Re: Soda blast?
[Re: Neil]
#3273259
11/30/24 07:09 PM
11/30/24 07:09 PM
Posts: 21,973 A collage of whims
topside
A collage of whims
My paint rep was dead set against soda - it leaves a film that messes with adhesion if not removed. We always used a good ol' D-A sander with 80 grit and a fairly careful touch to avoid digging in; messy, but it works well. Used aircraft stripper a few times (very messy, toxic, eats everything) but I don't really care for it. I did have a guy "sandblast" my '63 wagon, but he had a very careful approach, a greyish media, and it didn't warp a thing. It sound to me like a D-A job on that truck - just take your time over a few days - and wear a respirator, latex gloves, and a shoot suit.
Re: Soda blast?
[Re: topside]
#3273262
11/30/24 07:51 PM
11/30/24 07:51 PM
Posts: 20,417 Park Forest, IL
slantzilla
Park Forest, IL
Patrick took his Barracuda to a place by Indy and had it chemical dipped. He was very happy with it, but you had to shoot primer on it quickly before it flash rusted.
I don't think it was real cheap.
Re: Soda blast?
[Re: cudaman1969]
#3273349
12/01/24 11:45 AM
12/01/24 11:45 AM
Posts: 5,720 Star Idaho
67vertman
Star Idaho
Like with sand blasting, trying to get the sand out afterwards, Soda blasting also flushes paint and grime into every nook and cranny. This will cause paint failure as Soda has a high Ph caustic content thus making the paint fail and bubble.
My Monster are real!
Living within your means makes life pretty easy.
Re: Soda blast?
[Re: 67vertman]
#3273361
12/01/24 12:50 PM
12/01/24 12:50 PM
Posts: 44,062 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Like with sand blasting, trying to get the sand out afterwards, Soda blasting also flushes paint and grime into every nook and cranny. This will cause paint failure as Soda has a high Ph caustic content thus making the paint fail and bubble. Exactly! That is why dry ice is still the best product, it just goes away once used... GOOGLE IT!
JB Rhinehart, Realist
A-Body's RULE!
Re: Soda blast?
[Re: Rhinodart]
#3273381
12/01/24 03:09 PM
12/01/24 03:09 PM
Posts: 6,638 nowhere
Sniper
nowhere
Like with sand blasting, trying to get the sand out afterwards, Soda blasting also flushes paint and grime into every nook and cranny. This will cause paint failure as Soda has a high Ph caustic content thus making the paint fail and bubble. Exactly! That is why dry ice is still the best product, it just goes away once used... GOOGLE IT! That doesn't address the "flushes paint and grime into every nook and cranny" issue. We used to use CO2 blasting to clean parts in the semiconductor plant I worked at. They still needed a solvent wipe down afterwards to clean the residual stuff off. There really is no 100% clean blasting option, just various different issues to address and you need to decide which issues bother you least. My SIL has an old Franklin stove in his shop. Works but is crusty, he wants to clean it up. He's going to use a wire wheel. Me? I would disassemble it, sand blast it, blow it off, paint it and reassemble. Why? Because sand blasting is cheapest and the clean up issue is not much of one in this case since it will be disassembled. But I will tell you that I hate the jack wagons that blast carbs with sand or soda.
Re: Soda blast?
[Re: cudaman1969]
#3273386
12/01/24 03:41 PM
12/01/24 03:41 PM
67vertman
Star Idaho
The OP said the vehicle is already striped down and parts separated. IMO, if that was the case I would find a good local sandblasting company and have them do it. I good sandblaster, one who knows what they are doing, can minimize body/panel damage and get it done quickly and cheaply .
Re: Soda blast?
[Re: topside]
#3273433
12/01/24 07:33 PM
12/01/24 07:33 PM
Posts: 1,470 oklahoma
forphorty
oklahoma
My paint rep was dead set against soda - it leaves a film that messes with adhesion if not removed. We always used a good ol' D-A sander with 80 grit and a fairly careful touch to avoid digging in; messy, but it works well. Used aircraft stripper a few times (very messy, toxic, eats everything) but I don't really care for it. I did have a guy "sandblast" my '63 wagon, but he had a very careful approach, a greyish media, and it didn't warp a thing. It sound to me like a D-A job on that truck - just take your time over a few days - and wear a respirator, latex gloves, and a shoot suit. Agree. I've stripped miles of paint off with a locked in DA. Be careful around body lines
Re: Soda blast?
[Re: volaredon]
#3273463
12/01/24 09:23 PM
12/01/24 09:23 PM
forphorty
oklahoma
That won't get in the corners very well like behind the drip rail on a D150 cab ..and other places. Two or three inch fuzzy Roloc discs can get in some pretty tight spots. Could get one of those cheapy hand held sandblasters and use silica sand to carefully hit those hard-to-get places as well.
