Slant 6 Forklift ignition question #3278545
12/27/24 05:57 PM
12/27/24 05:57 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
I have a 1970's Yale forklift with a slant 6 engine running on propane and points ignition that cranks forever to start when cold but starts what I think is normal once it's warmed up. This forklift doesn't have a Mopar starter so it doesn't have the ignition output on the starter solenoid, it has a Ford type of starter solenoid. I replaced the propane system and shot it with starting fluid to see if it's a fuel problem, I really don't think it is. If I temporarily jump a wire from the battery to the positive side of the coil it starts much faster. I only have 1 wire going to the positive side of the coil and one on the output side of the ballast. The ignition looks like a universal replacement and it doesn't have an "IGN 2" output on it.
Does anybody know of a universal ignition switch with the "IGN 2 " output or a different way to wire this ignition system to temporarily get 12 volts to the coil for startup so I don't need the "IGN2" ?
Re: Slant 6 Forklift ignition question [Re: Boise Chall] #3278559
12/27/24 07:14 PM
12/27/24 07:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yale has an online presence, and service manuals appear available from various sources.
I had a universal ignition switch in my drag car with Ign 1 and 2 positions - it has been there forever, and still is, but don't recall the brand name.
FWIW, I'm in SW Boise on the Meridian border, if you need wiring stuff or whatever.
Re: Slant 6 Forklift ignition question [Re: topside] #3278573
12/27/24 09:37 PM
12/27/24 09:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Do what I did when I converted my 51 Plymouth to 12v.
The original starter solenoid was a "Ford" type. Though how it got that nam eis beyond me since Mopar was using them forever.
Anyway, the original solenoid was a three stud 6v unit, I replaced it with a four stud one, the fourth stud being labeled I, as in ignition, that is only hot in start and I wired that to the coil + to bypass the ballast in start.
Re: Slant 6 Forklift ignition question [Re: Boise Chall] #3278603
12/28/24 07:16 AM
12/28/24 07:16 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I'm thinking a jumper wire from the solenoid signal to coil plus should bypass the ballast when cranking. But, it might keep the solenoid engaged when running. A diode might be needed.
Angry white pureblood male
Re: Slant 6 Forklift ignition question [Re: ruderunner] #3278629
12/28/24 09:50 AM
12/28/24 09:50 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Ignition switches from that era should have a run and crank source. Sometimes they both will be hot(cranking) but will run off one once it starts. Have seen the ignition power go threw the oil pressure switch also. So no power until it builds enough pressure to trigger the switch.
Re: Slant 6 Forklift ignition question [Re: Boise Chall] #3278678
12/28/24 01:16 PM
12/28/24 01:16 PM
Propane and Butane are in a liquid form under pressure and when cold both do not convert into vapor very quickly,.
I've seen the same thing in our warehouse forklifts in the Mojave desert in mid summer on first start up of the dayshruggy work
Re: Slant 6 Forklift ignition question [Re: Cab_Burge] #3278755
12/29/24 12:06 AM
12/29/24 12:06 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
That was my experience back 35 years ago when I worked in factory maintenance. Propane fork trucks didn't like starting in colder weather very well. When it was really cold, we would pull the propane cylinders off and take them in the building for a 1/2 hour, made a huge difference.
The fact that it starts easier with a power wire to the coil is interesting. Like mentioned above, I have used the Ford style solenoids that had the 4th terminal IGN on them, that 4th terminal is a crank only battery power source.
Re: Slant 6 Forklift ignition question [Re: poorboy] #3278828
12/29/24 01:17 PM
12/29/24 01:17 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Like sniper says, if your Ford solenoid doesn't have four terminals, get one that does and wire the I terminal to the coil.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Slant 6 Forklift ignition question [Re: Hemi_Joel] #3278958
12/30/24 12:11 AM
12/30/24 12:11 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I used to work on a few Yale forklifts at the Hyster dealer. It seems like some of them had a primer button on them for cold start. Does this one?
