Re: Milodon dual oiling question
[Re: sr4440]
#3275420
12/11/24 09:44 AM
12/11/24 09:44 AM
Posts: 9,172 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Wouldn't that depend on the base circle diameter? Not really. The oil passage is always exposed at the bottom - when the lifter is at the top end of it's travel. The base circle is usually only changed (made smaller) when the lift is so high that the cam wouldn't fit into the tunnel and/or the lobes would contact the lifter bores. A smaller base circle allows the lifter to sit lower in the bore but it still exposes the oil passage when it at the top end of it's travel. Otherwise, base circles of cams are usually in the same ballpark until they start getting crazy lift. FWIW that's why many race blocks now have much larger and even raised cam bores - lobe lifts are getting so high that making the base circles smaller exceeded the strength of the cams. Remember, high lifts require more spring pressure which is transmitted to the cam.
[Re: rickseeman]
#3275536
12/11/24 06:47 PM
12/11/24 06:47 PM
Posts: 8,937 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
People keep overlooking the simple issue here, it works while NOT running but looses pressure while running! Somewhere a DOOR is opining!! Find that DOOR, IF no door, the drive shaft is too short or gear is slipping. That is the only thing that’s changed from the drill motor to engine running.
[Re: cudaman1969]
#3275538
12/11/24 06:54 PM
12/11/24 06:54 PM
Posts: 2,815 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
People keep overlooking the simple issue here, it works while NOT running but looses pressure while running! Somewhere a DOOR is opining!! Find that DOOR, IF no door, the drive shaft is too short or gear is slipping. That is the only thing that’s changed from the drill motor to engine running. Exactly. It works with a long priming driveshaft but not with an undetermined length distributor drive. So, I'll ask again. Is it 7" long from the tip to the bottom of the drive gear?
2011 Drag Pak Challenger
[Re: rickseeman]
#3275543
12/11/24 07:32 PM
12/11/24 07:32 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
That is the only thing that’s changed from the drill motor to engine running. Yup! And its been mentioned in a couple of replies.
[Re: Stanton]
#3275549
12/11/24 08:12 PM
12/11/24 08:12 PM
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
That is the only thing that’s changed from the drill motor to engine running. Yup! And its been mentioned in a couple of replies. Simple to check shaft, stick the drill drive into the pump, put a piece of tape on the shaft at bushing then compare to the gear-driver.
[Re: Z_Z]
#3275644
12/12/24 01:03 PM
12/12/24 01:03 PM
Posts: 3,245 Michigan
A727Tflite
Sorry guys I haven't had time to look at it
On the intermediate shaft..i can plainly see it under the car..i have to have the female part of the oil pump, that in goes in the block, lined up with the intermediate shaft, or the pump isn't going to go in the block, right? If the shaft is too short the pump will install without clocking it. You can remove and install the pump from the bottom, but you will likely have to get the pilot started now then rotate the pump CW and CCW until the intermediate shaft engages the inner rotor. Not how things are usually done but no problem in doing it this way.
[Re: cudaman1969]
#3275780
12/13/24 08:28 AM
12/13/24 08:28 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
When I replaced pump back in the day I just rotated pump body a little till it slid on up, very easy only15 degrees each way (6 flats) Exactly. Never been an issue.
[Re: rickseeman]
#3276641
12/17/24 12:08 PM
12/17/24 12:08 PM
Posts: 122 western iowa
Z_Z
western iowa
Alright, thanks Rick..that probably what I have, but seams like it scrapes in a couple places I have a used Charlie's pan i bought here a while back, it seams to have way more clearance, I have attached a picture of it
[Re: Z_Z]
#3276692
12/17/24 04:27 PM
12/17/24 04:27 PM
Posts: 740 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
It is very high, like 1/2" That's an issue, but NOT the issue. The pickup sitting 1/2 off the bottom of the pan is not going to cause a loss of oil pressure at idle and allow you to build pressure with a drill. I will bet a $100 that your issue is oil getting passed the lifters when the engine is running. Pull the intake and valley cover, pressurize the oil system with a drill and crank the starter. You will see the issue. One question i haven't seen answered, is this a new build or have you had this running before?
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3276697
12/17/24 04:48 PM
12/17/24 04:48 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I will bet a $100 that your issue is oil getting passed the lifters when the engine is running. Pull the intake and valley cover, pressurize the oil system with a drill and crank the starter. You will see the issue. This "may" be his issue BUT unless you have a trained eye you can't tell what's good or bad because there is a significant amount of oil seeping past lifters anyway. I'm speaking from experience also. Had a similar issue, swapped in shrouded lifters but couldn't tell the diffence - but it showed on the gauge !!
