64 cable shift trans #3275548
12/11/24 08:04 PM
12/11/24 08:04 PM
fredericksburg,va
cudaman1969 Offline OP
Itch Nutz
Itch Nutz
fredericksburg,va
I’m looking to put a 64 trans into the 65, 65 has shift on column, what is changed in trans from push button to column shift on valve body? Will 904 drive shaft be the same as 727 other than length?
Dang, I hit some button and post turned black, how do I get back to white?
Never mind I found the thingy to change back to white
Re: 64 cable shift trans [Re: cudaman1969] #3275559
12/11/24 10:06 PM
12/11/24 10:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
64 what , 65 what? shruggy
the trans yoke will be different twocents
Re: 64 cable shift trans [Re: cudaman1969] #3275560
12/11/24 10:11 PM
12/11/24 10:11 PM
A727Tflite Offline
A727Tflite  Offline
64 console shift trans will work in a 65.
Difference between the push button 62/63/64 and a 64 console shift/65 trans is the valve body casting machining for true park position, the manual valves, and shift levers/cable plug.
Output shaft diameters differ between 904 and 727.
Re: 64 cable shift trans [Re: cudaman1969] #3275588
12/12/24 06:51 AM
12/12/24 06:51 AM
The 1964 trans will have a ball and trunnion trans yoke requiring a matching driveshaft with that front type U joint.
!965 was the first year in the automatic that Mopar switch to a conventional front U joint, and then switch the stick shift tranny cars to the same type of front U joint and tranny yokes in 1966 shruggy
You can swap the tranny parts around to use the 1965 parts needed to the 1964 case and output shaft and tail shaft.. You should keep the valve body with the car year as the push button valve body is probably a little different than the push button cable valve body and so on
Good luck luck scope wrench up
Re: 64 cable shift trans [Re: Cab_Burge] #3275610
12/12/24 09:44 AM
12/12/24 09:44 AM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
A little more info on what I’m doing, 1965 b-body with 273-904 trans. I’m putting in a 413-727. I would like to keep the column shifter for the stock look. I have a 65 727 trans but was wanting to use it in my 64 Savoy because of the slip yoke. I do have an extra 65 main shaft and housing to put in the 64 cable trans but I’m not against using the 64 trans with the trunion joint if the stock 65 shaft will work (I can shorten it on my lathe). If nothing works easy i have a 66 column I can use with the 66 and up trans (which I have a bunch), like I said the whole idea centers around keeping the stock 65 column. From looking at both the 64-65 trans, they have same two cables, one for gears and one for parking pall. Even the 65 column has the same two cables, what am I missing?
Appreciate all replies so far.
Re: 64 cable shift trans [Re: cudaman1969] #3275622
12/12/24 10:40 AM
12/12/24 10:40 AM
A727Tflite Offline
A727Tflite  Offline
To maintain the 65 column shift you have to use a console shift valve body from a 64/65 OR a 65 valve body. Period.
62-65 ALL have two cables - regardless if console or column shift.
Re: 64 cable shift trans [Re: A727Tflite] #3275675
12/12/24 03:18 PM
12/12/24 03:18 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
Ok, got two of each year. What is the difference in the two years? Something to do with the rear pump? Will the 65 VB work in the 64 trans? Thanks
Re: 64 cable shift trans [Re: A727Tflite] #3275689
12/12/24 04:19 PM
12/12/24 04:19 PM
Mopar decided to have two different male ends on their shift cables from 1962 up to 1964, one for the pushbuttons and the other for the console shifters that came out in 1964 is what I believe.
I'm not sure about the 1965 trannies and shifter cable ends confused.
I have seen several different variants of the rooster combs and manual valves in those early trannies, they need to match each other to make the shifts correctly and not overlap up work shruggy
Re: 64 cable shift trans [Re: cudaman1969] #3275701
12/12/24 05:18 PM
12/12/24 05:18 PM
A727Tflite Offline
A727Tflite  Offline
Valve bodies are completely interchangeable between years.
62-65 have rear pumps. 62-64 have ball & trunnions prop shafts while 65 have a slip yolk.
Re: 64 cable shift trans [Re: A727Tflite] #3275703
12/12/24 05:23 PM
12/12/24 05:23 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
Great! Now I can move forward, thanks for all the info and help.
Re: 64 cable shift trans [Re: cudaman1969] #3275831
12/13/24 01:13 PM
12/13/24 01:13 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
As mentioned, the '64 console and all '65 manual valve needs to travel one more notch for Park. The cable ends are different as are the adapter they plug into, the roostercomb and the manual valve itself is different. The VB casting has a hole at the end of the manual valve bore to allow the extra travel.
Re: 64 cable shift trans [Re: John_Kunkel] #3275834
12/13/24 01:32 PM
12/13/24 01:32 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
Sounds good John, we have crazy banter on the other posts but I still respect you. I’ll probably use the 65 trans then down the road switch out the slip yoke main shaft in the 64 trans, seems simpler now I’ve thought about it. I don’t have that ‘pin’ that hooks inside to VB so I’m hoping the 904 trans is the same. All the cables are still there on the 64 trans so no problem with it.
btw great pictures, explains a lot!
Re: 64 cable shift trans [Re: John_Kunkel] #3275853
12/13/24 02:40 PM
12/13/24 02:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
HMM, seems your signature quote "The INTERNET, the MISinformation superhighway" applies again wink
No offense meant to others 🍻. I've been following this thinking the rooster comb and manual valve were different between the two but my "RAM" is getting a bit overloaded 🙄.
Didn't know remember about the valve body change or the difference in cable ends.
Unfortunately Intel stopped making Upgraded RAM devices for my model of intellect 😳 back in the 80's and used devices are hard to come by and sketchy🙄🤣🤣
Re: 64 cable shift trans [Re: TJP] #3275931
12/13/24 08:54 PM
12/13/24 08:54 PM
A727Tflite Offline
A727Tflite  Offline
It’s almost idiot proof until you mix up the manual valves and the rooster combs.
Re: 64 cable shift trans [Re: A727Tflite] #3275945
12/13/24 09:34 PM
12/13/24 09:34 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
During my days in engineering we would spend MONTHS trying to make something IDIOT PROOF. Usually the 1st person would do something we hadn't expected.
Re: 64 cable shift trans [Re: TJP] #3275951
12/13/24 10:05 PM
12/13/24 10:05 PM
Andrewh Offline
Andrewh  Offline
because engineers don't think like regular people.
I had a job where we made software for doctors.
I told them you can't build it like this, they will screw it up.
I got told, that they must be smart because they are doctors and let it go.
of course the doctors broke it.
Re: 64 cable shift trans [Re: TJP] #3276058
12/14/24 12:37 PM
12/14/24 12:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
One of my mentors had a saying..."some people can break a rubber ball".
Re: 64 cable shift trans [Re: John_Kunkel] #3276143
12/14/24 05:05 PM
12/14/24 05:05 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up beer
Re: 64 cable shift trans [Re: Andrewh] #3276145
12/14/24 05:07 PM
12/14/24 05:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
HMMM 🤔 🤣
Re: 64 cable shift trans [Re: Andrewh] #3276155
12/14/24 06:48 PM
12/14/24 06:48 PM
A727Tflite Offline
A727Tflite  Offline
Engineering and Quality use - in most organizations - DVP and R. In order to ferret out design flaws. Manufacturing has it’s own controls. They are all supposed to keep design and process defects from getting out.
But the service community is not well understood by the guys within most organizations.
Then you have people that can ruin an anvil in a sandbox with a rubber mallet.
