Re: rotor phasing experiment. whats this mean?
[Re: aarcuda]
#327702
05/25/09 12:01 AM
05/25/09 12:01 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If there is no vacuum to the advance mechanism, that plate is not going to move.
Pull the distributor cap off and twist the rotor clockwise and CCW. Not to the point of going into the advance springs but try to feel for slop in the oil pump to dist drive.
How is the timing chain?
[Re: RapidRobert]
#327704
05/25/09 10:23 AM
05/25/09 10:23 AM
Posts: 15,493 the boonies
aarcuda
the boonies
Pull the distributor cap off and twist the rotor clockwise and CCW. Not to the point of going into the advance springs but try to feel for slop in the oil pump to dist drive. How is the timing chain?
I think you nailed it that this is the "movement" that he is seeing at idle, that they both can(& do)make the rotor & therefore the timing marks jump around at idle. I used the collar on the dist shaft & a good chain & marks are rock steady now
I think that may be it. I did this last night when I first saw the rotor moving and ya, I can move the rotor back and forth quite a bit before getting into the mech advance. I do have a collar on it btw but my distr and oil pump drive are both used- probably got some slop (also two thinks I didn't replace when I built the motor last summer)
I'm going to try and video it. It's unreal
[Re: aarcuda]
#327705
05/25/09 10:26 AM
05/25/09 10:26 AM
Magnum
If that turns out to be the problem. Either a new HD oil pump drive or an ugly fix it to hammer the dist end and peen it wider.
[Re: Magnum]
#327706
05/25/09 01:02 PM
05/25/09 01:02 PM
Slop in the dist drive and chain should not affect rotor phase
[Re: aarcuda]
#327708
05/25/09 01:07 PM
05/25/09 01:07 PM
IF YOU ARE POINTING the light at your test hole, the movement you see should NOT be caused by the cam drive or intermediate shaft. It should all be in the relationship of the dist, possibly shaft wear, slop (looseness) in the advance plate, slop in the centrifugal mechanism, etc
What you are seeing in the test hole is the time difference between when the points open/ magnetic trigger and the spark happening at the rotor. You should be able to turn the dist. with an electric drill and get the same results.
[Re: AndyF]
#327710
05/25/09 02:08 PM
05/25/09 02:08 PM
aarcuda
the boonies
You think you see the rotor moving back and forth but that doesn't mean that it is actually moving. You are using a timing light as a strobe correct?
yes. the timing light fires on the wire coming from the cap terminal I windowed.
Im definitely seeing the rotor move first clockwise (to the left of the terminal) and then shoot over to the right wheni let off but it will center on the terminal at idle and after it settles at higher rpm.
I think my distributor is a pos that is just all wore out.
[Re: aarcuda]
#327711
05/25/09 02:46 PM
05/25/09 02:46 PM
RapidRobert
The rotor position(seen w the strobe light effect) is going to change constantly as the rpm changes(until you(at higher rpm's) hit the point where the curve is maxed out) & thats normal. I was thinking that the rotor was dancing at idle which would indicate tchain or intermediate shaft slot clearance or less likely dist shaft runout.
[Re: AndyF]
#327713
05/25/09 03:17 PM
05/25/09 03:17 PM
aarcuda
the boonies
Try a different timing light and see what happens.
i only have one. a snapon electronic and i trust it.
here a picture of the rotor with the reluctor lined up engine not running.
[Re: RapidRobert]
#327716
05/26/09 08:27 AM
05/26/09 08:27 AM
aarcuda
the boonies
no, its not dancing at idle (although every once and then it looks like the rotor os at the terminal right before the one Im looking at).
What I am seeing as I rev it up, the strobe is capturing the rotor move to the left of the terminal (reference picture above) for the reving part. If I rev it and hold it at a higher rpm, the rotor moves back to align with the terminal.
When I let go of the throttle and let it drop back to idle, the rotor moves way the heck to the right of the terminal as its decelerating and then re-aligns with the terminal again when its at idle.
Does this sound like what youve seen?
If the rotor and the relector and the puck-up and the cap are all stationary and the only thing i have going on is mechanical advance, the rotor position should ALWAYS be at the same location because I am firing off the spark plug wire and looking at the rotor. rotor being fixed to the reluctor means they always stay together irregardless of accel or decel or mech advance.
Maybe its just an inherent delay in my timing light that cant pick up the changes in the strobe as fast as its changing when i rev it. ya, maybe the timing light is not changing the strobe as fast as the spark is changing so it shows a delay
[Re: aarcuda]
#327717
05/26/09 12:19 PM
05/26/09 12:19 PM
If you are sure the advance plate is not moving around, it seems to me at least two possibilites are:
A triggering problem in the light--not likely, but not unheard of. Is this a delay light?
Worn/ loose shaft bushings allowing the shaft to move in relation to the pickup. With the Mopar aluminum housings, this used to be a huge problem, and is why I eventually ended up with a Hemi dual point which has a ball top bearing (tach drive)
#327718
05/26/09 12:51 PM
05/26/09 12:51 PM
aarcuda
the boonies
those are the only two i can come up with too. i check the plate to see if it could move easy (the one the pick up mount to) and its pretty tight. doesnt want to move back and forth BUT i can tilt it and that would change the gap and most likely the timing of the spark
[Re: aarcuda]
#327719
05/26/09 01:23 PM
05/26/09 01:23 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
At lower speeds you can have bounce especially at idle. This is normally the combination of the chain slop and the mechanical advance bouncing because of it. There is not enough constant rotation at idle on the cam and it can actually want to turn the cam the other direction for a split second during idling. On some cars with big springs and low vaccuum this will happen several times a second at idle. On many cars you will see this happen for a split second as you give it throttle and when it initially maintains an RPM. If you check the timing with the timing light this will coincide with it, and although people will argue this, this is not necessarily a problem unless it is extremely bad and happens at mid to high RPM. It can be impossible to remove this bounce completely and converting to a timing belt with a tensioner can help.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#327720
05/26/09 01:56 PM
05/26/09 01:56 PM
aarcuda
the boonies
but i should NONE that looking at what Im looking at.
the coil fires when the reluctor spline passes by it, send the bolt thru the top of the rotr, out to its tip, over too the cap terminal and out the plug wire. the timing light fires off when the bolt goes out the wire to the plug.
the rotor and reluctor never change relativce to each other. the pick up never changes cause theres no vacuum advance.
I AM seeing the tip of the rotor move ONLY when i rev it quickly and when I let go and it drops back to idle. rotor is only displaced from the terminal during that split second of Revving it, then it moves back to the terminal if I hold it at high rpm or at idle. its only during the quick rev and de-rev that it moves off the terminal
[Re: aarcuda]
#327721
05/26/09 02:14 PM
05/26/09 02:14 PM
Posts: 7,759 So Cal
HealthServices
So Cal
You have mechanical advance right?
Check this with your timing light at the timing mark (at the balancer) it will do something similar.
Allen
#327722
05/26/09 02:49 PM
05/26/09 02:49 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Try this. - Turn engine over until you see the rotor move.
- mark the balancer at this point.
- Now turn the balancer the other way until you just see the rotor move the other way. This is ~ how much slop you have to the distributor.
This is 'A' and ideally the amount slop you will see when you first give it gas, release the throttle, and at idle Now if you have mechanical advance with no vacuum. If you have vacuum advance just remove and plug the hose. - check the timing at idle.
- Check it again at its highest point.
Subtract the two values and you have your mechanical advance. This is 'B' Worst case scenario the amount of timing bounce you will have is A and B together. This is if you had a weak spring in the distributor. It will never get that bad because the spring will not allow that much bounce. The amount of slop in 'A' will cause a certain amount of bounce or timing slop. But the amount of 'A' in combination with 'B' will cause a larger amount of bounce. Either way this slight bounce is nothing to be concerned with because you are just returning to idle or you are just giving it gas, taking the slack out of 'A'. Unless of course you have a supercharged blown funny car running nitro methane, in which case an errant spark can it can potentially blow the supercharger or the head off.
Allen
[Re: aarcuda]
#327724
05/26/09 04:20 PM
05/26/09 04:20 PM
Posts: 7,759 So Cal
HealthServices
So Cal
If you have mechanical advance this is what you are seeing.
Allen
[Re: aarcuda]
#327725
05/26/09 04:23 PM
05/26/09 04:23 PM
Posts: 7,759 So Cal
HealthServices
So Cal
i know i have slop. but the check i am doing wont see that. the light will fire when the reluctor passes- WHENEVER the reluctor passes. The rotor's position inside the cap gets illuminated by the timing light.
and slop in the distributor wont change the relationship of the rotor to the reluctor except for slop in the rotor to shaft or if there was any slop in the reluctor to the shaft (but its tight there).
And the rotor in relationship to the reluctor will change when you have mechanical advance. The rotor will advance as rpms increase, but this advance is thru the the use of two weights and two springs.
and the amount of play i have in the rotor to the shaft is miniscule. Im seeing maybe .001-.003" play in the rotor to shaft but I am seeing 1/2" to 5/8" of jump in the position of the rotor when I shine the light on it and rev it
Correct basically there is no way you can see any of this movement with a just a timing light.
#327726
05/26/09 04:28 PM
05/26/09 04:28 PM
aarcuda
the boonies
i disagree. both the reluctor and the rotor mount solidly to the same shaft. they mount to this (see pic). When one moves, the other moves right with it. As the weights fly out and move the reluctor, the rotor tip changes with it.
[Re: aarcuda]
#327727
05/26/09 04:29 PM
05/26/09 04:29 PM
Posts: 7,759 So Cal
HealthServices
So Cal
If the rotor and reluctor is rigid (do not change in relation to each other) no you should not have a change.
Allen
#327728
05/26/09 04:30 PM
05/26/09 04:30 PM
aarcuda
the boonies
Why is there a slot?
the slot is so the reluctor AND rotor and move wrt to cam shaft
[Re: aarcuda]
#327730
05/26/09 04:44 PM
05/26/09 04:44 PM
Posts: 7,759 So Cal
HealthServices
So Cal
You are right I was trying to apply the timing error or delay that you see at the timing mark and balancer to the phasing of the distributor. This would not apply to the distributor phasing itself.
Allen
[Re: aarcuda]
#327731
05/26/09 05:19 PM
05/26/09 05:19 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
I agree, you are correct, phasing is the relationship between the rotor and the reluctor wheel - it has NOTHING to do with anything else...
