Re: K member swap 65 B body
[Re: DoubleD]
#3279810
01/01/25 07:44 PM
01/01/25 07:44 PM
Posts: 586 Kentucky
clovis
Kentucky
Cb1289 stated the stock motor mounts can easily be replaced with aluminum biscuits redrilled to gain a little over an inch.
I have been searching but can’t seem to find anything like what he is describing. Do you redrill the k member mount and use a solid engine mount? Any pictures would be great.
'75 Plymouth Duster ‘65 Plymouth Belvedere
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#3279812
01/01/25 07:47 PM
01/01/25 07:47 PM
Posts: 8,953 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
I have been searching but can’t seem to find anything like what he is describing. Do you redrill the k member mount and use a solid engine mount? Any pictures would be great. Can also space the K-frame down from frame like the 68 S/S cars were done.
[Re: cudaman1969]
#3279830
01/01/25 09:00 PM
01/01/25 09:00 PM
Posts: 586 Kentucky
clovis
Kentucky
Is this a ‘66 V8 k frame? It looks a little than what is shown on the Schumacher site.
[Re: clovis]
#3279832
01/01/25 09:06 PM
01/01/25 09:06 PM
Posts: 31,319 Oregon
AndyF
That looks like a 1966 or 1967 B body slant six K frame
Here is a 1971 B body V8 K frame
[Re: AndyF]
#3279841
01/01/25 10:14 PM
01/01/25 10:14 PM
Posts: 586 Kentucky
clovis
Kentucky
Andy Is there a biscuit mount that will move the engine back an inch on the early B k member?
[Re: clovis]
#3279867
01/01/25 11:52 PM
01/01/25 11:52 PM
AndyF
Andy Is there a biscuit mount that will move the engine back an inch on the early B k member? It isn't that simple. You start by locating the engine where you want it. Then you fabricate custom motor mount brackets which are welded to the K frame. When you are finished everything fits perfectly. Headers, PS, radiator, shroud, factory clutch fan, etc.
[Re: AndyF]
#3279977
01/02/25 01:33 PM
01/02/25 01:33 PM
Posts: 5,172 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I think the "biscuit" as it was referred to above is the 67 up (maybe 66 up) style of mount and not the 65 version... The 65 uses 2 studs facing down and into the K frame...( you can see the holes in the pic above from Andy F) The newer one only uses 1 stud and is a different design of mount...
...FAFO...
[Re: skicker]
#3279995
01/02/25 02:56 PM
01/02/25 02:56 PM
Posts: 586 Kentucky
clovis
Kentucky
Ok, that makes sense as I did see a solid mount that has one stud per side.
Is it acceptable to drill another set of slots further back on the mount? It’s looks as though to make an offset biscuit is doable.
[Re: clovis]
#3280088
01/02/25 09:01 PM
01/02/25 09:01 PM
Posts: 148 NJ
cb1289
NJ
No Redrilling on the K-Frame itself. Look at Andy's picture of the early B K-Frame. There is no premade biscuit that I know of that moves the engine back an inch for early B K-Frames. We bought the aluminum, cut it and drilled it as seen in these pics. This was in the late 70s when we ran stock eliminator in a '62 dodge wagon. Just needed to modify the trans mount as well, but it worked fine. At the same time, we also moved the rear axle forward approximately 1". If you decide to do the late model K-Frame, you will at the very least be hammering the seam in the tunnel on vintage metal. Not worth the damage IMO. Hope this helps. Good luck.
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: cb1289]
#3280135
01/03/25 02:33 AM
01/03/25 02:33 AM
Posts: 44,097 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3280183
01/03/25 11:48 AM
01/03/25 11:48 AM
Posts: 4,886 Wichita
GY3
Wichita
A friend made these for my car.
I see no need to move the engine back as we have plenty of traction (even with 275's) and, in fact, trying to keep the front end down!
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#3280292
01/03/25 06:42 PM
01/03/25 06:42 PM
Posts: 586 Kentucky
clovis
Kentucky
Thanks guys that is exactly what I was looking for. You don’t happen to have the dimensions of the aluminum blocks?
The move back is more for header, oil pan, and radiator clearance. An inch will go a long way on header clearance and keep me from having to close down 1/2 a tube, while hopefully not creating two much problem in the tunnel. I am planning to move the rear forward an inch by using the springs and caltrac under my Duster along with sliders.
Speaking of ‘62 wagons this was the last car my dad was involved with when I was a kid (me in the red circle).
