1969 Voltage Regulator Cover Restore #3273514
12/02/24 04:42 AM
12/02/24 04:42 AM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
I have a NOS 1969 voltage regulator. # 2098300 The paint on the cover needs redone. Is there anyone that restores these covers. I'd like to get the cover and the lettering repainted. Also on a June of 69 built car should the lettering be red or yellow.
Re: 1969 Voltage Regulator Cover Restore [Re: Davtona] #3273516
12/02/24 05:42 AM
12/02/24 05:42 AM
Poland, Ohio 44514
captainjack Offline
captainjack  Offline
Poland, Ohio 44514
I believe Performance Graphics in Florida restores the voltage regulator case and I believe cover is yellow. Hope this helps.
Re: 1969 Voltage Regulator Cover Restore [Re: captainjack] #3273525
12/02/24 07:00 AM
12/02/24 07:00 AM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
Yes Performance Car Graphics did these. But Dave sadly has passed away. Mike Mancini has taken over the business. But I have not heard if he is doing them so looking to see what is available.
Re: 1969 Voltage Regulator Cover Restore [Re: Davtona] #3273652
12/02/24 02:08 PM
12/02/24 02:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
On the any line regulators the printing was white, yellow was what was sold at the dealer. ECS can do the scrip, but they are limited on the date codes, call them. Question, does the body have a raised bump on the lower left hand side? Sorry, never mind what I said, for some reason I was thinking Imperial, which was the first car that got the electronic reg.
Re: 1969 Voltage Regulator Cover Restore [Re: 71birdJ68] #3273750
12/02/24 09:31 PM
12/02/24 09:31 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here ya go:
Re: 1969 Voltage Regulator Cover Restore [Re: kentj340] #3273752
12/02/24 09:42 PM
12/02/24 09:42 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
David Patik, now deceased, was owner of Performance Car Graphics of FL.
Scroll almost to bottom to restoration question 5.
Re: 1969 Voltage Regulator Cover Restore [Re: kentj340] #3273754
12/02/24 09:55 PM
12/02/24 09:55 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Reproduction with electronic internals that I bought years ago with a 1968 date code for my 1969 Barracuda built in November 1968.
Re: 1969 Voltage Regulator Cover Restore [Re: kentj340] #3273755
12/02/24 10:05 PM
12/02/24 10:05 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Factory original from my '69 Barracuda built in 1968 showing how the cover attaches to the base is not the same as the reproduction nor the eBay NOS.
Re: 1969 Voltage Regulator Cover Restore [Re: kentj340] #3273909
12/03/24 06:12 PM
12/03/24 06:12 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
MY 2cents. But this is NOT an oem regulator
But.
Now I'm starting to wonder what these are worth
Enjoy life today, It has an expiration date
Re: 1969 Voltage Regulator Cover Restore [Re: gtx6970] #3273977
12/04/24 03:20 AM
12/04/24 03:20 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Oops, my bad. The old regulator above is not factory original. I found a 1971 date code on the bottom side. It's most likely an aftermarket regulator since I would have bought it from a parts store, not a dealer's parts department.
Re: 1969 Voltage Regulator Cover Restore [Re: gtx6970] #3273996
12/04/24 08:19 AM
12/04/24 08:19 AM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
But Now I'm starting to wonder what these are worth
What they're worth will vary with the person. One note on the regulator shown. To my understanding the assembly line correct version will have 3 bars on the back side. Two directly side by side and a 3rd opposite them at an angle. My opinion the one shown with only the 2 bars is possibly a later over the parts counter issued regulator. Does anyone have a spare clamp and hex head bolt for the Field side wire hook up connection they would be willing to part with?? I'm looking for those.
Re: 1969 Voltage Regulator Cover Restore [Re: Davtona] #3274014
12/04/24 09:59 AM
12/04/24 09:59 AM
gtx6970 Offline
gtx6970  Offline
My 2 spares
Re: 1969 Voltage Regulator Cover Restore [Re: gtx6970] #3274021
12/04/24 10:30 AM
12/04/24 10:30 AM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
Here is the 3 bar version. I've got some of each. 3 bar is harder to find though seems like.
Re: 1969 Voltage Regulator Cover Restore [Re: Davtona] #3274035
12/04/24 11:14 AM
12/04/24 11:14 AM
gtx6970 Offline
gtx6970  Offline
I wonder what the difference is inside, if any.
Re: 1969 Voltage Regulator Cover Restore [Re: gtx6970] #3274047
12/04/24 12:09 PM
12/04/24 12:09 PM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
Can't answer that! Actually I've never had the cover off one. I think if a person really looks close this can be seen on the car as the regulator sticks out from the firewall some. Small detail for sure but one none the less!!
Re: 1969 Voltage Regulator Cover Restore [Re: kentj340] #3277011
12/18/24 10:38 PM
12/18/24 10:38 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
So if Dave Patik says the red lettered regulators are only on 1964 through 1967 cars and dealer replacements,
are the ones pictured by gtx6970 dealer replacements from 38th week 1968 and 26th week 1969 or 38th week 1978 and 26th week 1979?
Since they only have 2 coils on the back I wonder if they are the later?
MJ
Re: 1969 Voltage Regulator Cover Restore [Re: moparjohn] #3277190
12/19/24 10:38 PM
12/19/24 10:38 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
This was bought by Jack’s in 1982.
Don’t know when it was made
No date code on paint stamp
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: 1969 Voltage Regulator Cover Restore [Re: autoxcuda] #3277275
12/20/24 01:10 PM
12/20/24 01:10 PM
gtx6970 Offline
gtx6970  Offline
I have the stamps and the yellow ink, but no date code
And no red ink
If I could come up with a few spare OEM covers I might stamp a few for my car
Re: 1969 Voltage Regulator Cover Restore [Re: gtx6970] #3277333
12/20/24 05:01 PM
12/20/24 05:01 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
FWIW, the VR cover on my 17,000-mile RR has yellow lettering.
"059" on its cover, St Louis car, SPD 2/12/69.
Pretty sure it's original to the car - looks the same age as everything else under the hood, but I haven't worried about its date (yet laugh2).
Re: 1969 Voltage Regulator Cover Restore [Re: topside] #3277338
12/20/24 05:12 PM
12/20/24 05:12 PM
gtx6970 Offline
gtx6970  Offline
6000 mile 1966 satellite
