Page 2 of 3 1 2 3
Re: trick flow head exhaust valve leak [Re: GTX MATT] #3281505
01/08/25 06:07 PM
01/08/25 06:07 PM
pa
gregcharger72 Offline OP
pa
Originally Posted by GTX MATT
Thats great, it sounds like you hit your goal then. Did you keep the same carb and intake and port it or did you make a change?
I changed the manifold to the matching trick flow max wedge port manifold and used the same carb. I added an adaptor / spacer under the carb.
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3281621
01/09/25 10:44 AM
01/09/25 10:44 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Has a plan for the repair been decided on yet?
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3281627
01/09/25 12:42 PM
01/09/25 12:42 PM
S.E. Michigan
TruPerformance Offline
S.E. Michigan
How short of a adapter/spacer were you able to find? I am looking for this solution right now, due to limited clearance... I have a scoop, but not very tall. So I am concerned about my options in this scenario. thanks in advance.
1963 Belvedere (mine)
1969 Roadrunner (wife's)
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3281629
01/09/25 12:47 PM
01/09/25 12:47 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Greg how much did you pick up changing from the 240s to the 270s?
The car went from 10.7s to 10.4s and 124mph to 128mph with just the cylinder head change. I am quite happy with the results.
I got the heads off the engine and checked the valves and to my surprise the valves are not bent but the seats are deformed on the high leakage cylinders #1, 8, and 4. I can see light behind the valve. When checked with bluing dye there is a gap on the seat. I have no idea what could have caused this , I'm going to call trick flow tomorrow and see what they have to say.
That's a nice pickup. Whats the rest of the engine combo?
Re: trick flow head exhaust valve leak [Re: fast68plymouth] #3281648
01/09/25 02:03 PM
01/09/25 02:03 PM
pa
pa
I called Trick Flow customer service. I was asked to write an email letter explaining my issue with the heads, the test I've done and to send pictures of the heads, engine and car. Trick flow wanted see and inspect the heads, they sent call tags for the heads. The heads are now in their possession and I am waiting on the verdict. Their customer service has been reasonable and so far helpful.
Re: trick flow head exhaust valve leak [Re: TruPerformance] #3281660
01/09/25 02:44 PM
01/09/25 02:44 PM
pa
pa
The spacer I'm using came from AR Engineering, I bought it from Brad H here on Moparts, he was kind enough to sell me his because AR Engineering doesn't make it any more. Its 1/2 inch tall and has a taper to the bores kind of like a shear plate. It seems to work well. My carburetor has a dual pattern base plate.
Re: trick flow head exhaust valve leak [Re: DusterKid] #3281705
01/09/25 09:02 PM
01/09/25 09:02 PM
pa
pa
It's a .030 over , stock stroke 440. 11.7 to 1 cr. 260/264 Hughes engine cam. 1.6 rockers. 2" hooker headers .
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3281710
01/09/25 09:20 PM
01/09/25 09:20 PM
S.E. Michigan
S.E. Michigan
In Response To: "Re: trick flow head exhaust valve leak"
gregcharger72
Thanks. I know of that spacer, but unfortunately it is not available anymore. I am trying to find something that will be comparable to that setup. Haven’t had any luck yet. Thanks again and good luck with the TF warranty, I hope they do right by you.
Re: trick flow head exhaust valve leak [Re: TruPerformance] #3281729
01/09/25 10:56 PM
01/09/25 10:56 PM
AndyF Offline
AndyF  Offline
I'll sell the design rights and the CAD file to someone who wants to make those low profile spacers.
Re: trick flow head exhaust valve leak [Re: AndyF] #3282194
01/12/25 09:56 AM
01/12/25 09:56 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Yep, I had Andy's last one that I purchased when I was a still interested in an MP RB 4500 intake to test with a 4150 carb. The OP needed one about the same time that I gave up finding an intake that wasn't already hacked on or way overpriced (IMO). Nice part, which what I've come to expect from Andy's products.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3282469
01/13/25 01:52 PM
01/13/25 01:52 PM
NC
440Jim Offline
440Jim  Offline
NC
Did the top of the pistons show either contact or a pattern in the carbon at the valve? Can you post a picture ?
Re: trick flow head exhaust valve leak [Re: 440Jim] #3282483
01/13/25 03:21 PM
01/13/25 03:21 PM
pa
pa
This is cylinder #1. The one with the most leakage. There is no sign of contact that I can see.
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3282484
01/13/25 03:35 PM
01/13/25 03:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Hmmm, what does that leave as a cause ? Inconsistent or insufficient seat harness ?
Re: trick flow head exhaust valve leak [Re: topside] #3282569
01/14/25 12:17 AM
01/14/25 12:17 AM
Sounds like defective heads to me work twocents
Re: trick flow head exhaust valve leak [Re: Cab_Burge] #3283045
01/16/25 01:47 PM
01/16/25 01:47 PM
pa
pa
Talked with Trick Flow today and spent some time answering questions about my combination in an attempt to figure out what happened to the heads to cause some of the exhaust valves to leak.
Bottom line is my heads are getting fixed and should have them back in a week or two. I'm pleased with their customer service so far it's been easy dealing with them.
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3283048
01/16/25 01:54 PM
01/16/25 01:54 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Awesome! up
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3283049
01/16/25 01:57 PM
01/16/25 01:57 PM
That is good to hear up Thanks for posting your results.
I'm thinking of buying a set of their 270 soon work shruggy
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3283058
01/16/25 02:19 PM
01/16/25 02:19 PM
So. Burlington, Vt.
So. Burlington, Vt.
Did TF concur that there was an issue with the seat sealing surfaces?
Re: trick flow head exhaust valve leak [Re: fast68plymouth] #3283061
01/16/25 02:32 PM
01/16/25 02:32 PM
pa
pa
He didn't say, just told me that the heads were being fixed. He did comment that they were were not that bad, but from the line of questions I was asked, such as shift rpm , spark plugs used , total ign timing, type of fuel used, rocker arm used, cam part# and who made it, that there was definitely an issue.
Re: trick flow head exhaust valve leak [Re: gregcharger72] #3283064
01/16/25 02:39 PM
01/16/25 02:39 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
It's highly commendable they are fixing them for you. Most places I don't think would do much to help you once their parts have been installed and used.
Page 2 of 3 1 2 3
