Re: Which 833 for a Dakota [Re: 58pwrwgn] #3276094
12/14/24 02:38 PM
12/14/24 02:38 PM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted by 58pwrwgn
I thought 833 prduction ended in 87
I don't think you can turn down the large retainer to 4.35 with cutting into the bolt holes
I have done that on the larger 3/8 front bearing B/RB,426 hemi bellhousings wrench up
It was close to the bolts but worked fine in my car so far, I haven't put 100 miles on that car so far, maybe next summer I can drive it some more luck
Re: Which 833 for a Dakota [Re: Cab_Burge] #3276490
12/16/24 01:41 PM
12/16/24 01:41 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I did the same when I put the 833OD in my hot rod back in 2001.
- Stu Harmon
Re: Which 833 for a Dakota [Re: Hot 340] #3276493
12/16/24 02:09 PM
12/16/24 02:09 PM
If I was you I would look for a NP833 out of a 1966 to 1971 273 or 318 C.I. A body, not one from a 340.
The 273/ 318 trannies have 3.08 first gear instead of the 2.65 or 2.66 first gear which is easier on the clutch around town up twocents
The later over drive trannies use that low gear also but some little motors don't like the over drive in high gear shruggy
