Page 3 of 3 1 2 3
Re: K member swap 65 B body [Re: DoubleD] #3279810
01/01/25 07:44 PM
01/01/25 07:44 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Cb1289 stated
the stock motor mounts can easily be replaced with aluminum biscuits redrilled to gain a little over an inch.
I have been searching but can’t seem to find anything like what he is describing. Do you redrill the k member mount and use a solid engine mount? Any pictures would be great.
'75 Plymouth Duster
‘65 Plymouth Belvedere
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: K member swap 65 B body [Re: clovis] #3279812
01/01/25 07:47 PM
01/01/25 07:47 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Originally Posted by clovis
Cb1289 stated
Can also space the K-frame down from frame like the 68 S/S cars were done.
Re: K member swap 65 B body [Re: cudaman1969] #3279830
01/01/25 09:00 PM
01/01/25 09:00 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Is this a ‘66 V8 k frame? It looks a little than what is shown on the Schumacher site.
'75 Plymouth Duster
Re: K member swap 65 B body [Re: clovis] #3279832
01/01/25 09:06 PM
01/01/25 09:06 PM
AndyF Offline
AndyF  Offline
That looks like a 1966 or 1967 B body slant six K frame
Here is a 1971 B body V8 K frame
Re: K member swap 65 B body [Re: AndyF] #3279834
01/01/25 09:10 PM
01/01/25 09:10 PM
AndyF Offline
AndyF  Offline
Here is an early B body V8 k frame
Re: K member swap 65 B body [Re: AndyF] #3279841
01/01/25 10:14 PM
01/01/25 10:14 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Andy
Is there a biscuit mount that will move the engine back an inch on the early B k member?
'75 Plymouth Duster
Re: K member swap 65 B body [Re: clovis] #3279867
01/01/25 11:52 PM
01/01/25 11:52 PM
AndyF Offline
AndyF  Offline
Andy
It isn't that simple. You start by locating the engine where you want it. Then you fabricate custom motor mount brackets which are welded to the K frame. When you are finished everything fits perfectly. Headers, PS, radiator, shroud, factory clutch fan, etc.
Re: K member swap 65 B body [Re: AndyF] #3279977
01/02/25 01:33 PM
01/02/25 01:33 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I think the "biscuit" as it was referred to above is the 67 up (maybe 66 up) style of mount and not the 65 version... shruggy
The 65 uses 2 studs facing down and into the K frame...( you can see the holes in the pic above from Andy F)
The newer one only uses 1 stud and is a different design of mount... twocents
...FAFO...
Re: K member swap 65 B body [Re: skicker] #3279995
01/02/25 02:56 PM
01/02/25 02:56 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Ok, that makes sense as I did see a solid mount that has one stud per side.
Is it acceptable to drill another set of slots further back on the mount?
It’s looks as though to make an offset biscuit is doable.
'75 Plymouth Duster
Re: K member swap 65 B body [Re: clovis] #3280088
01/02/25 09:01 PM
01/02/25 09:01 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
No Redrilling on the K-Frame itself. Look at Andy's picture of the early B K-Frame. There is no premade biscuit that I know of that moves the engine back an inch for early B K-Frames. We bought the aluminum, cut it and drilled it as seen in these pics. This was in the late 70s when we ran stock eliminator in a '62 dodge wagon. Just needed to modify the trans mount as well, but it worked fine. At the same time, we also moved the rear axle forward approximately 1". If you decide to do the late model K-Frame, you will at the very least be hammering the seam in the tunnel on vintage metal. Not worth the damage IMO. Hope this helps. Good luck.
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: K member swap 65 B body [Re: cb1289] #3280135
01/03/25 02:33 AM
01/03/25 02:33 AM
1962 was the first year that Mopar went to unibody on all the B body cars. it has a one year only K member also whiney rant realcrazy
I bought a pair of 1963 Fury several years back, one two door and the other parts car is four door, the two door has a 1962 B body K member in it and I'm going to change it to a 1967 B body K member to move the motor back and give me a better choice on headers as well as more traction if needed luck whistling up devil
Re: K member swap 65 B body [Re: Cab_Burge] #3280183
01/03/25 11:48 AM
01/03/25 11:48 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
A friend made these for my car.
I see no need to move the engine back as we have plenty of traction (even with 275's) and, in fact, trying to keep the front end down!
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: K member swap 65 B body [Re: GY3] #3280292
01/03/25 06:42 PM
01/03/25 06:42 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Thanks guys that is exactly what I was looking for. You don’t happen to have the dimensions of the aluminum blocks?
The move back is more for header, oil pan, and radiator clearance. An inch will go a long way on header clearance and keep me from having to close down 1/2 a tube, while hopefully not creating two much problem in the tunnel. I am planning to move the rear forward an inch by using the springs and caltrac under my Duster along with sliders.
Speaking of ‘62 wagons this was the last car my dad was involved with when I was a kid (me in the red circle).
'75 Plymouth Duster
Re: K member swap 65 B body [Re: Cab_Burge] #3280327
01/03/25 10:49 PM
01/03/25 10:49 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
62 had a wild looking mount that set flat on the k-frame. I used those mounts putting a Super Bee 383 in a Jeep CJ 5. I used the 3 peed bell housing from a Max Wedge (Borg Warner trans) that thing would fly through the mud holes.
Page 3 of 3 1 2 3
