Re: Any way to use ignition key for trunk?
[Re: Locomotion]
#3280020
01/02/25 04:18 PM
01/02/25 04:18 PM
Posts: 5,792 Star Idaho
67vertman
Star Idaho
Are there any "Old School" key and lock places near you? We had one in my hometown and he did re-keying of old locks.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3280043
01/02/25 06:15 PM
01/02/25 06:15 PM
Posts: 6,581 ohio
ruderunner
ohio
I've heard but never confirmed that cop cars often had a single key setup.
A 194 blank fits many many years of Mopar.
Angry white pureblood male
[Re: ruderunner]
#3280047
01/02/25 06:26 PM
01/02/25 06:26 PM
Posts: 4,382 Morrow, OH
markz528
Morrow, OH
The blanks are different so you would need to be creative.
[Re: ruderunner]
#3280048
01/02/25 06:28 PM
01/02/25 06:28 PM
Posts: 5,009 new berlin wisconsin
Mr T2U
. this is correct. if i remember correctly they used the round trunk key for the 1 key setup.
perception is 90% of reality
[Re: BDW]
#3280053
01/02/25 06:52 PM
01/02/25 06:52 PM
Posts: 6,651 nowhere
Sniper
nowhere
70 E-body, but it's same issue on all of them. I see the key blank between ignition and trunk is different. Any way to mod, or swap a different cylinder for the trunk so the same key can be used? Heard it was a patent issue with Toyota that forced them to use 2 keys. At what point did they switch to 1, maybe that year cylinder would work?
Thx Doubtful Toyota had anything to do with this. More likely it's a valet concern. They can have the key for the ignition and door, but not the trunk. As mentioned, cop cars had that as an option. IF you can find a vehicle that uses the same trunk lock cylinder as your E body AND it had a cop car option you MIGHT be able to find an NOS cop car trunk lock, get it rekeyed to match your other locks and there you go.
[Re: BDW]
#3280055
01/02/25 07:22 PM
01/02/25 07:22 PM
Posts: 1,771 Phila
PhillyRag
Phila
Thx A door lock will go into a 70 opening, since same size & retainer will work. But not 72 & newer, larger lock. BUT, trunk locks have the return spring at the rear, door locks no. Maybe a 70/71 cuda trunk setup could be swapped/improvised to work. Ign/door & trunk keys all have different profile shapes thru the years, and can be swapped/inserted. Probably not worth the work unless for some reason necessary.
[Re: Mr T2U]
#3280081
01/02/25 08:35 PM
01/02/25 08:35 PM
Posts: 4,996 Florida
BDW
. this is correct. if i remember correctly they used the round trunk key for the 1 key setup. This sounds like the only possibility, but the trunk blank / cylinder would need to be the same as the ignition key. Anybody know what year / model cop trunk cylinder I would need to look for?
[Re: BDW]
#3280091
01/02/25 09:17 PM
01/02/25 09:17 PM
Posts: 2,517 ILLINOIS
volaredon
ILLINOIS
Thx Toyota? I doubt that. Mopar has had 2 keys for years in the 60s-70s -80s. One key for doors and ignition and the other for the trunk and glove box. That started way before Toyota had much of a presence here in the states. Ford and gm had the ignition key (only) with the other one fitting everything else on their cars at the same time. At least with Mopar they made the doors and ignition the same
[Re: volaredon]
#3280125
01/03/25 12:45 AM
01/03/25 12:45 AM
Posts: 5,171 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Just thinking outside the box here but why not just remove the small side cover on the lock and empty it out... Any key that turns it will open it... As long as no one knows that you should be fine...
...FAFO...
[Re: volaredon]
#3280126
01/03/25 12:55 AM
01/03/25 12:55 AM
Posts: 4,214 Canada -- Posts: 4034 -Registe...
5thAve
Thx Toyota? I doubt that. Mopar has had 2 keys for years in the 60s-70s -80s. One key for doors and ignition and the other for the trunk and glove box. That started way before Toyota had much of a presence here in the states. Ford and gm had the ignition key (only) with the other one fitting everything else on their cars at the same time. At least with Mopar they made the doors and ignition the same Yeah it had nothing to do with Toyota. It was the standard for decades for various makes to have 2 keys so that if you had to leave your key with someone you could keep the glove box and trunk secure. I don't know when things changed but well into the 2000s they still did something similar with the valet key that could do everything the normal one could except open the glove box and trunk.
[Re: A12]
#3280140
01/03/25 03:36 AM
01/03/25 03:36 AM
Posts: 21,790 N.E. OHIO, USA
A12
N.E. OHIO, USA
Another reason I think this is to prevent you or someone from mistakenly or accidentally locking your trunk key in the trunk is they also made the driver/s door so you could only lock it from the outside with the ignition key. Love/hate with that driver's door can only be locked from the outside with the ignition key. But then again you can only blame yourself with a Chevy, Ford, etc., if you lock your ignition key inside the car, Oh and also the separate trunk key was great for valet parking so no one but the trunk key holder could get into the trunk where the wife liked keeping her purse, etc.,
[Re: A12]
#3280141
01/03/25 05:26 AM
01/03/25 05:26 AM
Posts: 10,407 A Red State
SNK-EYZ
A Red State
Another reason I think this is to prevent you or someone from mistakenly or accidentally locking your trunk key in the trunk is they also made the driver/s door so you could only lock it from the outside with the ignition key. Love/hate with that driver's door can only be locked from the outside with the ignition key. But then again you can only blame yourself with a Chevy, Ford, etc., if you lock your ignition key inside the car, Oh and also the separate trunk key was great for valet parking so no one but the trunk key holder could get into the trunk where the wife liked keeping her purse, etc., That ended in 1971 from what I know. At least on E-Bodies starting in 1971 you can push the door lock lever down and close the door and the car is locked. I'm pretty sure it was done on all model Mopars starting in 71.
[Re: skicker]
#3280146
01/03/25 07:19 AM
01/03/25 07:19 AM
BDW
Just thinking outside the box here but why not just remove the small side cover on the lock and empty it out... Any key that turns it will open it... As long as no one knows that you should be fine... Not a bad idea. I did try and put the ignition key in the trunk cylinder, and that's when I looked closer and saw the blanks are different.
[Re: 5thAve]
#3280192
01/03/25 12:04 PM
01/03/25 12:04 PM
A12
N.E. OHIO, USA
Yeah it had nothing to do with Toyota. It was the standard for decades for various makes to have 2 keys so that if you had to leave your key with someone you could keep the glove box and trunk secure. I think it was so if you mistakenly locked your (trunk) key in the trunk you would still have an ignition key to drive home and hopefully have a spare at home. But EVERYONE had the trunk and ignition on one key ring or key fob DUH that's a too smart engineer thinking as they would do the two key ring key fob. Makes me wonder if the dealerships were ever instructed to give the owners the keys at purchase on two key rings. Probably there's a dealer new car delivery packet with the keys on separate key rings. So having a different key for the glove box is so you don't accidentally lock the key in there? Hmmmmmm maybe also valet resistant? And don't forget the center console..........and being able to lock and unlock them with another key while the ignition key is in and running the engine/driving.
