Page 2 of 3 1 2 3
Re: 727 trans explosion protection [Re: A39Coronet] #3278615
12/28/24 08:47 AM
12/28/24 08:47 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted by A39Coronet
I'd switch to a th400 or powerglide before I'd run a blanket or shield again. Blanket is a nightmare with melted straps and acting like a sponge, and the shield is pricey. I'd do the above with a billet drum and proper VB on anything that's going to rev.
5000 RPM has the potential to grenade a stock drum.
Kevin
Re: 727 trans explosion protection [Re: dvw] #3278656
12/28/24 11:41 AM
12/28/24 11:41 AM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
My thoughts; A Turbo 400 can spit a drum as well.
Yep.
Re: 727 trans explosion protection [Re: CMcAllister] #3278765
12/29/24 02:18 AM
12/29/24 02:18 AM
CA
crackedback Offline
crackedback  Offline
CA
Originally Posted by CMcAllister
Buddy of mine had a healthy small block, 904 combo in a Dart. Broke the 8 3/4 under power. Fixed the rear and was out driving the car around. Had a very slight vibration. Called me and said he was going to the track and whether I though it would be OK. I told him to take it out and bring it to me. He said it drives fine. I said bring it to me.
Half the springs were crushed and the rollers were loose in the thing. Half the rollers were functioning well enough to drive the car around. Would not have survived the first hit. No idea what valve body was in it other than it was a manual.
A failed roller clutch doesn't necessarily mean the car won't move. And in a 727 with a stock drum, it would be a ticking bomb.
You have to engine RPM way beyond what most decent street small blocks will turn to get a 904 drum to explode. Still better to fix it than risk other stuff falling apart with a vibration.
A stock 383 and 440 will rpm enough to get a 727 to grenade.
Re: 727 trans explosion protection [Re: A727Tflite] #3278895
12/29/24 05:37 PM
12/29/24 05:37 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Originally Posted by A727Tflite
Have the trans properly built, install an aftermarket billet front clutch drum, a bolt in over running clutch helps. A low band apply valve body offers a tad more help in preventing over run clutch roller spit back.
A shield or blanket is “suspenders on a belt” after doing the above.
And of course, drive the car correctly.
I haven't read all the comments but This is sound advice , the only thing I would add is to use a Super Sprag , A+A or whomever else is making it , I think it's coan ??... it has more rollers and it's very hard to damage , if at all. A standard bolt in is for repairing stock sprags that are loose in the case , they do nothing to stop the rollers from rolling over . A billet drum won't explode , at worst it will deform from tests I have seen so it not going bang is what you are really after.
Mainstream Media is the new Pravda
Re: 727 trans explosion protection [Re: crackedback] #3278907
12/29/24 06:58 PM
12/29/24 06:58 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never heard of a 904 coming apart like that. Not saying it never happened.
Re: 727 trans explosion protection [Re: CMcAllister] #3278908
12/29/24 07:05 PM
12/29/24 07:05 PM
CA
crackedback Offline
crackedback  Offline
CA
I've never seen a 904 explode. RPM required is WAY outside the realm of a street SB engine. Seen lots of cracked and fractured drums. Never an outright explosion from an overrun situation. The fix it comment was regarding the sprag.
JMO, those pricey 904 pricey parts are not worth the $ for someone that is bracket racing and not chasing every .01 on the slip.
Re: 727 trans explosion protection [Re: John_Kunkel] #3278910
12/29/24 07:13 PM
12/29/24 07:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Yep.
And a TH350.
We were at a backwoods 1/8 mile one day when they were having a Quick 8 race or something. Guy in a Camaro, blown alcohol big block, did a giant John Force burnout. backs up and stages, leaves, makes it about 3' and explodes the transmission. All of it. No shield or blanket. Oil and shards of metal out past the 60. Gets the car stopped, rolls out of it and rolls around on the track until someone gathers him up. He got a ride in the ambulance, after it showed up.
We went out to look at the mess. The only recognizable piece I saw....
Re: 727 trans explosion protection [Re: JohnRR] #3278954
12/29/24 11:15 PM
12/29/24 11:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
As mentioned in post #9. My car has damaged two Ultimate sprags. The Ultimate uses standard Ford C-6 rollers and springs. With a reduced diameter 727 inner race. Custom outer race.
Doug
Re: 727 trans explosion protection [Re: dvw] #3279026
12/30/24 11:07 AM
12/30/24 11:07 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Doug
Thanks Doug,sorry to hear that you broke them twice. fan I'll log into memory for future reference.
Re: 727 trans explosion protection [Re: JohnRR] #3279029
12/30/24 11:19 AM
12/30/24 11:19 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Is there a difference between the Coan Super Sprag and the A&A Ultimate? I used a Coan in the last 727 I did and haven't had any issues with it.
Re: 727 trans explosion protection [Re: JohnRR] #3279099
12/30/24 03:09 PM
12/30/24 03:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Still using them. I thought I new the issue with the first failure. Then it broke another. Tried one more fix. We'll see if that does it. They are stronger for sure. That being said. The car ran the stock part for 7 years w/o low band apply with zero failure. They all used the standard C-6 roller assy. https://www.ebay.com/itm/141876161734
Doug
Re: 727 trans explosion protection [Re: dvw] #3279123
12/30/24 04:24 PM
12/30/24 04:24 PM
A727Tflite Offline
A727Tflite  Offline
If you can install the ORC rollers without springs and the rollers can move away from being perpendicular you can fail the ORC.
Period.
Look at the difference in movement from vertical between the production and Ultimate and you will see what I am talking about.
Verticals means you are resting the main case on the back looking inside the case.
Re: 727 trans explosion protection [Re: dvw] #3279198
12/30/24 08:30 PM
12/30/24 08:30 PM
Minn
SportF Offline
SportF  Offline
Minn
I don't think it matters what kind of sprague you. put it it if you rip some gears out. The sprague goes when it looses the load then gets hit. In other words, you rip some gears out and the engine revs then you roll forward a little and the pinion hits more gears with the engine revs, that's when it goes. There isn't a sprague or case on the planet that will take that inertia hit.
Several years ago at BG a NSS racer did exactly this and the stationary part of the sprague cocked in its bore, and that was that. And that was a super dupper sprague. Sprague was still good, but not the case.
Re: 727 trans explosion protection [Re: SportF] #3279206
12/30/24 08:54 PM
12/30/24 08:54 PM
A727Tflite Offline
A727Tflite  Offline
It does matter.
Much easier to damage the conventional ORC rollers and springs than an Ultimate.
Breaking the cam/breaking it loose in the case is usually a secondary failure.
Re: 727 trans explosion protection [Re: A727Tflite] #3279273
12/31/24 08:34 AM
12/31/24 08:34 AM
PA
moparacer Offline
moparacer  Offline
PA
Never seen or heard of that either. I had a sprag failure in a 904 years ago. Car just revved up and didn't move. No explosion.
The drum is considerably smaller and lighter in a 904 and it will take the RPM without exploding.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Re: 727 trans explosion protection [Re: moparacer] #3279297
12/31/24 10:45 AM
12/31/24 10:45 AM
an8sec70cuda Offline
I use the CSR carbon shield on my cuda. I used to run a blanket, but switched to the shield b/c of the NHRA rules and it's the only thing that will fit w/o hacking up the trans tunnel.
I had a drum explode in 2008 and it made a huge mess, but the shield did its job. It did destroy the shield, but it kept the explosion contained.
This was no minor explosion either. The case, pan, and valvebody were in pieces and swept up off the starting line. Every bellhousing bolt had a small piece of case still attached to it.
Crawled under the car and you could see the clutches just hanging on the shafts. A piece of the drum dented and cracked a header tube, blew the whole floor pan upward, stopped when it hit the brake pedal.
After that I put billet drums in the new trans and my backup.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: 727 trans explosion protection [Re: an8sec70cuda] #3279328
12/31/24 01:27 PM
12/31/24 01:27 PM
Puyallup, WA
LemonWedge Offline
LemonWedge  Offline
Puyallup, WA
Glad to hear your shield did its job with the explosion. I hear over and over again that a carbon-fiber shield is no match for explosion shrapnel (??).
A few years ago I busted my 8-3/4 for the last time. Happened right at the hit, sheered the pinion right in half and turned the whole thing into a gravel box. I tore into the transmission after that and found everything to be perfectly fine. Foot was to the floor, coming off the two-step. I got out of it immediately, but the carnage of that incident was exactly the type that should have damaged the sprag. Somehow it was fine. Just lucky I guess. I installed a blanket after that incident feeling as though I was on borrowed time with the stock drum. Car also got a D60 after that.
I’m now in the process of installing a Transbrake in my 727. I’m going with a CRT unit. After a lengthy discussion with John, he convinced me that it was past time for a billet steel drum. I was going to go with one of his units, but then just last week out of the blue I found a brand new A&A Ultimate Steel Drum complete with retainer and 15-spring piston on eBay for a fraction of the retail price tag. I couldn’t hit the “buy it now” button fast enough on that deal. So I will now be running a bolt in sprag, a steel drum, and an LBA valvebody.
At the same time as this project, I’m also on a campaign to carve some weight out of my street-heavy sled. I weighed the blanket just last night…. 9lbs-3oz. Not as bad as I would have thought. I think it’s worth its weight. But it is also a giant PIA! I take pride in my car always looking clean and well maintained at the track. This thing never fails to hang down like some slob with his pants sagging off his ass. I don’t know how many times someone has come up to me at the track and said “there’s something hanging down under your car”. I’ll get under there with zip ties and duct tape, but the thing just always finds a way to hang down. Drives me nuts. Not to mention it also makes it nearly impossible to access the linkage, or numerous other areas.
So I’m on the fence as to whether or not it will be re-installed when the transmission goes back into the car.
Back to the original discussion…. I feel pretty fortunate to have been racing with a stock drum as long as I have with no issues, and feel really good about having that worry behind me now. FWIW: I start my burnout just out of the water in 1st gear, but immediately go to second as soon as the tires turn and hold it in 2nd at about 4500 until I feel it start to tug. Let off and roll forward to a stop. Straight back to 1st gear then let it roll forward in 1st to the beams. I try to do as small a burnout as possible, as I don’t think a big smokey burnout does anything for you with todays tire technology, and mostly I’m cheap and don’t like to have to buy tires.
LemonWedge - Street heavy / Strip ready.
468” Lowdeck MaxWedge - 10.42 @ 128
Re: 727 trans explosion protection [Re: LemonWedge] #3279349
12/31/24 02:54 PM
12/31/24 02:54 PM
A727Tflite Offline
A727Tflite  Offline
Try installing the blanket and retaining it to the tunnel with a large piece of sheet metal that is of the same shape as the tunnel sandwiching the blanket.
Then install the trans. What I do then is install a shield that attaches to the pan bolts and is radiused up sort of like a a half tube, runs from the front cooler line fitting back to just in front of the rear cooler line. That keeps the blanket off the linkage. Both these methods helps the airflow around the trans.
Add as many belts needed to “keep your pants up”.
Re: 727 trans explosion protection [Re: an8sec70cuda] #3279350
12/31/24 02:55 PM
12/31/24 02:55 PM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree
Re: 727 trans explosion protection [Re: racerx] #3279356
12/31/24 03:26 PM
12/31/24 03:26 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I still need to pull my trans to have Doug build it for me, but I ended up with a billet drum and the Coan sprag in addition to a CSR shield and Griner LBA valve body. Figured even if the Coan C6 sprag breaks, between it, the drum and the shield, it isn't going to send anything through the floorpan.
Page 2 of 3 1 2 3
