as my old man would say : "a buck 2 ninetyeight"...................
all kidding and wizea$$ery aside, that looks like a nicely designed and executed kit, based on my extensive fabrication and machining background.
as hemi parts in general are expensive, and throttle cable brackets alone can be between $40-65.00 just for the common wedge blocks [depending on carb application], in just my [probably worthless] opinion, your kit may be realistically worth around $150.00-175.00+ or so.
this depends entirely on A : how much time, effort in design, and expense you have in producing it, and B : how much you need/want to recoup your investment costs, less your time involvement. [one never seems to get back "the time invested element" in anything. or so it seems.
just my worthless opinion.
YOUR mileage WILL vary............
