Re: Ever had an MSD 6AL just die on you?
[Re: Streetwize]
#3272678
11/27/24 11:25 AM
11/27/24 11:25 AM
Posts: 13,581 Marion, South Carolina [><]
an8sec70cuda
Pat Collins, TechWest Racing.
Only time I've just had one die is from low battery voltage.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Streetwize]
#3272679
11/27/24 11:26 AM
11/27/24 11:26 AM
Posts: 12,505 Taxes & Virus's R-US, NY
Dragula
Usually, repeated cranking with a nearly dead battery will take out the 6A, 6AL, and or the coil....Somtimes the coil goes first and then the box, somtimes the box.
I had my coil swell up and quit before the box quit on the next fire up. I have had a couple of these boxes quit, and yet, my 7AL2 has been mercilessly cranked on a nearly dead battery, and no issues, coil or otherwise. And that has been in my street car since '96 when I bought it.
I have switched to Petronix and had no issues in my race car. Was tired of changing out boxes. I am also in the middle of changing out the one in my street car. I like all the features on the newer boxes so I have a 7AL just sitting here.
[Re: topside]
#3272691
11/27/24 11:56 AM
11/27/24 11:56 AM
Posts: 4,678 Motor City
6PKRTSE
Motor City
Yes, we have had dozens and dozens of defective boxes, distributors and EFI components fail. Send them back in to MSD and they mysteriously always check out good and MSD ships back at no charge... They fix whatever is wrong with it and send back claiming nothing was wrong with it so they don't get a bad reputation out in the field.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Dragula]
#3272703
11/27/24 12:21 PM
11/27/24 12:21 PM
Posts: 2,562 PA
moparacer
PA
Did you do a spark test by jumping the pickup wires? I always do that to test the box in a no spark situation.
The only time I have ever had a MSD box die was when someone hooked a battery charger up backwards years ago.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 5.44-126 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3272732
11/27/24 01:24 PM
11/27/24 01:24 PM
Posts: 3,012 A shed in England
Tig
A shed in England
IIRC Frieburger broke a couple of 6 AL's on his '56 using solid core wires. I've never had any issues with MSD stuff and haven't heard of too many problems this side of the pond, we had a rash of counterfeit ones entering the market all bearing the same serial number a few years ago but heard nothing since.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Streetwize]
#3272760
11/27/24 03:54 PM
11/27/24 03:54 PM
Posts: 43,986 Bend,OR USA
Cab_Burge
[Re: 6PKRTSE]
#3272879
11/28/24 08:36 AM
11/28/24 08:36 AM
Posts: 3,643 Oakland, MI
dizuster
Oakland, MI
Yes, we have had dozens and dozens of defective boxes, distributors and EFI components fail. Send them back in to MSD and they mysteriously always check out good and MSD ships back at no charge... They fix whatever is wrong with it and send back claiming nothing was wrong with it so they don't get a bad reputation out in the field. Its not uncommon that simply unplugging, removing, and plugging stuff back in is what actually fixes it. A module failure itself is actually pretty rare. It's almost always the connection itself, grounds, etc... that are the problem. It's step one taught to problem solving. Remove the part completely, and re install it. It seems dumb, but you would be SHOCKED how many times that fixes a problem like this. Not to say stuff doesn't fail of course too.
[Re: Moparite]
#3273345
12/01/24 11:29 AM
12/01/24 11:29 AM
Posts: 5,189 CT
GTX MATT
CT
Make sure the box has switched power, and your distributor is triggering it. You can test by grounding or jumping one of the trigger wires, theres instructions on MSD’s site.
Like Andy said you can send it back to MSD and they will diagnose it and tell you what it costs to fix but its really reasonable. I got one from a buddy that he fried somehow and it was around $80 with return shipping.
People are selling the old analog boxes cheap these days too, but they are surprisingly well built and MSD’s customer service is very good.
[Re: Streetwize]
#3273534
12/02/24 08:32 AM
12/02/24 08:32 AM
Posts: 8,952 Holly/MI
Dean_Kuzluzski
Holly/MI
I got 2 reman'd by Holley's Tech Repair back around 2021. It was about $85 a piece. Toughest part was getting through the phone system to a live Technician. But, service was excellent thereafter. Both started dying intermittently, like they were overheating. My theory is there's a big capacitor that is used to create the "Multiple discharge" affect and it eventually breaks down. I still buy cores for $50 to send in.
[Re: A727Tflite]
#3273659
12/02/24 02:38 PM
12/02/24 02:38 PM
Posts: 10,653 Rittman Ohio
fourgearsavoy
Rittman Ohio
Removing the battery cable while running and reattaching will take them out too. The tech guy at the track switches my battery off and it is basically doing the same thing and my box is still doing good. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3273663
12/02/24 02:45 PM
12/02/24 02:45 PM
Posts: 3,219 Michigan
A727Tflite
Removing the battery cable while running and reattaching will take them out too. The tech guy at the track switches my battery off and it is basically doing the same thing and my box is still doing good. Gus Then the MSD tech guy lied to me after mine failed doing this. He switches it off then on while it is running? Do you have the later MSD with the full time + and - wires?
[Re: A727Tflite]
#3273720
12/02/24 06:43 PM
12/02/24 06:43 PM
fourgearsavoy
Rittman Ohio
Yeah that is how they test your shut-off switch they flip it off while it's running to make sure it shuts off. If it doesn't then it's pretty much useless. My 6AL is about 25 years old since I sent it to MSD when I bought it used to have them extend the wires and check it out. I am aware of how voltage spikes can damage electronic devices and I'm not saying it can't happen but tech inspectors do this to thousands of cars every weekend. Gus
[Re: fourgearsavoy]
#3273797
12/03/24 06:21 AM
12/03/24 06:21 AM
Tig
A shed in England
Yeah that is how they test your shut-off switch they flip it off while it's running to make sure it shuts off. If it doesn't then it's pretty much useless. My 6AL is about 25 years old since I sent it to MSD when I bought it used to have them extend the wires and check it out. I am aware of how voltage spikes can damage electronic devices and I'm not saying it can't happen but tech inspectors do this to thousands of cars every weekend. Gus The MSD tech guy told me what kills them is reattaching the battery cable while running - if I recall he said it goes full field while disconnected then zaps the box when reconnected. I’m no electrical expert, still haven’t forgot my first electric shock. Yep they check it the same over here too. The battery isolation (kill) switch should turn everything off and the engine should stop. Removing the battery cables while the engine is running will still allow the engine to run IF the alternator field circuit isn't interrupted. This can cause voltage spikes as the battery acts as a type of voltage "buffer". I've had no issues with either an analogue 6AL or a Grid when the kill switch is checked but on the grid we do have a MSD filter (capacitor), which we also take the voltage supply for the Racepak from. This filters out any RFI or relay spikes though we've fitted flywheel diodes to the relays where possible.
[Re: A727Tflite]
#3273829
12/03/24 11:25 AM
12/03/24 11:25 AM
an8sec70cuda
So if your kill switch works properly, this won't be an issue.
[Re: an8sec70cuda]
#3273845
12/03/24 12:20 PM
12/03/24 12:20 PM
Tig
A shed in England
So if your kill switch works properly, this won't be an issue. Never had an issue, first started racing in '96 and they check it at least once every season. I'm always switching it on and off too but usually the car isn't running.
