400 Motor home block? #3277391
12/21/24 06:57 AM
12/21/24 06:57 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
https://youtu.be/OOCUc_HFmZs?si=8BbBZ29B3ss5U3Aq
What's the difference between a 230 400 block and a motor home block? work
Re: 400 Motor home block? [Re: racerx] #3277406
12/21/24 09:29 AM
12/21/24 09:29 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Well, there is such a thing as a "motorhome" block. It means it came in a motorhome. But I don't guess it's any better than a regular block. It is made from the same casting. It is described in the Mopar B/RB handbook. It has 2 "steam holes" in the deck under each exhaust port similar to a 426 Hemi. This is why those 2 holes are there when you buy a head gasket for a wedge. (Look at your wedge head gasket.) But that doesn't mean that all motorhomes had a "motorhome block". Don't confuse this with the Very Heavy Main Web 230 block that was made up until approximately 10-10-71. Which is what you should use to build a 1000 horsepower wedge if you are not using an aftermarket block.
2011 Drag Pak Challenger
Re: 400 Motor home block? [Re: racerx] #3277416
12/21/24 10:48 AM
12/21/24 10:48 AM
AndyF Offline
AndyF  Offline
No such thing as a motorhome block but I'm not going to bash those guys too hard since they are running a lot of my parts on that engine!
Chrysler just produced blocks. Some went into cars, some into police cars, some into trucks, some into motorhomes. The same exact castings got used everywhere. Some got stamped HP, some got stamped T, etc.
Re: 400 Motor home block? [Re: AndyF] #3277448
12/21/24 01:12 PM
12/21/24 01:12 PM
iagree Mopar did not use any 400 motors in any motorhome chassis that I know of or have heard of: up: shruggy scope
Re: 400 Motor home block? [Re: Cab_Burge] #3277554
12/22/24 05:04 AM
12/22/24 05:04 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Well, I disagree. There is a 440 block that went specifically into SOME motor homes. Mostly the later ones. I’ve got one at the shop. I, unknowingly, bought it new as a short block when Mopar was selling things cheap in the 80’s. It is just machined differently with the ,as mentioned above, steam holes. Ironically, it does not have the heads listed as “ motorhome “ with the special casting number. Those are 213 if I remember correctly. These blocks are matted from the factory with a specifically machined 452 casting. It has the same “steam holes” . Many a motor home has gotten hot before all head gaskets started being produced with those holes. It was not known to get those spec gaskets for a motor home application. These 452 heads also had the smaller tapered seat spark plugs. I can personally testify that my 3/4 ton truck with that block and a set of 906 heads would run very hot on a summer day. My buddy had the same block and head combo that did the same thing. I ended up pulling mine out . He just re-blocked his car to solve his problem. Now the last time this conversation came up( and it seems to do that a lot), some old tech on here said there was a special water pump housing and thermostat that went with that combo and most people did not know that. I don’t know about that but I would not be surprised. Down here in the Texas heat, we were always hearing of some guy burning up his 440 motor home engine.
Now, I’ve never heard of a “400” motor home block.
Re: 400 Motor home block? [Re: fastmark] #3277713
12/23/24 07:50 AM
12/23/24 07:50 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thanks fellas ....I read on some interesting facts on 440 sourse.com. coffee
Re: 400 Motor home block? [Re: racerx] #3277718
12/23/24 08:38 AM
12/23/24 08:38 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I don't think they put 400 blocks in motor homes. 440 is what i know they used and some could be found with forged cranks and 6 pac rods as Chrysler used up their stock. A friend of mine aquired one and found the good parts inside. I guess Chrysler did not let anything go to waste.
Re: 400 Motor home block? [Re: mopar dave] #3277772
12/23/24 03:09 PM
12/23/24 03:09 PM
I have seen 413 industrial motors in Class A motorhomes and other applications like generator power plants ,marine and H.D. (5 ton+) trucks.
Those blocks have a bunch of extra reinforcing ribs on the lower sides between the oil pan rails and the bottom of the cylinder walls scope
Re: 400 Motor home block? [Re: Cab_Burge] #3277807
12/23/24 06:18 PM
12/23/24 06:18 PM
AndyF Offline
AndyF  Offline
The only block that I've personally seen which I couldn't explain was a 426 Wedge block with cross bolted mains. I was told it was for NASCAR applications. I didn't have a camera with me when I saw it (before cell phones were invented) so I didn't get a picture. Guy who was selling Mopar stuff out of his garage had the block sitting in a corner. It was a wedge block but had a Hemi bottom end. Wish I had some pictures of it. There is no record of Mopar ever producing a block like that so it must have been "back channel" or something?
Re: 400 Motor home block? [Re: AndyF] #3277886
12/24/24 07:22 AM
12/24/24 07:22 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Yes, NASCAR block, circa 1971-72. They were just discussed on here a couple months ago.
Re: 400 Motor home block? [Re: sixpakdodge] #3277927
12/24/24 11:30 AM
12/24/24 11:30 AM
PA
moparacer Offline
moparacer  Offline
PA
The 400 block I am running is "supposedly" a "motorhome" block....1977 date.
When I bought it off the guy he told me that is what it came out of. Can't imagine any reason he would have made that up. It also has the oil dipstick hole plugged and it looks like the factory done it, so I assume it had some other dipstick setup on it which would also lean towards a motorhome. Or even a van chassis? shruggy
And its held up pretty well considering what I have put it through.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Re: 400 Motor home block? [Re: moparacer] #3278055
12/24/24 07:35 PM
12/24/24 07:35 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Do that block have any factory markings like the old HP's/230/430 blocks?
Re: 400 Motor home block? [Re: moparacer] #3278120
12/25/24 09:50 AM
12/25/24 09:50 AM
NY
challenger451ci Offline
NY
I was told the same thing about the block I used for my 451 and I never questioned where it really came from. After about 15yrs of service and abuse, we named it "King Winnebego Block". smile
Re: 400 Motor home block? [Re: challenger451ci] #3278144
12/25/24 11:06 AM
12/25/24 11:06 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
It would probably help to define "Motorhome".
A Class A Winnibago type apparently would be 413 or 440 only.
A Class C, B Van style was probably available with a 400.
Kevin
Re: 400 Motor home block? [Re: challenger451ci] #3278163
12/25/24 12:20 PM
12/25/24 12:20 PM
PA
moparacer Offline
moparacer  Offline
PA
Not that I recall no. I will have to compare it to my other 400 block when I get the chance. Car is in the trailer right now.
Here is a pic of the dipstick plug.
Re: 400 Motor home block? [Re: moparacer] #3278213
12/25/24 04:37 PM
12/25/24 04:37 PM
AndyF Offline
AndyF  Offline
Dipstick plug just means the block was used in application with a truck oil pan. The truck oil pan has a dipstick tube that screws into the pan.
Re: 400 Motor home block? [Re: AndyF] #3278227
12/25/24 06:53 PM
12/25/24 06:53 PM
[quote=AndyF]Dipstick plug just means the block was used in application with a truck oil pan. The truck oil pan has a dipstick tube that screws into the pan. [/quote) Exactly up scope
I'm thinking that some of the van chassis that came with BB in them used that oil pan also confused work
Re: 400 Motor home block? [Re: Cab_Burge] #3278231
12/25/24 07:25 PM
12/25/24 07:25 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yes, they do. I have several big blocks that I have parted out of Vans or motorhomes over the years.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 400 Motor home block? [Re: racerx] #3278565
12/27/24 08:02 PM
12/27/24 08:02 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
230 block...motor home block...HP block...all terms used to get more green from buyers. Loved my 400 motors tho, both were strong runners.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 400 Motor home block? [Re: A39Coronet] #3278607
12/28/24 07:24 AM
12/28/24 07:24 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
