Re: 71 Cuda Paint Job Project
[Re: modelmakerinc]
#3276430
12/16/24 08:22 AM
12/16/24 08:22 AM
Posts: 2,495 west palm beach, florida
modelmakerinc
Moved to the pass side and tore into lower A-pillar. Found a little rot, much more solid than drivers side. CUT, BLAST,FAB,PREP,WELD,GRIND,SAND, DONE, NEXT....
[Re: modelmakerinc]
#3280888
01/06/25 11:30 AM
01/06/25 11:30 AM
modelmakerinc
The lower front inner corner looked like gobs of bubble gum  when i stripped the paint off. The door skin has a bunch of high spots (dings) made from inside, and plenty of areas that will need attention.
[Re: modelmakerinc]
#3280897
01/06/25 11:52 AM
01/06/25 11:52 AM
modelmakerinc
Then I find the next surprise.  not really too bad, I will cut out some of the inner structure to access the backside of these areas and repair accordingly. The structure will be welded back into position. I am getting excited to move into the body work phase to really get a good look at a fresh straight and proper base for painting.
[Re: topside]
#3297761
03/30/25 11:39 AM
03/30/25 11:39 AM
modelmakerinc
Passenger door received the patches needed, the inside and outside of the lower front had rust issues, I cut out the poor prior patch and the rust on the back side, created new patches and stiched them into place as always i treat the insde and backside of patches with rust inhibitor and coppercoat weld thru primer.
