Re: 4150 carb max airflow
[Re: mopar873]
#3273579
12/02/24 11:33 AM
12/02/24 11:33 AM
Posts: 1,420 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I totally agree. I took off a 9375 Dominator and replaced it with the old Holley 80514 1000cfm annular. Lost very little in performance, but the idle quality, throttle response and low speed manners overall were amazing for the combo I was running. 446" with -1 heads and way too big of a cam and it still behaved really well. I've kind of been on the hunt for a 80514, I think that's a great carb for 410-450" engines. I built my own starting with a Braswell 1.59" v main body I picked up. Unfortunately, between the upgraded boosters & metering blocks and the slightly larger CNC'd venturi, the 80514 baseline tune I started with is horribly rich w/ this parts combination and I haven't started getting it dialed in, yet.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3273647
12/02/24 01:45 PM
12/02/24 01:45 PM
Posts: 10,653 Rittman Ohio
fourgearsavoy
Rittman Ohio
I got mine a year ago from Scogin Dicky Performance. They had it in stock and $30 lower than anyone else. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3273671
12/02/24 03:10 PM
12/02/24 03:10 PM
Brad_Haak
Loudoun County, VA
I got one years ago from either Autozone or Advance Auto Parts using a discount code that made it a killer deal for the carb I built and later sold, but it's not available from them now; Scoggins-Dickey doesn't list it anymore, either, FWIW. A few will pop up on Summit now and then, but then they go on backorder for months until the next ones trickle in.
[Re: hemienvy]
#3273696
12/02/24 05:41 PM
12/02/24 05:41 PM
Brad_Haak
Loudoun County, VA
Thanks to all on here, this has been a really informative thread.
While I don't doubt some of these carbs, especially with the annular boosters, will give great drivability, I still doubt that they flow 1000 CFM. I admit I have not called and chatted with some of these carb builders.
In fact, I've not read what a 1050 Dom with annular boosters will flow either, maybe it's actually way higher than 1050 at 1.5" pressure drop.
You can read what horsepower they support but not the actual flow numbers. Maybe I'm just being too picky, but I have to believe this info is out there somewhere. Maybe these will help 4150 dry flow tests4150 wet flow tests
[Re: Brad_Haak]
#3273801
12/03/24 07:47 AM
12/03/24 07:47 AM
Posts: 8,252 Plymouth, MI
Blusmbl
Plymouth, MI
Flow improvements? Minor; probably < 20 CFM wet; I've come to think dry flow comparisons aren't valid when different booster types (down-leg vs annular) are involved
Atomization and booster response improvements? Yes
And... can you find one? I've been searching for a Proform 67218 main body and don't see one anywhere. I suspect they're being made in limited quantities these days. Thanks, that's helpful. Just tried buying one from Summit, we'll see if it shows up!
[Re: mopar873]
#3273849
12/03/24 12:32 PM
12/03/24 12:32 PM
Posts: 2,783 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I totally agree. I took off a 9375 Dominator and replaced it with the old Holley 80514 1000cfm annular. Lost very little in performance, but the idle quality, throttle response and low speed manners overall were amazing for the combo I was running. 446" with -1 heads and way too big of a cam and it still behaved really well. I've kind of been on the hunt for a 80514, I think that's a great carb for 410-450" engines. I had a 80514 years ago and liked it. Then a year or 2 ago Holley or Summit was advertising a 80514-2, with is the same thing except made out of aluminum, and so I bought one of those. They charged me a few dollars less the $1,000 for it. That hurt.
2011 Drag Pak Challenger
