360 magnum neutral balance
#3277488
12/21/24 04:47 PM
12/21/24 04:47 PM
Posts: 2,479 ILLINOIS
volaredon
ILLINOIS
What would this take? Would I have to buy an aftermarket crank? What would it take to neutral balance a stock crank? Any idea of Cost to do so. What are the advantages of external balance anyway? Looking at a torquer motor for a truck that will be used as one. I'm putting together a 80s d250 (officially let's call it an 83, even though the cab i have is 90, bed is 91, etc but the frame and everything I have here for title and vin is from the original 83 I had) Looking at finding an nv4500 for it, want to make a good camper puller. Couple of steps over OEM (what used to be called) "towing/ RV" cam. 4 barrel, probably a TQ. Will have AC. S Neutral balance stick flywheels seem easier to find, as do neutral balance harmonic balancers, that's all, as motivation to do so Not really interested in stroker build at this point.
Re: 360 magnum neutral balance
[Re: topside]
#3277496
12/21/24 05:55 PM
12/21/24 05:55 PM
Posts: 16,311 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Should be externally balanced and require the scalloped flex plate with neutral balanced torque converter.
Facts are stubborn things.
[Re: Andrewh]
#3277497
12/21/24 05:56 PM
12/21/24 05:56 PM
Posts: 6,635 nowhere
Sniper
nowhere
pretty sure the stock 5.9 is neutrally balanced. . Not stock it isn't.
[Re: larrymopar360]
#3277499
12/21/24 05:58 PM
12/21/24 05:58 PM
Sniper
nowhere
Should be externally balanced and require the scalloped flex plate with neutral balanced torque converter. Missed the part about it being a stick? I guess flywheel and NV4500 weren't clues? You can buy, new, magnum balanced flywheels at rock auto for not a lot of money. But being this is an "AMC" build I hesitate to cite one.
[Re: topside]
#3277542
12/21/24 11:18 PM
12/21/24 11:18 PM
volaredon
ILLINOIS
Are we talking internal vs external balance ? Yeah
[Re: volaredon]
#3277543
12/21/24 11:43 PM
12/21/24 11:43 PM
Posts: 23,823 Here
jcc
No soup for you!!!
No soup for you!!!
Here
30 years ago I neutral balanced my first 360 motor, which I still have, and am glad I did.
I forbid my content here from being learned and used by artificial intelligence systems.
