Re: enclosed trailer inside finishing [Re: Mr340] #3280746
01/05/25 03:30 PM
01/05/25 03:30 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Originally Posted by Mr340
To raise the car up so opening the door clears the escape door.
up up
Re: enclosed trailer inside finishing [Re: A12] #3280754
01/05/25 04:30 PM
01/05/25 04:30 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I know someone who bought a used trailer and he epoxy painted the trailer deck to clean up the appearance inside. Eventually the sticky rear tires started to pull bits of paint up on hot days so he just covered the tire track locations front to back with 2 strips of diamond plate.
Re: enclosed trailer inside finishing [Re: Mr340] #3281036
01/06/25 08:00 PM
01/06/25 08:00 PM
STL
cdstl Offline
cdstl  Offline
STL
Primed with Kilz, them battleship gray gloss on the floor and gloss white on the walls (oil base) and trusscore for the ceiling. I went with gloss for easy cleanup.
Did you make your ramps out of 2x4s?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: enclosed trailer inside finishing [Re: Mr340] #3281045
01/06/25 08:52 PM
01/06/25 08:52 PM
is Trusscore and where did you buy it?
Re: enclosed trailer inside finishing [Re: Cab_Burge] #3281198
01/07/25 03:31 PM
01/07/25 03:31 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Trusscore is a pvc based material used for walls and ceilings. I bought it at the local Wimsatt building materials store. It comes in 16”wide panels in lengths of 8’, 10, 12, and I think 20’. It’s not cheap but I liked the install method and some of the other features .
https://trusscore.com/
The ramps are two 2x10’s wide and 2 high. I needed a minimum is 2” rise so 1 row wouldn’t do it and I did both sides as a posed to just the driver side because I jus like the car sitting level
