Re: Headlight Upgrade
[Re: HealthServices]
#328048
07/03/09 05:54 PM
07/03/09 05:54 PM
Posts: 565 IA
landon1
IA
very nice! glad you put in the relays - i just installed relays, keeping my halogens and it made a HUGE improvement, so i'm sure upgrading the lamps would be even better when i get the chance
'71 Satellite Sebring 440
[Re: frank]
#328050
07/03/09 08:56 PM
07/03/09 08:56 PM
Posts: 1,822 Colorado
denfireguy
Colorado
You really do not need the relays. Halogen lamps draw far less current than the old tungsten filament bulbs for the same amount of light. We used to use landing lights in the high beams on four light systems. They were 110 Watts at 12.6 Volts. A 55 Watt halogen draws half the current and puts out just as much light. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#328051
07/03/09 09:04 PM
07/03/09 09:04 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
The problem is these old cars do not get full battery voltage at the headlights. That's why the relay upgrade works.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: frank]
#328052
07/04/09 12:30 PM
07/04/09 12:30 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
Nice install. I'm going to do the same. The bulbs you received, were they an H1 and and H4 bulb?? What is the difference between H1 and H4? One more question, where did you get your relays from? Thanks
I couldn't say what the actual difference is, except that the H4 is for the low beams and H1 is for the high. The lenses are different, the H1 is more clear than the H4. bulbs for the H4 also are dual filliment as they change when the high beams are activated.
I got my relays from http://www.bmotorsports.com/shop/product_info.php/products_id/504
seemed to have the best price. Got all wire from West Marine, got the noninsulated terminals from
http://www.wiringproducts.com/index1.html
#328054
07/04/09 03:24 PM
07/04/09 03:24 PM
They never did, when new. I put relays in my Roadrunner back in the '70's, and could see a difference with stock headlamps. This was before the sealed beam halogens came out. I never ran Lucas or Hellas's but I sure used the hell out of 4537's!!!!
