Re: Group Buy Dakota/Durango Long Tube Headers
[Re: 69DodgeGTS]
#3240666
06/26/24 10:46 AM
06/26/24 10:46 AM
Posts: 20,742 north of coder
moparx
Buying your homeless and unwanted bolt on battery terminals
those are a great looking set of pipes ! a couple of things i do on any set of headers i install, i "stole" from our passed member, Mr. P-body [R.I.P.] i cut the end pipes from the middle two at the mounting flange, and drill one mounting hole on each flange segment two drill sizes larger. these simple mods dramatically increase the sealing ability of the flange, no matter how thick the flange is. this is especially true of the 1/4" and 5/16" flanges. doing this can seal any flange of any header to any head. i also use studs in the head, along with reduced head size flange nuts. doing these simple things has worked superbly for me over many years and many header installs. just my personal experience. your mileage will vary.
[Re: moparx]
#3240702
06/26/24 01:40 PM
06/26/24 01:40 PM
Posts: 2,827 541 slobovia
A990
541 slobovia
those are a great looking set of pipes ! a couple of things i do on any set of headers i install, i "stole" from our passed member, Mr. P-body [R.I.P.] i cut the end pipes from the middle two at the mounting flange, and drill one mounting hole on each flange segment two drill sizes larger. these simple mods dramatically increase the sealing ability of the flange, no matter how thick the flange is. this is especially true of the 1/4" and 5/16" flanges. doing this can seal any flange of any header to any head. i also use studs in the head, along with reduced head size flange nuts. doing these simple things has worked superbly for me over many years and many header installs. just my personal experience. your mileage will vary. Can you post a pic?
[Re: A990]
#3240851
06/27/24 10:13 AM
06/27/24 10:13 AM
moparx
those are a great looking set of pipes ! a couple of things i do on any set of headers i install, i "stole" from our passed member, Mr. P-body [R.I.P.] i cut the end pipes from the middle two at the mounting flange, and drill one mounting hole on each flange segment two drill sizes larger. these simple mods dramatically increase the sealing ability of the flange, no matter how thick the flange is. this is especially true of the 1/4" and 5/16" flanges. doing this can seal any flange of any header to any head. i also use studs in the head, along with reduced head size flange nuts. doing these simple things has worked superbly for me over many years and many header installs. just my personal experience. your mileage will vary. Can you post a pic? i have a set of headers stashed overhead in the garage rafters with this mod done. i'll see if i can get a picture or two of them without taking them down.
[Re: moparx]
#3241083
06/28/24 10:55 AM
06/28/24 10:55 AM
moparx
hopefully this picture will help explain what i like to do, cutting the flanges. i always like to contour the flanges a little for appearance, but just slicing through the flanges with a wizz wheel or hacksaw would accomplish the same objective. opening up one bolt hole a couple sizes allows for slight movement during warm up and cool down, helping the sealing of the flange.
UPDATE Dakota/Durango Long Tube Headers
[Re: A990]
#3275350
12/10/24 08:23 PM
12/10/24 08:23 PM
Posts: 48 Florida
69DodgeGTS
Just heared that 25 sets of long tube headers completed. 15 sets going to coating. If your wanting a set of real long tube headers for Dakota/ Durango that have been a proven winner. You better contact www.southeastperformance.com 813-503-8069
Re: UPDATE Dakota/Durango Long Tube Headers
[Re: 69DodgeGTS]
#3275594
12/12/24 07:36 AM
12/12/24 07:36 AM
Posts: 4,880 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I was told these headers developed from a 1999 Dakota R/T. So they fit 97-03 Dakota or Durango 2 wheel chassi. These were the specific performance vehicles back then everyone wanted parts for.
Some Gen 1 Dakota owners said they fit their trucks with some dimpling for clearance in certain areas.
97 Ram 1500 fits passenger side but drivers side hits all. .
No 4 x4 long tube headers. They have front differential drive unit in the way of pipes so only shorties work.
Id love to purchase a set but mine is a 1995 (2wd). If I knew for sure they would fit with a dent or two I'd buy a set. The last time I did a search about this the other forums had the same consensus- that they might fit the first gen. (Honestly Id hate taking the ball peen to these headers because they are a work of art!) But I do have a set of the first 2-year Magnum large exit diameter manifolds I will run.
Keep old mopars alive.
[Re: 69DodgeGTS]
#3276946
12/18/24 04:14 PM
12/18/24 04:14 PM
Posts: 3,324 West Coast, USA
jbc426
West Coast, USA
I just ordered a raw finished set directly from TTI. They make the best headers I've tried them on my '70 RB 'Cuda and '68 Barracuda with a 5.9 Magnum.
I wanted them coated in mat black, so I'm having them done locally inside and out after I test fit them in a resto-mod I'm building ('57 Dodge D100 on a 2WD Dakota chassis).
1970 Plymouth 'Cuda #'s 440-6(Stock drivetrain in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's & EFI. 1968 Plymouth Barracuda Convertible Paxton Boosted 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#3277000
12/18/24 09:48 PM
12/18/24 09:48 PM
Posts: 4,707 Motor City
6PKRTSE
Motor City
My Son's 99 Dakato 4x4 came with a set. After I rebuilt his 360 we reinstalled them with the fresh rebuild. I don't know what brand name that are, but they are the best fitting set of headers I have installed. They go right in and on.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 69DodgeGTS]
#3277047
12/19/24 05:33 AM
12/19/24 05:33 AM
2boltmain
Holland MI Ottawa
I hear ya, they didn't say what exactly they hit to clearance but it would be a shame to dent them up.
Yo u know with those bigger outlet manifolds, have a 2 1/2" Y pipe made at a muffler shop, connected to a 3" single pipe to muffler with dual 2 1/2" outlets and you should make some power. Yes and I do have a set of those big outlet manifolds I have blasted and painted. I will run them. I got them for $60 from an LKQ near me. Since I have these manifolds, Im skipping the shortie headers even though they look nice. Hooker 5803 super comps have been discontinued which are long tube direct fit.
