How much horsepower HP manifolds vs headers #3277784
12/23/24 04:52 PM
12/23/24 04:52 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
How much HP gain do headers have compared to HP manifolds?
440 6 Pack with MP purple cam .468 lift. The drives side header is touching the power steering gear box. I wonder if that causes the seal to leak? I'm thinking about going back to HP cast iron manifolds. Thanks Don
Re: How much horsepower HP manifolds vs headers [Re: cudadon] #3277790
12/23/24 05:35 PM
12/23/24 05:35 PM
Central NC
gch Offline
gch  Offline
Central NC
Depends on the HP level and the size of the header tubes IMO. Why not clearance the header tube? On a stock headed engine with a small cam I would say no more than 15hp difference. Low speed and midrange torque may be down a bit as well.
Re: How much horsepower HP manifolds vs headers [Re: cudadon] #3277805
12/23/24 06:15 PM
12/23/24 06:15 PM
AndyF Offline
AndyF  Offline
Not much difference with cast iron heads and a cast iron intake manifold. Maybe a few HP at peak depending on the rest of the exhaust system. For a car like that I'd probably go back to the original cast iron exhaust manifolds as long as you still have them.
Re: How much horsepower HP manifolds vs headers [Re: AndyF] #3277822
12/23/24 07:06 PM
12/23/24 07:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Seems to me the header will rotate away from the steering box under acceleration, so the options are:
Clearance the tube
Shim the engine mounts upward (maybe the trans mount too)
Change headers
Swap to OEM manifolds
Re: How much horsepower HP manifolds vs headers [Re: topside] #3277848
12/23/24 09:51 PM
12/23/24 09:51 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
All good comments. Clearancing the header might be my choice.
I should have said it has 906 heads ported with MP porting templates.
It has about 420 horsepower. Aluminum Edelbrock 6 Pack manifold.
I don't have the original ci manifolds. Thanks
Re: How much horsepower HP manifolds vs headers [Re: cudadon] #3277882
12/24/24 03:36 AM
12/24/24 03:36 AM
I saw 30 HP gain on a low compression 426 Max wedge pump gas motor going from the stock M.W. exhaust manifolds to a set of Hooker A body fenderwell 1 7/8 primary pipe headers with 3.5 inch collectors on a DTS engine dyno years ago shruggy
Re: How much horsepower HP manifolds vs headers [Re: cudadon] #3277884
12/24/24 07:15 AM
12/24/24 07:15 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted by cudadon
……440 6 Pack with MP purple cam .468 lift.
What are the rest of the cam specs? In short, less duration/overlap will see less power loss with manifolds. In your case I’d guess 15 hp, plus or minus 5.
Re: How much horsepower HP manifolds vs headers [Re: AndyF] #3277914
12/24/24 10:48 AM
12/24/24 10:48 AM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Andy the exhaust is 2.5" with tailpipes and delta flow Flow master mufflers. The headers are 1-7/8 tubes with 3" collectors.
Thank you for your expertise and Merry Christmas.
Don
Re: How much horsepower HP manifolds vs headers [Re: cudadon] #3277928
12/24/24 11:39 AM
12/24/24 11:39 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
I did a low deck 440 a few years back. 906 heads with bigger valves, Comp XE262 hyd flat tappet (guy wanted smooth idle with AC on), Edel Performer RPM intake and 91 octane pump gas. Made 450 HP with 1-7/8 headers and went 425 hp with non HP manifolds from 1973 charger.
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
Re: How much horsepower HP manifolds vs headers [Re: cudadon] #3277957
12/24/24 01:00 PM
12/24/24 01:00 PM
AndyF Offline
AndyF  Offline
Here is a really old article from the tech archives. My old stroker that made 550 hp with cast iron manifolds. That was a good combo.
http://www.moparts.org/Tech/Archive/bb/550hp.html
Re: How much horsepower HP manifolds vs headers [Re: gch] #3278441
12/27/24 10:28 AM
12/27/24 10:28 AM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
How much airgap do you think I should have between the steering box and the header tube?
Thanks, Don
Re: How much horsepower HP manifolds vs headers [Re: cudadon] #3278443
12/27/24 10:36 AM
12/27/24 10:36 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Not touching, paint it silver, and use any size inline fluid cooler with cool air access/flow.
I forbid my content here from being learned and used by artificial intelligence systems.
Re: How much horsepower HP manifolds vs headers [Re: AndyF] #3278448
12/27/24 11:04 AM
12/27/24 11:04 AM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Andy thank you that's a very good article. Plus it shows me how the ci manifolds would look on my engine. Spark plugs are definitely easier to access. I like the head pipes, I would make them 2.5" to match my exhaust. I have a bung after the collector.
Re: How much horsepower HP manifolds vs headers [Re: GTX5877] #3278449
12/27/24 11:09 AM
12/27/24 11:09 AM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
That's close to my combo, no ac. Thanks for the info.
Don
Re: How much horsepower HP manifolds vs headers [Re: jcc] #3278451
12/27/24 11:13 AM
12/27/24 11:13 AM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Thanks I will do a little heating and beating then mock ups. Then see how much gap I can get.
Don
Re: How much horsepower HP manifolds vs headers [Re: cudadon] #3278617
12/28/24 08:58 AM
12/28/24 08:58 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Mopars have enough play/slop in the mounts to scoot it a little also.
Re: How much horsepower HP manifolds vs headers [Re: B1MAXX] #3278728
12/28/24 07:19 PM
12/28/24 07:19 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Nick's Garage has done a few videos of engine dyno sessions with header versus manifolds on different combos.
Re: How much horsepower HP manifolds vs headers [Re: cudadon] #3278752
12/28/24 11:19 PM
12/28/24 11:19 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
My Super Bee
