Weber Belt Drive Installation?
#721902
06/11/10 09:01 PM
06/11/10 09:01 PM
Posts: 6,187 Melbourne , Australia
LA360
I just wanted to clarify a couple of things with the installation of one of these belt drives.
There are two copper washers that come in the kit, one os to be installed onto the cam prior to the cam adapter? The second is then put onto the cam adapter followed by the thrust plate and appropriate shims?
AL...
Alan Jones
Re: Weber Belt Drive Installation?
[Re: LA360]
#721903
06/12/10 04:22 AM
06/12/10 04:22 AM
Posts: 1,019 Finland
mafo
Finland
Thats how I have it installed, don t know if it s correct but it works
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#721904
06/12/10 06:08 AM
06/12/10 06:08 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Al, I still have my installation instruction sheet from Dave Weber and you are correct.
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#721905
06/12/10 06:24 PM
06/12/10 06:24 PM
LA360
Thanks guys, I have to make up some new washers for my own unit, and help fit one to my friend's engine. I do recall being told that alot of the Comp guys that used there would machine the block to replace washers with a torrington roller thrust bearing. Something to look at for me later on.
Many thanks for the replies guys.
AL....
Alan Jones
[Re: LA360]
#721906
06/14/10 08:06 PM
06/14/10 08:06 PM
LA360
How have these washers looked when you had the belt drive apart? How much racing had you done on it when you had it all apart?
Alan Jones
[Re: LA360]
#721911
06/15/10 03:07 PM
06/15/10 03:07 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I emailed Dave Weber and got a PDF file of the install instructions. You can do that..........sorry , I don't have his email address handy ( edited to add.......someone does. And don't I feel like a dunce. ........ or fire off an email to me at tubtar@msn.com and I will forward the attachment to you. It is pretty much what has been detailed on here.
[Re: tubtar]
#3272089
11/24/24 12:19 AM
11/24/24 12:19 AM
Posts: 1,409 CA.
RAY1969CARS
CA.
I emailed Dave Weber and got a PDF file of the install instructions. You can do that..........sorry , I don't have his email address handy ( edited to add.......someone does. And don't I feel like a dunce. <img src="/ubbthreads/images/graemlins/laugh2.gif" alt="" /> ........ or fire off an email to me at tubtar@msn.com and I will forward the attachment to you. It is pretty much what has been detailed on here. <img src="/ubbthreads/images/graemlins/thumbs.gif" alt="" /> hi sir could i get a copy of that pdf ?
[Re: LA360]
#3272091
11/24/24 01:29 AM
11/24/24 01:29 AM
Posts: 23,617 Here
jcc
No soup for you!!!
No soup for you!!!
Here
AL.... Why, for a non-roller application?
I'm with Helmuth Hübener, and no soup is being served today.
