Page 3 of 4 1 2 3 4
A Body Tubular Upper Control Arms [Re: moparts] #3283566
01/19/25 09:30 AM
01/19/25 09:30 AM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
Pair of A Body Tubular Upper Control Arms. Heim Joints and Ball Joints are perfect and ready to install. I had brackets welded on to attach travel limiters. These arms were in my car for a very brief period of time due to a change in plans. $350. rich1981@optonline.net SOLD
Re: For Sale - Wilson Manifolds spacer& adapter [Re: moparts] #3284317
01/22/25 04:11 PM
01/22/25 04:11 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Wilson Manifolds 4500 to 4150 low profile adapter.
$150
Wilson Manifolds 1.5 inch 4 hole tapered spacer for 4150 #004130
$150
ATI Super Damper #917467E BB Mopar. $225
Thanks Moparts
Buyer pays shipping
Re: For Sale - Wilson Manifolds spacer& adapter [Re: cudadon] #3284460
01/23/25 12:48 PM
01/23/25 12:48 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
A pair of Weld Magnum 2.0,15" fronts. Good condition. One wheel has a slight wobble. $500 + shipping for the pair.
[Linked Image][Linked Image][Linked Image][Linked Image]
Re: For Sale P4876548 water pump [Re: OUTLAWSSAA] #3284937
01/25/25 05:20 PM
01/25/25 05:20 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Mopar performance P4876548 high performance SB water pump.
Radiator connection tig welded to clear large fuel pump
$385 obo
thanks
rapid340@yahoo.com
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: For Sale Holley double pumper 4 bbl 4776 [Re: Rapid340] #3284938
01/25/25 05:42 PM
01/25/25 05:42 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Super nice Holley double pumper 4 bbl 4776 classic
These are around $750 (plus tax) new
$385
thanks
Re: For Sale Holley double pumper 4 bbl 4776 [Re: Rapid340] #3284940
01/25/25 06:12 PM
01/25/25 06:12 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
NOS Mopar Performance intake manifold
large port intake for use with W5 or similar heads.
$485
thanks
rapid340@yahoo.com
3' Hooker Aero Chamber Mufflers 21505HKR [Re: moparts] #3285448
01/27/25 09:43 PM
01/27/25 09:43 PM
Central Pa.
Cloned_Cuda Offline
Cloned_Cuda  Offline
Central Pa.
The mufflers are brand new and were out the boxes for fitting only.
$160 for the pair plus shipping or pick up.
AED 785 Vacuum Secondary Carbs ***SOLD*** [Re: Cloned_Cuda] #3285451
01/27/25 10:03 PM
01/27/25 10:03 PM
Central Pa.
Cloned_Cuda Offline
Cloned_Cuda  Offline
Central Pa.
These Carbs came with the engine I had built, and they are basically brand new with only engine run in time. They come with Carb Kits from AED and Quick Fuel Adjustable Secondaries.
$1380 for the pair plus shipping. ****SOLD****
US Car Tool Driveshaft Loop [Re: Cloned_Cuda] #3285454
01/27/25 10:22 PM
01/27/25 10:22 PM
Central Pa.
Cloned_Cuda Offline
Cloned_Cuda  Offline
Central Pa.
Driveshaft Loop was new, bolted it up on car, decided to do something different.
$70 plus shipping. **SOLD**
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3285457
01/27/25 10:31 PM
01/27/25 10:31 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Wilwood Brake Proportioning Valve===as you see it , just the valve.
$25 plus USPS shipping from Syracuse NY
Pay Pal only. Shipping will be USPS Flat Rate or being a smaller item maybe just first class.
RIP Monte Smith
Larry Morgan 500 cubic inch race motor parts [Re: moparts] #3286660
02/02/25 02:30 PM
02/02/25 02:30 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
2 Book Racing Carbs,1250-1500 CFM .,,,,,,,2500 OBO,,,,,,,,,,,,,,,,,,C&R racing radiator 22X13 with extras,,,,,750.00,,,,,,,,,,,,,,Complete dry sump oil system,1250.00,,,,,,Coan racing trans,,turbo 400,..4500 stall,,,,make offer,,,,all parts have about 2 hrs run time on them,,,,,COMPLETE motor setup,disassembled is available,,heads have damage,,block,pistons,ect good shape....St Louis area.....,,message me for pictures
.940 A body Torsion Bars / Firm Feeal [Re: moparts] #3286739
02/02/25 08:44 PM
02/02/25 08:44 PM
Mid-Michigan
GOREO Offline
GOREO  Offline
Mid-Michigan
.940 A body Torsion Bars for sale. New, never used. Purchased from Firm Feel a few years ago. Shown on their site as H/D - Police usage. (WR155) TBA3 . Listed for $500. $350 negatable plus shipping in their original box. Possible delivery assistance in Lower Michigan area. Contact me thru Moparts.
Indy 572-13 Top-end plus RB [Re: 70RR383] #3287150
02/04/25 02:09 PM
02/04/25 02:09 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I have a good pair of 572-13 heads, Jesel rockers kit and matching CFE 2x4150 sheet intake WITH linkage. Ti 2.3 coated intakes and Ti 1.88 exhaust. Set up made over 900HP on a 452 RB about 20 years ago. Need an exhaust valve job and springs. I can finish them to your liking for extra money. I was going to use these to make 1050HP with some tune-ups and bigger cam but have Predator heads now. These will push a 3200# car solid into the 8's as-is at a nice low rpm. (bracket) Chambers are about 66cc now and can be milled further. $3800. (Heads and Intake PENDING) I have two fresh and matched '950' HP carbs, tuned well on my last motor $1400 with package. 55mm 4/7 swap cam about .790' NET lift with heads $425 with package. New 572-13 CP 4.507" 1.2 C/H pistons with rings/ latest tricks $1800 with package. Good stuff! Heads were painted and I'll detail/clean them when purchased. Decks are good currently. Contact thru Moparts Thanks!
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3287956
02/07/25 05:20 PM
02/07/25 05:20 PM
Locomotion Offline
Locomotion  Offline
* 3" x 7/8" T-Bolt exhaust clamps from TTI kit made by Five Star MFG. 11 new, 1 used (Range approx. 3" - 3 1/4")
Bands are stainless, bolts are plated.
* 3' standard exhaust pipe clamps - 2 new
All for $55.00 including shipping within the 48 states from Florida 32117.
Sorry, no PayPal.
locomo@bellsouth.net
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3287993
02/07/25 08:35 PM
02/07/25 08:35 PM
Locomotion Offline
Locomotion  Offline
Lead Shot bags & loose - Race car ballast, fishing, scuba, etc.....
* Lead shot nylon bags - 2lb - 5lb range - 61lbs+ total
(Contrary to the tags, a few are off by as much as a pound, but total is 61lbs+)
$225.00 including Priority Flat Rate shipping within the 48 states from Florida 32117
(Would prefer to ship to a business address which may make it easier to deliver and accept at that weight.)
* Lead shot - loose in bag 23lbs+ total
$45.00 including Priority Flat Rate shipping within the 48 states.from Florida 32117
Sorry, No PayPal.
Milodon s/s pan [Re: moparts] #3288103
02/08/25 11:42 AM
02/08/25 11:42 AM
ky
68roadrunner Offline
ky
65 up b body milodon pan. Outer finish is pretty much wore off, inside is good. I never used it. But appears to not be any damage that would prevent good use. No pickup included. 9.375" deep inside. $300 plus shipping. Can send more pictures, it says my others are to big
Crane ductile rockers [Re: moparts] #3288106
02/08/25 11:47 AM
02/08/25 11:47 AM
ky
ky
SOLD SOLD:::::;::::Good rockers I used in the past and have been on the shelf. Some adjusters are different lengths where some got changed, could use some new locking nuts. Definitely usable if wanted to. $200 plus shipping SOLD SOLD
Big Block 727 rmvb [Re: 68roadrunner] #3288268
02/09/25 12:49 AM
02/09/25 12:49 AM
Chesterfield Twp. Mi.
John Burdine Offline
TCI Super Street Fighter big block Mopar transmission upgraded with CRT reverse manual valve body. Works perfect. TCI rates this unit up to 750 hp.
Pick up only in Warren Mi. NO SHIPPING
$1999
PM or John 586-222-2728 jonburdine@yahoo.com
Re: For Sale - Race Parts - 1st Quarter [Re: moparts] #3288922
02/11/25 11:38 PM
02/11/25 11:38 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Edelbrock #2920 Victor W2 Rectangular port intake manifold in good condition.
$250 + ship. *******SOLD*******
PM or GTX5877@yahoo.com
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
ARP Head stud kit for SB W-2 heads [Re: moparts] #3290221
02/17/25 11:58 PM
02/17/25 11:58 PM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
ARP Pro Series Cylinder Head Studs #144-4202 for SB Mopar with W-2 cylinder heads. 12 point nuts, washers and 8740 studs. Over $200 new. Sell for $100 + shipping from 56007
Private message
1974 VW Karman-Ghia
Page 3 of 4 1 2 3 4
