Looking for a dented, bent, or rusty fender that has some fender lip area remaining. I don't need the whole fender, ideally just the section as show in the picture. I can use a bit less if thats all thats available. At this time, I'm not thinking it will matter if its left or right as I'm only using sections from this. This piece doesn't even have to be perfectly straight, but does need to be mostly intact in the designated area. If you have an old, fragged, rusty, or beat up fender you are going to throw away, I'll throw a few buck your way to cut out a piece and send it to me. PM me here if you have something that might work for this.
