Re: 727 trans explosion protection
[Re: SportF]
#3279896
01/02/25 09:21 AM
01/02/25 09:21 AM
Posts: 13,611 Marion, South Carolina [><]
an8sec70cuda
Sound to me like the floor did the job, not the shield. There were no holes through the floor, so the shield did it's job. When the trans exploded, there wasn't much to hold the shield to it. It blew upwards into the floor, deflecting the shrapnel. The shield was still in one piece, but it was very damaged. A blanket couldn't have done any better. Options are limited if you have a car quicker than 10.0 and don't want to cut up the tans tunnel/firewall.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3279899
01/02/25 09:31 AM
01/02/25 09:31 AM
Posts: 4,888 Wichita
GY3
Wichita
Why do people think the bolt in sprag is an upgrade?
It was originally designed as a "case saver" for cases where the OE sprag wasn't a press fit anymore, was it not?
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#3279911
01/02/25 10:07 AM
01/02/25 10:07 AM
Posts: 3,261 Michigan
A727Tflite
It was originally designed as a "case saver" for cases where the OE sprag wasn't a press fit anymore, was it not? Not designed as a case saver. The rollers, cam and race have to stay perpendicular to the axis to work. Most people don’t understand that.
[Re: A727Tflite]
#3279939
01/02/25 11:46 AM
01/02/25 11:46 AM
Posts: 8,267 Plymouth, MI
Blusmbl
Plymouth, MI
I thought there were two types of bolt in sprags- one is the oem style and is just a stock replacement, except being bolt in. The Coan and A&A ultimate bolt in ones have the larger C6 rollers.
[Re: Cab_Burge]
#3279945
01/02/25 12:09 PM
01/02/25 12:09 PM
Posts: 20,425 Park Forest, IL
slantzilla
Park Forest, IL
The last one I remember seeing was a 13:70 340 Barracuda. NLBA Cheetah valve body, no brake, no drum, no blanket. His trans guy warned him he had a bomb and at least needed a blanket. Guy said he couldn't afford it. When it let go it broke his foot and he was off work for a month.
Then there's the famous picture of the 64 Hemi car that pooped on the line....
[Re: Cab_Burge]
#3279946
01/02/25 12:11 PM
01/02/25 12:11 PM
Posts: 27,211 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
I don't remember any 727 explosion before trans brake were invented and used in drag racing: work: : confused: Maybe my memory is wrong Lots of explosions long before the brake. Witnessed a couple myself in the late sixties before LBA VB's including the one mentioned above. (Pisani & Waite)
[Re: A727Tflite]
#3280028
01/02/25 04:50 PM
01/02/25 04:50 PM
Posts: 6,666 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I don't remember any 727 explosion before trans brake were invented and used in drag racing: work: : confused: Maybe my memory is wrong As old as you are I would have thought you would have seen a few from back in the 60’s. I'm thinking the No Neutral Drop Rule was probably triggered by a few drum explosions in the Pushbutton days. Push 1 for go... Kevin
[Re: A727Tflite]
#3280137
01/03/25 02:36 AM
01/03/25 02:36 AM
Posts: 44,097 Bend,OR USA
Cab_Burge
I don't remember any 727 explosion before trans brake were invented and used in drag racing: work: : confused: Maybe my memory is wrong As old as you are I would have thought you would have seen a few from back in the 60’s. When were 727 trans brakes invented and first used?
[Re: Cab_Burge]
#3280151
01/03/25 08:42 AM
01/03/25 08:42 AM
Posts: 996 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
Cab ....A lot of people claimed being the first, a lot of early different methods were employed, BUT First INTERNAL transbrake was Steve Griner, he mentioned to me first time he used it at Gatornationals, everyone near the starting line backed up knowing it was an automatic car, and was wide open and matted to the floor Rest in Peace Steve, and thanks for all you did for automatics https://www.legacy.com/us/obituaries/jconline/name/stephen-griner-obituary?id=11179613
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
[Re: Twostick]
#3280195
01/03/25 12:20 PM
01/03/25 12:20 PM
John_Kunkel
Rio Linda, CA
I don't remember any 727 explosion before trans brake were invented and used in drag racing: work: : confused: Maybe my memory is wrong As old as you are I would have thought you would have seen a few from back in the 60’s. I'm thinking the No Neutral Drop Rule was probably triggered by a few drum explosions in the Pushbutton days. Push 1 for go... Kevin The Clutchflite is the same as a Neutral Drop, that's why the LBA VB was introduced to protect the sprag. IIRC, B&M was the first to offer it.
