Re: Pushing a stock block....
[Re: Dragula]
#3274439
12/06/24 02:28 PM
12/06/24 02:28 PM
Posts: 4,886 Wichita
GY3
Wichita
Ours recently ran 9.92 @ 135mph in a 3,680 lbs. car. 505" RB. I'll let you do the math to figure out HP since every time I post it people want to question the number.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: Dragula]
#3274445
12/06/24 03:27 PM
12/06/24 03:27 PM
Posts: 10,177 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My first thoughts are how to get high hp with less stress? How about e85, low compression, high boost, moderate rpm? I am speculating here,,,,,,,a moderate cam to work from say 4800 to 6,000 rpm with good boost, could a guy build 800 hp and have it live?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#3274449
12/06/24 03:59 PM
12/06/24 03:59 PM
GY3
Wichita
My first thoughts are how to get high hp with less stress? How about e85, low compression, high boost, moderate rpm? I am speculating here,,,,,,,a moderate cam to work from say 4800 to 6,000 rpm with good boost, could a guy build 800 hp and have it live? Low rotating mass and low rpm is in my efforts.
'63 Dodge 330
[Re: GY3]
#3274458
12/06/24 04:40 PM
12/06/24 04:40 PM
Posts: 1,651 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I had three 505 cu. in stock 440 blocks crack in between the main cap and cylinder 1 or 3 (don't remember for sure). Around 745 horse power . All three lasted 3 years each. Around 450 passes each. After 3rd one cracked , I switched to a Bill Mitchell Aluminum block, and went to 540 cu. in. Freshened every 3 years, everything looks good. Freshened 3 times so far. Last time we went to 548 cu. in. 797 horse power with 760 ft. lb. torque. About 450 to 475 passes between freshen ups.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: GY3]
#3274490
12/06/24 07:41 PM
12/06/24 07:41 PM
Posts: 12,801 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Ours recently ran 9.92 @ 135mph in a 3,680 lbs. car. 505" RB. I'll let you do the math to figure out HP since every time I post it people want to question the number. My dream wheel says right at 700. That's enough for a stock block.
[Re: Dragula]
#3274515
12/06/24 09:40 PM
12/06/24 09:40 PM
moparpollack
Lil Herman
Lil Herman
85086
Stock block half filled, aluminum rods, stock crank, 500hp nitrous shot in Dale Gebharts gremlin and it didn't blow up 900hp?
[Re: moparpollack]
#3274533
12/06/24 10:43 PM
12/06/24 10:43 PM
Posts: 12,538 Taxes & Virus's R-US, NY
Dragula
How much stroke can you fit with aluminum rods?
Either way, I pulled the 400/512 out of my Duster tonight, and when I go thru it, I am going to measure a few things, but doing basic math, it looks like I am right around 10.4:1 compression....Putting in say a .085 head gasket, could drop me to 9.5:1, switch cams and add boost. At 7psi, this thing would make 50hp more than my big Hemi....
[Re: CMcAllister]
#3274548
12/07/24 07:27 AM
12/07/24 07:27 AM
Posts: 4,305 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Ours recently ran 9.92 @ 135mph in a 3,680 lbs. car. 505" RB. I'll let you do the math to figure out HP since every time I post it people want to question the number. My dream wheel says right at 700. That's enough for a stock block. My dream-wheel says about 750 at sea level.
[Re: Dragula]
#3274549
12/07/24 07:31 AM
12/07/24 07:31 AM
HardcoreB
Shelby Twp. Mi
What power levels have you guys pushed a stock 440 block to?
Thinking of doing somthing stupid...Just kinda bored and I have access to one more really nice 440 block. Was thinking of doing another 440Source build and going with a 528 with the +..03 over -30 dished pistons and a .075 head gasket for about 9:1 and then adding a TorqueStorm blower....for street strip fun.... IMO if you are using a blower on a production 440 block use a stock stroke and long alloy rod. Turn up the boost!
[Re: Dartsport540]
#3274557
12/07/24 08:47 AM
12/07/24 08:47 AM
Posts: 918 Missouri
jwb123
Missouri
I had three 505 cu. in stock 440 blocks crack in between the main cap and cylinder 1 or 3 (don't remember for sure). Around 745 horse power . All three lasted 3 years each. Around 450 passes each. After 3rd one cracked , I switched to a Bill Mitchell Aluminum block, and went to 540 cu. in. Freshened every 3 years, everything looks good. Freshened 3 times so far. Last time we went to 548 cu. in. 797 horse power with 760 ft. lb. torque. About 450 to 475 passes between freshen ups. Yep I can report exactly the same type of history with running a stock block. I tried concrete, main girdles, 4 bolt caps. About three seasons and they would start to lost ET, take them apart and could not reuse them because of cracks and cylinder distortion. I know the aftermarket blocks are expensive but calculate the machine work costs on a stock block and if you plan to race for more than a couple seasons the aftermarket block investment makes dollar sense.
[Re: HardcoreB]
#3274658
12/07/24 02:54 PM
12/07/24 02:54 PM
Posts: 5,194 CT
GTX MATT
CT
Ours recently ran 9.92 @ 135mph in a 3,680 lbs. car. 505" RB. I'll let you do the math to figure out HP since every time I post it people want to question the number. My dream wheel says right at 700. That's enough for a stock block. My dream-wheel says about 750 at sea level. I got 699.2
[Re: Dragula]
#3274712
12/07/24 06:42 PM
12/07/24 06:42 PM
Posts: 2,146 Byron, NY
W.I.N. Racing
Byron, NY
its more a question of how long can you push a stock block at a given HP level. at 600 hp probably as long as you want it to...over that the clock ticks faster and faster.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3274747
12/08/24 05:59 AM
12/08/24 05:59 AM
gregsdart
its more a question of how long can you push a stock block at a given HP level. at 600 hp probably as long as you want it to...over that the clock ticks faster and faster. A lot depends on what stress levels the block sees, and intensity. My first beef, is the non center weighted cranks and weak block. There usn' t enough metal above the mains, and cast two bolt main caps are only good for so much. If it is a MUST DO, then working with a stock 440 block at the minimum i would offset grind a 440 crank to 4.0 inch stroke going to a sbc 2.1 bearing. Custom aluminum BME 396 forging rods, 7.10 long or longer to get a light piston in there. At .030 overbore you have 475 cubes. I would opt for a low compression ratio, 9.0? The lower ratio increases the dwell time of the power stroke , . E85 allows excellent boost and timing curve, plus cools the incoming charge. If a guy doesn't go above say 7 psi, i would hope 750 reliable hp could be made with a turbo? And live. Just my speculation. I built a 475 like discribed, and it had a good life normally aspirated.
[Re: gregsdart]
#3274753
12/08/24 08:48 AM
12/08/24 08:48 AM
Posts: 301 NY
challenger451ci
NY
Before I bought my Indy Maxx block, I did a lot of research and figuring. If I stuck with a stock block, it would have had gotten this girdle system: https://www.bcrproducts.com/caps_and_girdle_system.htmlI think the Indy block was right around $5k to the door at the time. It didn't make sense at that time to invest in the stock block and try to make it live north of 1000hp on nitrous. My low deck 451 had 100's of passes in the 9.30 to 9.50 range at 3500lbs with a factory stock 440 crank(low deck mains) and stock main caps with a 3/8" girdle and is still sitting in the corner as a spare. My machinst was an old school Super Stock guy that would balance stuff damn near perfect and the bobweight came out pretty light on that setup. Don't get greedy with the timing, and I think you can make them live.
[Re: challenger451ci]
#3274758
12/08/24 09:27 AM
12/08/24 09:27 AM
Posts: 8,125 Tulsa OK
Bad340fish
Tulsa OK
What is harder on them the RPM and horsepower or low end torque?
I know the junkyard LS guys don't like to work them down low. 800hp+ with a loose enough converter and running them to 8000RPM. I guess when you are leaning on them really hard if you drop them below 6500RPM they can bend the factory rods.
68 Barracuda Formula S 340
[Re: Dragula]
#3274760
12/08/24 09:33 AM
12/08/24 09:33 AM
Posts: 4,221 New York
polyspheric
New York
Reducing static CR with thick head gasket = bad idea.
Boffin Emeritus
