727 Shift Lever seal #3280560
01/04/25 09:22 PM
01/04/25 09:22 PM
Star Idaho
67vertman Offline OP
Star Idaho
Has anyone replaced the seal while the transmission is still in the vehicle? I have read that it can be done, just asking if anyone has done it. 79 Dodge w150, so there is plenty of clearance between the tunnel and trans.
My Monster are real!
Living within your means makes life pretty easy.
Re: 727 Shift Lever seal [Re: 67vertman] #3280565
01/04/25 09:40 PM
01/04/25 09:40 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Ive done it on my '66 Charger. Dropped the valve body and tapped it out from underneath. I know there's a special tool for it but I didn't have one.
Re: 727 Shift Lever seal [Re: bobby66] #3280567
01/04/25 09:47 PM
01/04/25 09:47 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Don't forget the kick down shaft seal.
Re: 727 Shift Lever seal [Re: bobby66] #3280568
01/04/25 09:51 PM
01/04/25 09:51 PM
Star Idaho
Star Idaho
I appreciate the input. Trying not to drop the pan again, but it is an option.
Re: 727 Shift Lever seal [Re: SALEM1912] #3280569
01/04/25 09:52 PM
01/04/25 09:52 PM
Star Idaho
Star Idaho
Luckily that one is no leaking. grin But with my luck at will start after I replace the shift lever one, so I may as well kill two birds with one service job.
Re: 727 Shift Lever seal [Re: 67vertman] #3280570
01/04/25 09:53 PM
01/04/25 09:53 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Vertman if I can find it I have that tool.
Re: 727 Shift Lever seal [Re: 67vertman] #3280575
01/04/25 10:21 PM
01/04/25 10:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yes. Miller C-3642
Re: 727 Shift Lever seal [Re: CMcAllister] #3280580
01/04/25 10:39 PM
01/04/25 10:39 PM
Star Idaho
Star Idaho
Originally Posted by CMcAllister
Yes. Miller C-3642
Nice. I will see if I can find one locally.
Re: 727 Shift Lever seal [Re: 67vertman] #3280598
01/05/25 05:38 AM
01/05/25 05:38 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
If you’re talking about the selector shaft seal, this is what I used.
Re: 727 Shift Lever seal [Re: Car Nut] #3280599
01/05/25 05:39 AM
01/05/25 05:39 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Re: 727 Shift Lever seal [Re: Car Nut] #3280614
01/05/25 08:59 AM
01/05/25 08:59 AM
Andrewh Offline
Andrewh  Offline
I used the tool as well, and as pictured above, I had to use a c-clamp to help reinstall.
I feel like I needed the c-clamp to help get a bite to pull as well.
so as long as you have room for it, you should be fine.
also I jacked up that side to get most of the fluid to the passenger side to reduce spillage.
but I seem to recall there is supposed to be an inner seal you can't get to from the outside, but I could be misremembering.
Re: 727 Shift Lever seal [Re: bobby66] #3280617
01/05/25 09:16 AM
01/05/25 09:16 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Just did one a couple months ago just as described above. Cleaned up the shaft a little before re-install. Replaced both seals.
Re: 727 Shift Lever seal [Re: 67vertman] #3280631
01/05/25 11:03 AM
01/05/25 11:03 AM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
There is an updated style of shift shaft seal. I have used it a couple of times now when the O.E. style leaked even when new. I don't have the part information handy, I always get it from my local trans guru. But if anyone was interested, I can call him tomorrow and get it.
It has always sealed my problem shift shaft seal leaks.
Master, again and still
Re: 727 Shift Lever seal [Re: DaveRS23] #3280644
01/05/25 11:44 AM
01/05/25 11:44 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Re: 727 Shift Lever seal [Re: mopowers] #3280652
01/05/25 12:15 PM
01/05/25 12:15 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
Ive done it both ways with and without the tool.
IMO, Its just easier to drop the valve body , especially cars with headers
Enjoy life today, It has an expiration date
Re: 727 Shift Lever seal [Re: gtx6970] #3280659
01/05/25 12:29 PM
01/05/25 12:29 PM
Kirkland, Washington
Pacnorthcuda Offline
I did it on a 77 Volare (904) without the tool. Just used a pick. It was a pain.
Re: 727 Shift Lever seal [Re: 67vertman] #3280668
01/05/25 12:37 PM
01/05/25 12:37 PM
Alberta
440_Offroader Offline
Alberta
I just changed both seals on my 79' W150 last weekend. I did however drop the pan and remove the valve body for this. I wanted to change fluid, filter, adjust the bands, and I don't have the special tool anyways. My truck had a 1/4" of dirt sitting around the shift lever ( probably why it was leaking), so I had to clean that as well. This was way easier with the valve body removed, and I didn't have to worry about dirt falling into the transmission. Installing the shift seal was easy as I just used a 1/2" nut and bolt with 2 washers. Just have to make sure the seal is square when starting to tighten the bolt. The kickdown seal is probably not as easy with the valve body in, as the c-clip might be a pain in the butt. It's super easy to change with the valve body out, and you can clean up the sealing surfaces then as well. Make sure the kick down seal goes in as it came out, as it almost looks like it should get installed the other way around.
There is lots of room on your truck to use the tool, however, if that's the way you're going to change it.
Re: 727 Shift Lever seal [Re: 440_Offroader] #3280704
01/05/25 01:36 PM
01/05/25 01:36 PM
Star Idaho
Star Idaho
Thanks for all the reply's and pictures. up
I now have a early spring project to do. wrench
I just did a transmission services, filter and fluid. I thought the pan gasket was causing my leaking problem as most the bolts where lose. But after the services, and it still leaking some, I chased it to the seal. I will attack it from the top
With everyone's input and guidance I feel confident I can do it.
Re: 727 Shift Lever seal [Re: 67vertman] #3283791
01/20/25 03:48 PM
01/20/25 03:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I used a small screwdriver to pry out and tapped new one in with a socket. Not much room.
Time just gets away from us
I`m here until I`m not
Re: 727 Shift Lever seal [Re: mopars4ever] #3283794
01/20/25 04:21 PM
01/20/25 04:21 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I tried that with one recently and I think I scratched the shaft service and was not able to pry it out. Probably original 1966.
When I dropped the valve body I cleaned up and polished the shaft. There was some seal wear there too so glad I did.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: 727 Shift Lever seal [Re: autoxcuda] #3283795
01/20/25 04:26 PM
01/20/25 04:26 PM
So Cal
So Cal
I polished both the selector and kickdown shafts.
Re: 727 Shift Lever seal [Re: autoxcuda] #3283797
01/20/25 04:33 PM
01/20/25 04:33 PM
So Cal
So Cal
make sure to take pictures of everything assembled before you take it apart.
Especially the selector comb and note what position it's in so you put it back in the same gear.
I put a little grease on the OD of the shaft so it didn't tear or mess up the seal. The seal had some grease in it already.
Re: 727 Shift Lever seal [Re: autoxcuda] #3283799
01/20/25 04:49 PM
01/20/25 04:49 PM
Star Idaho
Star Idaho
Thanks for the great pictures and tips. I am looking forward to starting it, but it needs to warm up first. snowblow
Re: 727 Shift Lever seal [Re: 67vertman] #3283826
01/20/25 06:43 PM
01/20/25 06:43 PM
So Cal
So Cal
I used this durring wheel to polish the surface.
Love these. I leave this on my bench grinder and a brillo flapper wheel.
I use it for trim prep for polishing. Speeds up taking out deeper scratches.
https://www.mscdirect.com/product/details/84524925
This is like my flapper wheel. I think there's less expensive versions out there
https://www.mscdirect.com/product/details/62000823
Re: 727 Shift Lever seal [Re: autoxcuda] #3283853
01/20/25 08:53 PM
01/20/25 08:53 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up This is where many fail and wonder why it still leaks whistling beer
Re: 727 Shift Lever seal [Re: autoxcuda] #3283856
01/20/25 09:02 PM
01/20/25 09:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have exactly the same setup but use a lathe with strips of various grit sandpaper. One would need to be careful not to create flat spots with the wheels or have the wheel grab it and sling it beer
Re: 727 Shift Lever seal [Re: 67vertman] #3283872
01/20/25 10:43 PM
01/20/25 10:43 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
You should have a mile of room to change it without removing the pan. I did one in my 70 Challenger by picking it out with a small straight screwdriver, then after polishing the shaft with a scotchbrite pad, I used a C clamp and a deep socket same size as the seal and pushed back in. It worked great!
Re: 727 Shift Lever seal [Re: TJP] #3284865
01/25/25 12:02 PM
01/25/25 12:02 PM
Alberta
Alberta
I had just replaced mine a while back and it still leaked. It wasn't leaking by the lip seal though. It was leaking between the transmission case and the seal body. I put some 515 loctite on the seal body this time. It has been dry for a couple weeks now.
