Page 4 of 5 1 2 3 4 5
Re: Milodon dual oiling question [Re: sr4440] #3275420
12/11/24 09:44 AM
12/11/24 09:44 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Quote
Wouldn't that depend on the base circle diameter?
Not really. The oil passage is always exposed at the bottom - when the lifter is at the top end of it's travel. The base circle is usually only changed (made smaller) when the lift is so high that the cam wouldn't fit into the tunnel and/or the lobes would contact the lifter bores. A smaller base circle allows the lifter to sit lower in the bore but it still exposes the oil passage when it at the top end of it's travel. Otherwise, base circles of cams are usually in the same ballpark until they start getting crazy lift. FWIW that's why many race blocks now have much larger and even raised cam bores - lobe lifts are getting so high that making the base circles smaller exceeded the strength of the cams. Remember, high lifts require more spring pressure which is transmitted to the cam.
Re: Milodon dual oiling question [Re: Stanton] #3275421
12/11/24 10:00 AM
12/11/24 10:00 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Let's confirm that the oil pump drive shaft is 7" from the tip to the bottom of the gear.
2011 Drag Pak Challenger
Re: Milodon dual oiling question [Re: rickseeman] #3275536
12/11/24 06:47 PM
12/11/24 06:47 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
People keep overlooking the simple issue here, it works while NOT running but looses pressure while running! Somewhere a DOOR is opining!! Find that DOOR, IF no door, the drive shaft is too short or gear is slipping. That is the only thing that’s changed from the drill motor to engine running.
Re: Milodon dual oiling question [Re: cudaman1969] #3275538
12/11/24 06:54 PM
12/11/24 06:54 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Exactly. It works with a long priming driveshaft but not with an undetermined length distributor drive. So, I'll ask again. Is it 7" long from the tip to the bottom of the drive gear?
Re: Milodon dual oiling question [Re: rickseeman] #3275543
12/11/24 07:32 PM
12/11/24 07:32 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
Yup! And its been mentioned in a couple of replies.
Re: Milodon dual oiling question [Re: Stanton] #3275549
12/11/24 08:12 PM
12/11/24 08:12 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Originally Posted by Stanton
Quote
Simple to check shaft, stick the drill drive into the pump, put a piece of tape on the shaft at bushing then compare to the gear-driver.
Re: Milodon dual oiling question [Re: cudaman1969] #3275619
12/12/24 10:26 AM
12/12/24 10:26 AM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Sorry guys I haven't had time to look at it
On the intermediate shaft..i can plainly see it under the car..i have to have the female part of the oil pump, that in goes in the block, lined up with the intermediate shaft, or the pump isn't going to go in the block, right?
Re: Milodon dual oiling question [Re: Z_Z] #3275633
12/12/24 12:00 PM
12/12/24 12:00 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Uh, usually the pump is installed FIRST !!!
Re: Milodon dual oiling question [Re: Stanton] #3275635
12/12/24 12:05 PM
12/12/24 12:05 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Let's go through this process carefully ...
The pump gets installed. The engine is rotated to TDC on the #1 firing stroke. The intermediate shaft is installed to put the #1 plug roughly where you want it when the distributor is installed. When you install the intermediate shaft it will self-align with the pump.
Re: Milodon dual oiling question [Re: Z_Z] #3275644
12/12/24 01:03 PM
12/12/24 01:03 PM
A727Tflite Offline
A727Tflite  Offline
If the shaft is too short the pump will install without clocking it.
You can remove and install the pump from the bottom, but you will likely have to get the pilot started now then rotate the pump CW and CCW until the intermediate shaft engages the inner rotor. Not how things are usually done but no problem in doing it this way.
Re: Milodon dual oiling question [Re: A727Tflite] #3275677
12/12/24 03:27 PM
12/12/24 03:27 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
When I replaced pump back in the day I just rotated pump body a little till it slid on up, very easy only15 degrees each way (6 flats)
Re: Milodon dual oiling question [Re: cudaman1969] #3275780
12/13/24 08:28 AM
12/13/24 08:28 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Exactly. Never been an issue.
Re: Milodon dual oiling question [Re: rickseeman] #3276560
12/16/24 09:05 PM
12/16/24 09:05 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Sorry guys ive been busy with work, and needed a break from looking at this thing..lol
Yes Rick the oil pump shaft is 7"
Re: Milodon dual oiling question [Re: Z_Z] #3276630
12/17/24 10:49 AM
12/17/24 10:49 AM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
What's the clearance of the swinging pickup, from the bottom of the pan supposed to be? Mine is pretty close.
Re: Milodon dual oiling question [Re: Z_Z] #3276632
12/17/24 11:20 AM
12/17/24 11:20 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Maybe 3/16"
Re: Milodon dual oiling question [Re: rickseeman] #3276641
12/17/24 12:08 PM
12/17/24 12:08 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Originally Posted by rickseeman
Maybe 3/16"
Alright, thanks Rick..that probably what I have, but seams like it scrapes in a couple places
I have a used Charlie's pan i bought here a while back, it seams to have way more clearance, I have attached a picture of it
Re: Milodon dual oiling question [Re: Z_Z] #3276665
12/17/24 01:41 PM
12/17/24 01:41 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, that looks a little high. You can't use oil you can't pickup
Re: Milodon dual oiling question [Re: rickseeman] #3276666
12/17/24 01:55 PM
12/17/24 01:55 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
It is very high, like 1/2"
Re: Milodon dual oiling question [Re: Z_Z] #3276692
12/17/24 04:27 PM
12/17/24 04:27 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
That's an issue, but NOT the issue. The pickup sitting 1/2 off the bottom of the pan is not going to cause a loss of oil pressure at idle and allow you to build pressure with a drill. I will bet a $100 that your issue is oil getting passed the lifters when the engine is running. Pull the intake and valley cover, pressurize the oil system with a drill and crank the starter. You will see the issue. One question i haven't seen answered, is this a new build or have you had this running before?
Without Data, you’re just another guy with an opinion.
Re: Milodon dual oiling question [Re: sr4440] #3276697
12/17/24 04:48 PM
12/17/24 04:48 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
This "may" be his issue BUT unless you have a trained eye you can't tell what's good or bad because there is a significant amount of oil seeping past lifters anyway. I'm speaking from experience also. Had a similar issue, swapped in shrouded lifters but couldn't tell the diffence - but it showed on the gauge !!
