Page 3 of 3 1 2 3
Re: 727 trans explosion protection [Re: Blusmbl] #3279371
12/31/24 04:29 PM
12/31/24 04:29 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I know some on here dont like the CSR shields, but I liked it on the charger, yeah things got a touch tight, but nothing super difficult. We used a billet front drum, and bolt in sprag as well for extra insurance.
Re: 727 trans explosion protection [Re: racerx] #3279389
12/31/24 06:34 PM
12/31/24 06:34 PM
Minn
SportF Offline
SportF  Offline
Minn
Sound to me like the floor did the job, not the shield.
Re: 727 trans explosion protection [Re: SportF] #3279896
01/02/25 09:21 AM
01/02/25 09:21 AM
an8sec70cuda Offline
There were no holes through the floor, so the shield did it's job. When the trans exploded, there wasn't much to hold the shield to it. It blew upwards into the floor, deflecting the shrapnel.
The shield was still in one piece, but it was very damaged. A blanket couldn't have done any better.
Options are limited if you have a car quicker than 10.0 and don't want to cut up the tans tunnel/firewall.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: 727 trans explosion protection [Re: an8sec70cuda] #3279899
01/02/25 09:31 AM
01/02/25 09:31 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Why do people think the bolt in sprag is an upgrade?
It was originally designed as a "case saver" for cases where the OE sprag wasn't a press fit anymore, was it not?
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: 727 trans explosion protection [Re: GY3] #3279908
01/02/25 09:57 AM
01/02/25 09:57 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you are building a racecar I believe in doing whatever it takes to be a good piece. If it's getting a cage, suspension, etc why people don't do other items at the same time? I this case making the tunnel larger. It makes shields and removal a snap. Not hard or expensive to do. And when it's done no one will be able to tell anyway.
Doug
Re: 727 trans explosion protection [Re: GY3] #3279911
01/02/25 10:07 AM
01/02/25 10:07 AM
A727Tflite Offline
A727Tflite  Offline
Not designed as a case saver. The rollers, cam and race have to stay perpendicular to the axis to work.
Most people don’t understand that.
Re: 727 trans explosion protection [Re: A727Tflite] #3279939
01/02/25 11:46 AM
01/02/25 11:46 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I thought there were two types of bolt in sprags- one is the oem style and is just a stock replacement, except being bolt in. The Coan and A&A ultimate bolt in ones have the larger C6 rollers.
Re: 727 trans explosion protection [Re: A727Tflite] #3279941
01/02/25 11:49 AM
01/02/25 11:49 AM
I don't remember any 727 explosion before trans brake were invented and used in drag racing: work: shruggy: confused: Maybe my memory is wrong confused
Re: 727 trans explosion protection [Re: Cab_Burge] #3279945
01/02/25 12:09 PM
01/02/25 12:09 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The last one I remember seeing was a 13:70 340 Barracuda. NLBA Cheetah valve body, no brake, no drum, no blanket. His trans guy warned him he had a bomb and at least needed a blanket. Guy said he couldn't afford it. When it let go it broke his foot and he was off work for a month.
Then there's the famous picture of the 64 Hemi car that pooped on the line....
Re: 727 trans explosion protection [Re: Cab_Burge] #3279946
01/02/25 12:11 PM
01/02/25 12:11 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
Lots of explosions long before the brake. Witnessed a couple myself in the late sixties before LBA VB's including the one mentioned above. (Pisani & Waite)
Re: 727 trans explosion protection [Re: Cab_Burge] #3279947
01/02/25 12:14 PM
01/02/25 12:14 PM
A727Tflite Offline
A727Tflite  Offline
As old as you are I would have thought you would have seen a few from back in the 60’s. up
Re: 727 trans explosion protection [Re: A727Tflite] #3280028
01/02/25 04:50 PM
01/02/25 04:50 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I'm thinking the No Neutral Drop Rule was probably triggered by a few drum explosions in the Pushbutton days.
Push 1 for go...
Kevin
Re: 727 trans explosion protection [Re: A727Tflite] #3280137
01/03/25 02:36 AM
01/03/25 02:36 AM
When were 727 trans brakes invented and first used?
Re: 727 trans explosion protection [Re: Cab_Burge] #3280144
01/03/25 06:09 AM
01/03/25 06:09 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I use a Super Sprag, billet steel front drum, and a Blanket. Haven't been to the track in a while but I was always careful how I launched the truck. Years ago before I used all the 'Good Stuff' I broke a U-Joint coming off the line. I pulled the tranny when I got home and it had rolled over the overrunning clutch. After that it got a blanket and when I built the Hemi the tranny got all the 'Good stuff too
Re: 727 trans explosion protection [Re: Cab_Burge] #3280151
01/03/25 08:42 AM
01/03/25 08:42 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
Cab ....A lot of people claimed being the first, a lot of early different methods were employed, BUT
First INTERNAL transbrake was Steve Griner, he mentioned to me first time he used it at Gatornationals, everyone near the starting line backed up knowing it was an automatic car, and was wide open and matted to the floor eek
Rest in Peace Steve, and thanks for all you did for automatics
https://www.legacy.com/us/obituaries/jconline/name/stephen-griner-obituary?id=11179613
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: 727 trans explosion protection [Re: Twostick] #3280195
01/03/25 12:20 PM
01/03/25 12:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Push 1 for go...
Kevin
The Clutchflite is the same as a Neutral Drop, that's why the LBA VB was introduced to protect the sprag. IIRC, B&M was the first to offer it.
Page 3 of 3 1 2 3
