Alternator question #3277335
12/20/24 05:05 PM
12/20/24 05:05 PM
ohio
ruderunner Online content OP
ruderunner  Online Content OP
ohio
Charging system quit on my Ramcharger the other day. Pretty sure it's the alternator but want to confirm.
If I put battery power to one field terminal and ground the other, it should go full charge right?
Angry white pureblood male
Re: Alternator question [Re: ruderunner] #3277336
12/20/24 05:06 PM
12/20/24 05:06 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Yes
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Alternator question [Re: metallicareload] #3277344
12/20/24 05:58 PM
12/20/24 05:58 PM
ohio
ohio
Re: Alternator question [Re: ruderunner] #3277435
12/21/24 11:37 AM
12/21/24 11:37 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
turn key to run, alternator pulley should magnetize with small screwdriver touching it, means alternator is ok
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Alternator question [Re: 440lebaron] #3277449
12/21/24 01:14 PM
12/21/24 01:14 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not quite.
Doesn't prove the diodes are good. All it proves is that the input side appears to be working.
Re: Alternator question [Re: Sniper] #3277568
12/22/24 08:14 AM
12/22/24 08:14 AM
ohio
ohio
It's dead. Already swapped and back to charging.
3 month old alternator and 44 year old everything else.
They just don't build things the way they used to.
Re: Alternator question [Re: ruderunner] #3277570
12/22/24 08:21 AM
12/22/24 08:21 AM
Arizona
jsully Offline
jsully  Offline
Arizona
Re: Alternator question [Re: jsully] #3277920
12/24/24 10:53 AM
12/24/24 10:53 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
This was my question from the first post, what year? 1980 Were they still amp gauge or did they have a shunt? Both were problematic. That's why they stopped using them and have a volt gauge now.
Re: Alternator question [Re: Moparite] #3277938
12/24/24 12:07 PM
12/24/24 12:07 PM
Andrewh Offline
Andrewh  Offline
you should probably replace the VR too.
I have had a few go bad and kill off an alt at the same time. not sure why. but I almost always wind up replace both parts.
Re: Alternator question [Re: Moparite] #3277954
12/24/24 12:55 PM
12/24/24 12:55 PM
ohio
ohio
Originally Posted by Moparite
Quote
It's an 80 and the ammeter has been bypassed for years. Old style smoke machine.
Re: Alternator question [Re: Andrewh] #3277956
12/24/24 12:58 PM
12/24/24 12:58 PM
ohio
ohio
Been burned by the "quality " of aftermarket parts too many times over the years. If I have good functional OEM stuff I won't change it.
See the current situation for example.
Re: Alternator question [Re: ruderunner] #3278044
12/24/24 06:00 PM
12/24/24 06:00 PM
IMGTX Offline
IMGTX  Offline
3 months?
You must have bought the premium brand i only got 2-1/2 weeks on my last lifetime warranty alternator.
I would call the stuff they sell today crap but crap is better than this stuff.
Glad its fixed. up
Re: Alternator question [Re: IMGTX] #3278051
12/24/24 06:56 PM
12/24/24 06:56 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Is it true that under a lifetime warranty they will only warranty it one time???
Time just gets away from us
I`m here until I`m not
Re: Alternator question [Re: mopars4ever] #3278089
12/25/24 12:38 AM
12/25/24 12:38 AM
IMGTX Offline
IMGTX  Offline
I have lifetime warranty replaced brake pads, alternators, and other stuff multiple times.
There seems to be no limit but sometimes stuff is no longer available or doesn't show up in their system which is a hassle.
Re: Alternator question [Re: ruderunner] #3278094
12/25/24 04:43 AM
12/25/24 04:43 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Quote
Being a 80 it should be a shunted system, so bypass or not the amm will make nothing, since these ammeters are a remote signal readers between both sides of the shunt path, not like older full load ammeters. At least on passenger cars. I guess by this year trucks should be the same.
Re: Alternator question [Re: IMGTX] #3278098
12/25/24 07:09 AM
12/25/24 07:09 AM
ohio
ohio
3 months?
Glad its fixed. up
The 1st 2 were junk right out of the box. Didn't even install them. One sounded like it had sand in the bearings and the other had been dropped.
Re: Alternator question [Re: NachoRT74] #3278099
12/25/24 07:14 AM
12/25/24 07:14 AM
ohio
ohio
Quote
Negative. 80 was the last year of the full current style ammeter. 81 was a whole new cluster that went to 89 or so. This had the shunt style ammeter. 90 to 93 had a voltmeter. Change over might be 91.
