1993 d series repop body patch panels?
#3279380
12/31/24 05:32 PM
12/31/24 05:32 PM
Posts: 7,610 Minnesota
Hemi_Joel
Minnesota
Hi, is anyone making new body panels or patch panels for the 93 D series? I'm thinking maybe I should replace the rocker panels and cab corners on my 93 D350 extended cab. Thanks, and happy New Year!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: 1993 d series repop body panels?
[Re: birdtracker]
#3280051
01/02/25 06:33 PM
01/02/25 06:33 PM
Hemi_Joel
Minnesota
Thanks for the help. So far though, I'm only seeing standard cab parts, none for the extended cab. Maybe they don't make them anymore?
[Re: Hemi_Joel]
#3280336
01/03/25 11:10 PM
01/03/25 11:10 PM
Posts: 11,020 Freeport IL USA
poorboy
Freeport IL USA
Thanks for the help. So far though, I'm only seeing standard cab parts, none for the extended cab. Maybe they don't make them anymore? I didn't know there was a difference in the cab mounts between a standard cab ans an extended cab. The front cab mounts should be the same, and I thought that the rear cab mount body support channel on the extended cabs was just moved more towards the rear of the cab?
[Re: poorboy]
#3280348
01/04/25 12:49 AM
01/04/25 12:49 AM
Hemi_Joel
Minnesota
Thanks for the help. So far though, I'm only seeing standard cab parts, none for the extended cab. Maybe they don't make them anymore? I didn't know there was a difference in the cab mounts between a standard cab ans an extended cab. The front cab mounts should be the same, and I thought that the rear cab mount body support channel on the extended cabs was just moved more towards the rear of the cab? I'm just looking for the rocker panels and cab corners. Fortunately, I don't need cab mounts.
[Re: Hemi_Joel]
#3280382
01/04/25 09:09 AM
01/04/25 09:09 AM
Posts: 1,224 rust belt
Moparite
rust belt
I'm only seeing standard cab parts, none for the extended cab. Maybe they don't make them anymore? Extended cab trucks were few and far between so don't expect parts for them.
