Stock valve cover question #3277686
12/22/24 08:33 PM
12/22/24 08:33 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
My 408 stroked 360 has RHS non-magnum heads and OEM valve covers. I want to convert the right side to a factory style push in breather with hose running to nipple on air cleaner. Right now it has a filter style breather w/o hose and it clamps on to the approx 2" extension on valve cover. Will any LA small block valve cover work?
Facts are stubborn things.
Re: Stock valve cover question [Re: larrymopar360] #3277687
12/22/24 08:37 PM
12/22/24 08:37 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
This is what I have now. Want a factory look
Re: Stock valve cover question [Re: larrymopar360] #3277691
12/22/24 09:10 PM
12/22/24 09:10 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
They used those black valve cover breathers for many years as I have seen them on Dodge pickups and vans made well into the 70's. So long as the hole in the valve cover accepts the correct size rubber grommet for the breather any 70's era passenger side valve cover should be ok to use.
