake and port it or did you make a change?
Page 1 of 3 1 2 3
