'71 Cuda 6-bbl tribute #3272316
11/25/24 12:25 PM
11/25/24 12:25 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
This popped up on my feed today, if anyone's interested:
https://www.hemmings.com/auction/1971-plymouth-cuda-wentworth-sd-341209?
It has a few of the greatest-hits irritants - certified Moparx battery terminal, plastic dash cover, helper shocks, budget-ugly radiator, wanna-be-racer wing - but might be fun.
$35,000 bid so far, not yet @ reserve.
Re: '71 Cuda 6-bbl tribute [Re: topside] #3272326
11/25/24 12:58 PM
11/25/24 12:58 PM
Kirkland, Washington
Pacnorthcuda Offline
Bummer that they painted the Tailpanel black too far! Put the much needed M88 moulding on and the black will be OUTSIDE of the moulding. And black out the rear marker light housings(easy).
Re: '71 Cuda 6-bbl tribute [Re: Pacnorthcuda] #3272331
11/25/24 01:49 PM
11/25/24 01:49 PM
MN
Droop69 Offline
Droop69  Offline
MN
It was a pretty cool car originally, FJ6, white top and interior. 3 speed stick
Re: '71 Cuda 6-bbl tribute [Re: Droop69] #3272334
11/25/24 02:20 PM
11/25/24 02:20 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Way over done.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: '71 Cuda 6-bbl tribute [Re: Droop69] #3272352
11/25/24 03:59 PM
11/25/24 03:59 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Remove the dirty floor mats before you take the pictures. tsk Lots of small things done incorrectly, so it makes one wonder what other short cuts were taken.
It would be a fun driver if you could get it cheaply enough.
My Monster are real!
Living within your means makes life pretty easy.
