Front Disc brake kit onto ‘70 Duster drum spindles #3276567
12/16/24 09:37 PM
12/16/24 09:37 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I know I’ve asked this before but can’t find it
Is there a set up that allows me to add discs while keep the existing drum spindles ?
Re: Front Disc brake kit onto ‘70 Duster drum spindles [Re: lostdog] #3276735
12/17/24 07:49 PM
12/17/24 07:49 PM
BDW Offline
BDW  Offline
Google Scarebird, I believe they have what you need
Try this
https://www.scarebird.com/shop/drt-...uth-a-body-with-10-inch-drums-3023#attr=
Re: Front Disc brake kit onto ‘70 Duster drum spindles [Re: BDW] #3276906
12/18/24 12:52 PM
12/18/24 12:52 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
the last time i heard of scarebird, they were going out of business, and only selling what they had on hand.
glad to see they are back in business. who revived them ?
beer
Re: Front Disc brake kit onto ‘70 Duster drum spindles [Re: moparx] #3278274
12/26/24 09:11 AM
12/26/24 09:11 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Wilwood has a kit for drum spindles.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Front Disc brake kit onto ‘70 Duster drum spindles [Re: moparmarks] #3279001
12/30/24 09:42 AM
12/30/24 09:42 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
This!
We put them on drum spindles on our B-body. The kit works great.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Front Disc brake kit onto ‘70 Duster drum spindles [Re: GY3] #3281318
01/08/25 12:41 AM
01/08/25 12:41 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Dr Diff sells a Viper kit that bolts to 73-76 Abody drum spindles and B and Ebody drum spindles. I don't know what is different with earlier A spindles.
https://www.doctordiff.com/viper-caliper-mounting-brackets-for-mopar-drum-knuckles.html
He also sells a B and Ebody drum spindle caliper bracket kit. Again I don't know what the exact difference is between the A and B spindles. Might be something as simple as bolt size or having to modify a bolt location.
https://www.doctordiff.com/front-disc-brake-caliper-brackets-for-11.75-on-drum-knuckles.html
I just noticed the non Viper kit is out of stock.
Kevin
Re: Front Disc brake kit onto ‘70 Duster drum spindles [Re: Twostick] #3281395
01/08/25 12:18 PM
01/08/25 12:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've done a couple disc swaps onto drum spindles on early Bs, one Scarebird, and another brand I don't recall.
Both went on fine, no problems, but the track width increased.
If the wheel/tire setup is already tight at the wheel opening, that can be an issue, and a spec you'll need to know.
