I need some clutch help #3274495
12/06/24 08:12 PM
12/06/24 08:12 PM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
Quick run down on my car
65 Coronet 383, liberty proshift 23 spline trans. Dana 60, 4.10, power lock
1350 u joints, chrome moly drive shaft. Scatter shield.
Engine is a true 10:1 383, forged trw pistons, iron heads, 2.14/1.81 valves, crown 32002 solid cam 500lift / 300 duration
Tunnel Ram with dual 450 holleys. ( I have dual compucar fixed 100 hp plate nitrous setup but it isn't plumbed yet)
66 up k frame , Mini tubbed, relocated super stock springs with afco sliders 325/50 Hoosier drag radials.
Clutch is a vintage (80's era) Zoom 11" borg and beck. Clutch was new when installed
I just got the car together and running/driving this fall. After resisting the urge to beat on it while getting things broken in for several hundred miles, I decided to give it a fairly hard launch. Clutch slipped / smoked. Zero tire spin. So I drove it some more. Maybe not enough heat cycling? At any rate couple hundred miles later I tried a 1-2 power shift. Clutch slipped/smoked again.
I checked the free play at the clutch fork and have about 3/8?? Inch of movement at the rod end. So it's not hanging up.
I don't think it's going to get any better.
I really think I have a crap clutch. Either the 40 year old disc material is deteriorated or the pressure plate is not providing the proper clamping force or as I have been reading recently Zoom is junk.
So I'm going to replace it this winter
Being that I have a fairly heavy car, sticky tires, relatively decent hooking rear suspension, and 400-500 HP, I'm looking to replace the clutch with something that will be a bit softer on my 23 spline trans.
I understand that clutches like a soft lock or a twin disc can take some of the shock load off the trans/drive line. But I've read some poor reviews of some of these with disc plates warping.
If this was your car what clutch would you use?
18 spline isn't in the cards right now.
Video of the car
https://youtu.be/cHGAhxWBezU?si=lCFhKVFXfTYFFUOw
Re: I need some clutch help [Re: NTOLERANCE] #3274504
12/06/24 08:46 PM
12/06/24 08:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'm a centerforce fan. I would encourage a new flywheel with the clutch and dialing in the bell housing. You don't have to buy a CF flywheel but do get a Known brand. I have installed MANY over the last 20+ years with only one issue. They had packaged the wrong sized disc for the PP tsk tsk That crapped up 3 cutch cables before we pulled the trans and found the problem. They replaced the Clutch, PP, and bearings but nothing else 👎
As po'd as I was I stayed with them as all other installs were problem free. twocents beer
Re: I need some clutch help [Re: TJP] #3274505
12/06/24 08:56 PM
12/06/24 08:56 PM
Madison Wi
Madison Wi
I did have the shield dialed in- tried doing it myself and never felt confident so I punted to someone with the experience and skill.
And he bought different offset dowel pins than I did. drive
I have a 143 tooth stock flywheel which was resurfaced before the install.
Re: I need some clutch help [Re: NTOLERANCE] #3274509
12/06/24 09:07 PM
12/06/24 09:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Center Force here as well. Been in the car 20 years, at least 100 passes with slicks. Mid 12 second car at 3775 lbs race ready. Best clutch I've ever owned.
Doug
Re: I need some clutch help [Re: dvw] #3274510
12/06/24 09:20 PM
12/06/24 09:20 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I will agree that Zoom sucks. Blew up a couple of those in short order.
Tried several others and settled on Centerforce. Great clutch, low pedal pressure but bites well and holds up to abuse. No brainer to me, Centerforce,
Re: I need some clutch help [Re: dvw] #3274513
12/06/24 09:29 PM
12/06/24 09:29 PM
Madison Wi
Madison Wi
Doug
Which centerforce did you use? There are several
Re: I need some clutch help [Re: NTOLERANCE] #3274524
12/06/24 10:14 PM
12/06/24 10:14 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I personally can't stand any diaphram clutch, only Borg and Beck for me. No Chevy parts in any of my builds. tsk I don't care what my left knee feels like, a properly set-up B&B blows away a diaphram. Of course opinions vary... rolleyes
JB Rhinehart, Realist
A-Body's RULE!
Re: I need some clutch help [Re: Rhinodart] #3274529
12/06/24 10:36 PM
12/06/24 10:36 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Originally Posted by Rhinodart
I personally can't stand any diaphram clutch, only Borg and Beck for me. No Chevy parts in any of my builds. :
That's what I thought too. Until I tried a CF, twocents
Re: I need some clutch help [Re: Ramrod39] #3274555
12/07/24 08:34 AM
12/07/24 08:34 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Just looked on the Centerforce website. Where are the 18 spline discs?
Re: I need some clutch help [Re: NTOLERANCE] #3274563
12/07/24 09:30 AM
12/07/24 09:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Pretty sure it was a 269729. But like I said it's been 20 years. It has an aftermarket billet flywheel that was balanced with the engine which is a 360. Nobody offered a good 360 flywheel back then.
Doug
Re: I need some clutch help [Re: Rhinodart] #3274564
12/07/24 09:32 AM
12/07/24 09:32 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What is your thought process here? Just wondering why you think the B&B is so much bettter? Why does it "blow away a diaphram style"?
Doug
Re: I need some clutch help [Re: dvw] #3274589
12/07/24 11:25 AM
12/07/24 11:25 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I tried not to get into this but maybe I'm old school ,back in the day even chevy guys in the know wouldn't run a diaphragm.
That being said the best clutch I ran with slicks bolted on at the track, after many brands experience, was the old mopar street strip stuff not the green back either (10.5 only way it came).
I would have to check the old mopar catalog for the p/n. 2nd would be the Hays
On a side note any of the clutches I was running wouldn't last forever.
Maybe this has changed in the last 30 years...but 30 years ago people had issues with the centerforce. Not destructive, but issues. I say pick your own. If your the trying type put the centerforce in.
I drive Chevys occasionally and they ain't the same feel as my 70 charger rt.
I have never driven an Mopar with a centerforce.
Re: I need some clutch help [Re: B1MAXX] #3274596
12/07/24 11:53 AM
12/07/24 11:53 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
a little reading.
Re: I need some clutch help [Re: B1MAXX] #3274597
12/07/24 11:54 AM
12/07/24 11:54 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
2
Re: I need some clutch help [Re: B1MAXX] #3274599
12/07/24 11:55 AM
12/07/24 11:55 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
3
Re: I need some clutch help [Re: NTOLERANCE] #3274609
12/07/24 12:21 PM
12/07/24 12:21 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have a Center Force and I like the way it worked, BUT one thing, the dual friction disc HATES stop and go traffic and, or hills. You are in flat country, so that won't be a problem, but if you drive in a lot of stop and go, it won't work. They get hot and start smoking. I couldn't even do a parade, but other than that I like it.
Re: I need some clutch help [Re: 71birdJ68] #3274654
12/07/24 02:33 PM
12/07/24 02:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have used mainly the centerforce II's unless it was a real low power application. Have never had a chatter issue or any other kind. up beer
Re: I need some clutch help [Re: B1MAXX] #3274657
12/07/24 02:53 PM
12/07/24 02:53 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
B1 not trying to be offensive in any way but the article posted is from 1990. CF was in their infancy at that time. Technology has jumped light years ahead in that timeframe. Years ago I too hated diaphragm style clutches. can't even remember who talked me into trying one but once I did, I haven't used anything else since.
It has nothing to do with the leg effort required IMO. It's more to do with removing the stress on the frame rail pivot point (of which we had to reinforce MANY back in the day) and the longevity while being driven hard.
here's a link to their story for anyone interested up beer LINKY
and B1 , you might be surprised who developed CF clutches wink up
Re: I need some clutch help [Re: TJP] #3274660
12/07/24 03:02 PM
12/07/24 03:02 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
actually 1980...lol but I'll never change. I like the B&B feel better. To each their own. up
Re: I need some clutch help [Re: B1MAXX] #3274672
12/07/24 03:34 PM
12/07/24 03:34 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have used literally every kind of clutch out there in my Savoy. My current unit is a Centerforce II pressure plate with a Mcleod 500 series disc and it is hands down the best clutch I have ever owned. It is smooth on the street and it hits hard enough on the track that I'm afraid it will break third gear in my HEMI box.
To the OP if you don't want to break your 23 spline box something has to slip or it will strip the teeth off third gear with traction,torque,and weight. A light pressure or adjustable long style plate with an iron disc will do the job. You need to spend money on a clutch if you don't want to break your current transmission. I haven't used a B&B clutch for almost 20 years. I have however used a Borg/Beck/Long Hays MKXII plate when I was racing on a regular basis but It was an adjustable unit with 900# base pressure with counter weights on the levers. That clutch was high maintenance on the street though.
The Centerforce II is a great clutch and with the dual friction disc you will be happy with it.
Gus beer
64 Plymouth Savoy
Dana 60
