Re: For Sale/ Wanted - Big Block Engine - 4th Quarter
[Re: moparts]
#3265325
10/20/24 12:08 PM
10/20/24 12:08 PM
Posts: 8,170 DELAWARE
TONY_DAGOSTINO
DELAWARE
383 aluminum intakes-Edelbrock DP4B also has Chrysler part# $300 Very nice, threads are good, no cracks or repairs. Hasn’t been ported. Doesn’t appear to have been sandblasted prior but could use a cleaning now. Fits 400 cid too. -Edelbrock Torker $250 Good shape, hasn’t been ported or ground on. 2 Carb Bolt Holes Have some Upper Threads Missing, But the Threads Below Are Good and Hold a Bolt/Stud Just Fine. The Rest Are Good. The EGR port at the bottom of the plenum was blocked off. Doesn’t appear it’s been sand blasted prior, no cracks or elongated holes. -Holley Street Dominator $275 Very nice, threads are good, no cracks or repairs. Hasn’t been ported. Doesn’t appear to have been sandblasted prior but should be blasted or tanked before use. more pics available send email to tonymopar@aol.comCan ship. Located in Oceanside California
[Re: TONY_DAGOSTINO]
#3265326
10/20/24 12:10 PM
10/20/24 12:10 PM
TONY_DAGOSTINO
DELAWARE
440 6-Pack Intake Manifold $775. Original Mopar Cast Iron. Excellent Condition. No cracks or repairs threads are good and hasn’t been modified. please email tonymopar@aol.comCan ship, but its heavy. Located in Oceanside California
[Re: moparts]
#3265328
10/20/24 12:12 PM
10/20/24 12:12 PM
TONY_DAGOSTINO
DELAWARE
383 2x4 barrel dual quad intake manifold. $450 Original Chrysler Mopar part. Cast iron. No cracks or repairs, threads are good. also fits 400 cid. Can ship, but its heavy. located in Oceanside California please email tonymopar@aol.com
Water Pump Pulley - WTB
[Re: moparts]
#3265792
10/22/24 09:53 AM
10/22/24 09:53 AM
Posts: 141 Central Pa.
Cloned_Cuda
Central Pa.
Single Groove Water Pump Pulley that I'm looking for:
6" - 6 1/2" OD, 2 1/8" - 2 1/4" depth measuring from the back edge of the pulley to the inside face of the pulley (where it mounts to the water pump).
PM me here
Thanks Moparts
[Re: moparts]
#3266717
10/27/24 05:24 PM
10/27/24 05:24 PM
Posts: 1,685 Cleveland, OH
TWS
Cleveland, OH
For Sale: A set of original 440 six-pack carbs for 4-speed. Holley LIST 4375 (center, date 2839), 4382 (front, date 2349), and 4383 (rear, date 2829). More pics available upon request.
$1,600, plus shipping. I'm never offended by offers. Parts located in Cleveland, OH. Free delivery to MCACN in November, or other possible delivery.
TWSchuler@aol.com
Dated cast iron 440-6 intake also available. I have other six-pack, T/A, NOS and nice used Challenger parts for sale. Message me for a list if interested.
Wanted forged 440 crank
[Re: TWS]
#3267645
11/01/24 02:57 PM
11/01/24 02:57 PM
Posts: 277 MI
IROC78
MI
Found and no longer needed pending machine shop giving it a thumbs up. Thank you !
[Re: moparts]
#3269258
11/08/24 11:32 PM
11/08/24 11:32 PM
Posts: 2,775 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I want to build a wedge. I have a B and an RB block to start with. I'm not sure which one I want to build so I guess I'll just start trying to round up some parts and whichever one I find the parts for, I'll go with that one. I like the 337 intake for the 440 and I would like a 4500 M1 for a low block. If you can help me out with these let me know, thanks. Rick Seeman 501-519-742five
2011 Drag Pak Challenger
[Re: moparts]
#3270809
11/16/24 06:46 PM
11/16/24 06:46 PM
Posts: 4,388 Madison Wi
NTOLERANCE
Madison Wi
1970 383 engine
$1500
Will consider trades for a ready to go Mopar 18 spline four speed with the dual pattern tail housing, or 23 spline dual pattern trans with cash on your end
Located in Stoughton WI 53589. Prefer local pick up.
70 non-hp 383 from a full sized car. (Car was scrapped long ago) This was a very low mileage engine when I got it- 27,000??
I put new rings, bearings and seals in it. STD bore.
Heads are fresh 346 castings with new valves guides and seals. I have a set of hp valve springs, retainers and locks - those aluminum pieces are just to keep the heads together.
Includes a vintage erson hyd flat tappet performance cam, new vintage lifter set, ( shouldnt have any cam lobe issues with this stuff from the 1980's) mechanical push rods, and a set of crane iron rockers that may need some work. Also included: Deep oil pan and pick up. Double roller timing set Weiand aluminum dual plane intake Probably some other stuff I am forgetting.
I've had this engine for a decade or so. Just dont see me using it.
Will trade for a ready to go b/e body 18 spline Mopar four speed. I'll consider a 23 spline if you add some cash.
